TFrecord that created in tensorflow object detection API
I am trying to do a resnet10 detection model training. And I have already create a tfrecord in tensorflow object detection API, instead of using convertion tool from TLT.
Is it okay for TLT to train a model with this kind of tfrecord?
Cause now it occured an error when start doing the training.
Using TensorFlow backend.
2019-04-10 03:42:50.027390: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1356] Found device 0 with properties:
name: Tesla P4 major: 6 minor: 1 memoryClockRate(GHz): 1.1135
pciBusID: 0000:05:00.0
totalMemory: 7.43GiB freeMemory: 7.31GiB
2019-04-10 03:42:50.027470: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1435] Adding visible gpu devices: 0
2019-04-10 03:42:54.552814: I tensorflow/core/common_runtime/gpu/gpu_device.cc:923] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-04-10 03:42:54.552890: I tensorflow/core/common_runtime/gpu/gpu_device.cc:929]      0
2019-04-10 03:42:54.552900: I tensorflow/core/common_runtime/gpu/gpu_device.cc:942] 0:   N
2019-04-10 03:42:54.553193: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1053] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 7063 MB memory) -> physical GPU (device: 0, name: Tesla P4, pci bus id: 0000:05:00.0, compute capability: 6.1)
2019-04-10 03:42:54,709 [INFO] /usr/local/lib/python2.7/dist-packages/iva/dashnet/scripts/train.pyc: Loading experiment spec at /workspace/tlt-experiments//nvidia_tlt/spec.txt.
2019-04-10 03:42:54,711 [INFO] /usr/local/lib/python2.7/dist-packages/dlav/drivenet/spec_handling/spec_loader.pyc: Merging specification from /workspace/tlt-experiments//nvidia_tlt/spec.txt
2019-04-10 03:43:47,074 [INFO] /usr/local/lib/python2.7/dist-packages/iva/dashnet/scripts/train.pyc: Cannot iterate over exactly 330258 samples with a batch size of 16; each epoch will therefore take one extra step.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
input_1 (InputLayer)            (None, 3, 544, 960)  0
conv1 (Conv2D)                  (None, 64, 272, 480) 9472        input_1[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 272, 480) 256         conv1[0][0]
activation_1 (Activation)       (None, 64, 272, 480) 0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 136, 240) 36928       activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 136, 240) 256         block_1a_conv_1[0][0]
activation_2 (Activation)       (None, 64, 136, 240) 0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 136, 240) 36928       activation_2[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 136, 240) 4160        activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 136, 240) 256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 136, 240) 256         block_1a_conv_shortcut[0][0]
add_1 (Add)                     (None, 64, 136, 240) 0           block_1a_bn_2[0][0]
        block_1a_bn_shortcut[0][0]
activation_3 (Activation)       (None, 64, 136, 240) 0           add_1[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 68, 120) 73856       activation_3[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 68, 120) 512         block_2a_conv_1[0][0]
activation_4 (Activation)       (None, 128, 68, 120) 0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 68, 120) 147584      activation_4[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 68, 120) 8320        activation_3[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 68, 120) 512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 68, 120) 512         block_2a_conv_shortcut[0][0]
add_2 (Add)                     (None, 128, 68, 120) 0           block_2a_bn_2[0][0]
        block_2a_bn_shortcut[0][0]
activation_5 (Activation)       (None, 128, 68, 120) 0           add_2[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 34, 60)  295168      activation_5[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 34, 60)  1024        block_3a_conv_1[0][0]
activation_6 (Activation)       (None, 256, 34, 60)  0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 34, 60)  590080      activation_6[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 34, 60)  33024       activation_5[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 34, 60)  1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 34, 60)  1024        block_3a_conv_shortcut[0][0]
add_3 (Add)                     (None, 256, 34, 60)  0           block_3a_bn_2[0][0]
        block_3a_bn_shortcut[0][0]
activation_7 (Activation)       (None, 256, 34, 60)  0           add_3[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 34, 60)  1180160     activation_7[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 34, 60)  2048        block_4a_conv_1[0][0]
activation_8 (Activation)       (None, 512, 34, 60)  0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 34, 60)  2359808     activation_8[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 34, 60)  131584      activation_7[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 34, 60)  2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 34, 60)  2048        block_4a_conv_shortcut[0][0]
add_4 (Add)                     (None, 512, 34, 60)  0           block_4a_bn_2[0][0]
        block_4a_bn_shortcut[0][0]
activation_9 (Activation)       (None, 512, 34, 60)  0           add_4[0][0]
dropout_1 (Dropout)             (None, 512, 34, 60)  0           activation_9[0][0]
output_bbox (Conv2D)            (None, 12, 34, 60)   6156        dropout_1[0][0]
output_cov (Conv2D)             (None, 3, 34, 60)    1539        dropout_1[0][0]
Total params: 4,926,543
Trainable params: 4,920,655
Non-trainable params: 5,888
  File "/usr/local/bin/tlt-train-g1", line 10, in <module>
    sys.exit(main())
  File "./common/magnet_train.py", line 24, in main
  File "</usr/local/lib/python2.7/dist-packages/decorator.pyc:decorator-gen-106>", line 2, in main
  File "./drivenet/common/timer.py", line 46, in wrapped_fn
  File "./dashnet/scripts/train.py", line 627, in main
  File "./dashnet/scripts/train.py", line 552, in run_experiment
  File "./dashnet/scripts/train.py", line 457, in train_dashnet
  File "./dashnet/scripts/train.py", line 291, in build_training_graph
  File "./drivenet/common/dataloader/default_dataloader.py", line 199, in get_dataset_tensors
  File "./drivenet/common/dataloader/default_dataloader.py", line 240, in _generate_images_and_ground_truth_labels
  File "./drivenet/common/dataloader/default_dataloader.py", line 375, in _load_input_tensors
KeyError: 'frame/id'
Hoping to get a reply.
Thx in advance
Unfortunately, only TFRecords generated using converter tool will be compatible with TLT training.
Thanks,
Adil
