Hi all, I’m trying to retrain trafficcamnet, i encountered below error. How can I deal with this error?
2022-10-27 20:20:07,893 [INFO] root: Registry: ['nvcr.io']
2022-10-27 20:20:08,055 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.4-py3
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-htgmt8ae because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2022-10-27 11:20:15,873 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-10-27 11:20:16,004 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-10-27 11:20:16,734 [INFO] root: Starting DetectNet_v2 Training job
2022-10-27 11:20:16,734 [INFO] __main__: Loading experiment spec at /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_its.txt.
2022-10-27 11:20:16,735 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_its.txt
2022-10-27 11:20:16,752 [INFO] root: Training gridbox model.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-10-27 11:20:16,752 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-10-27 11:20:17,572 [INFO] root: Sampling mode of the dataloader was set to user_defined.
2022-10-27 11:20:17,572 [INFO] __main__: Cannot iterate over exactly 8862 samples with a batch size of 8; each epoch will therefore take one extra step.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2022-10-27 11:20:17,576 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2022-10-27 11:20:17,577 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2022-10-27 11:20:17,580 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2022-10-27 11:20:17,856 [INFO] root: Building DetectNet V2 model
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-10-27 11:20:17,856 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-10-27 11:20:17,857 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-10-27 11:20:17,880 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2022-10-27 11:20:20,071 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2022-10-27 11:20:20,071 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2022-10-27 11:20:20,072 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2022-10-27 11:20:20,513 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Compile it manually.
warnings.warn('No training configuration found in save file: '
2022-10-27 11:20:32,631 [INFO] iva.detectnet_v2.objectives.bbox_objective: Default L1 loss function will be used.
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 720, 1280) 0
conv1 (Conv2D) (None, 64, 360, 640) 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 360, 640) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 360, 640) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 180, 320) 36928 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 180, 320) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 180, 320) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 180, 320) 36928 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 180, 320) 4160 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 180, 320) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 180, 320) 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 180, 320) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 180, 320) 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 180, 320) 36928 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 180, 320) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 180, 320) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 180, 320) 36928 block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 180, 320) 4160 block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 180, 320) 256 block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 180, 320) 256 block_1b_conv_shortcut[0][0]
add_2 (Add) (None, 64, 180, 320) 0 block_1b_bn_2[0][0]
block_1b_bn_shortcut[0][0]
block_1b_relu (Activation) (None, 64, 180, 320) 0 add_2[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 90, 160) 73856 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 90, 160) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 90, 160) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 90, 160) 147584 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 90, 160) 8320 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 90, 160) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 90, 160) 512 block_2a_conv_shortcut[0][0]
add_3 (Add) (None, 128, 90, 160) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 90, 160) 0 add_3[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 90, 160) 147584 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 90, 160) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 90, 160) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 90, 160) 147584 block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 90, 160) 16512 block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 90, 160) 512 block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 90, 160) 512 block_2b_conv_shortcut[0][0]
add_4 (Add) (None, 128, 90, 160) 0 block_2b_bn_2[0][0]
block_2b_bn_shortcut[0][0]
block_2b_relu (Activation) (None, 128, 90, 160) 0 add_4[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 45, 80) 295168 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 45, 80) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 45, 80) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 45, 80) 590080 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 45, 80) 33024 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 45, 80) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 45, 80) 1024 block_3a_conv_shortcut[0][0]
add_5 (Add) (None, 256, 45, 80) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 45, 80) 0 add_5[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 45, 80) 590080 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 45, 80) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 45, 80) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 45, 80) 590080 block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 45, 80) 65792 block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 45, 80) 1024 block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 45, 80) 1024 block_3b_conv_shortcut[0][0]
add_6 (Add) (None, 256, 45, 80) 0 block_3b_bn_2[0][0]
block_3b_bn_shortcut[0][0]
block_3b_relu (Activation) (None, 256, 45, 80) 0 add_6[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 45, 80) 1180160 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 45, 80) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 45, 80) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 45, 80) 2359808 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 45, 80) 131584 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 45, 80) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 45, 80) 2048 block_4a_conv_shortcut[0][0]
add_7 (Add) (None, 512, 45, 80) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 45, 80) 0 add_7[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 45, 80) 2359808 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 45, 80) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 45, 80) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 45, 80) 2359808 block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 45, 80) 262656 block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 45, 80) 2048 block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 45, 80) 2048 block_4b_conv_shortcut[0][0]
add_8 (Add) (None, 512, 45, 80) 0 block_4b_bn_2[0][0]
block_4b_bn_shortcut[0][0]
block_4b_relu (Activation) (None, 512, 45, 80) 0 add_8[0][0]
output_bbox (Conv2D) (None, 44, 45, 80) 22572 block_4b_relu[0][0]
output_cov (Conv2D) (None, 11, 45, 80) 5643 block_4b_relu[0][0]
Total params: 11,576,503
Trainable params: 11,564,855
Non-trainable params: 11,648
2022-10-27 11:20:32,667 [INFO] root: DetectNet V2 model built.
2022-10-27 11:20:32,667 [INFO] root: Building rasterizer.
2022-10-27 11:20:32,668 [INFO] root: Rasterizers built.
2022-10-27 11:20:32,668 [INFO] root: Building training graph.
2022-10-27 11:20:32,670 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-10-27 11:20:32,670 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-10-27 11:20:32,670 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-10-27 11:20:32,670 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 40, io threads: 80, compute threads: 40, buffered batches: 4
2022-10-27 11:20:32,671 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 8862, number of sources: 1, batch size per gpu: 8, steps: 1108
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-10-27 11:20:32,716 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f9fe3d22eb8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f9fe3d22eb8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-10-27 11:20:32,761 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f9fe3d22eb8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f9fe3d22eb8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-10-27 11:20:32,787 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2022-10-27 11:20:33,058 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: True - shard 0 of 1
2022-10-27 11:20:33,064 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2022-10-27 11:20:33,064 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f9fe3e65898>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f9fe3e65898>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-10-27 11:20:33,079 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f9fe3e65898>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f9fe3e65898>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-10-27 11:20:33,485 [INFO] __main__: Found 8862 samples in training set
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/visualizer/tensorboard_visualizer.py:79: The name tf.summary.image is deprecated. Please use tf.compat.v1.summary.image instead.
2022-10-27 11:20:33,489 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/visualizer/tensorboard_visualizer.py:79: The name tf.summary.image is deprecated. Please use tf.compat.v1.summary.image instead.
2022-10-27 11:20:33,492 [INFO] root: Rasterizing tensors.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/rasterizers/bbox_rasterizer.py:347: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
2022-10-27 11:20:33,604 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/rasterizers/bbox_rasterizer.py:347: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
2022-10-27 11:20:33,806 [INFO] root: Tensors rasterized.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:89: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
2022-10-27 11:20:33,807 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:89: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:515: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
2022-10-27 11:20:33,824 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:515: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:36: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
2022-10-27 11:20:33,824 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:36: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_functions.py:17: The name tf.log is deprecated. Please use tf.math.log instead.
2022-10-27 11:20:34,063 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_functions.py:17: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:235: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2022-10-27 11:20:34,747 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:235: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/visualizer/tensorboard_visualizer.py:85: The name tf.summary.histogram is deprecated. Please use tf.compat.v1.summary.histogram instead.
2022-10-27 11:20:37,886 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/visualizer/tensorboard_visualizer.py:85: The name tf.summary.histogram is deprecated. Please use tf.compat.v1.summary.histogram instead.
2022-10-27 11:20:40,559 [INFO] root: Training graph built.
2022-10-27 11:20:40,560 [INFO] root: Building validation graph.
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 917, in <module>
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 906, in <module>
File "<decorator-gen-2>", line 2, in main
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 893, in main
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 757, in run_experiment
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 682, in train_gridbox
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 556, in build_validation_graph
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py", line 704, in get_dataset_tensors
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/modulusobject/modulusobject.py", line 432, in wrapper
File "/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/data_loader.py", line 137, in __init__
ValueError: DataLoader excepts at least one element in data_sources.
2022-10-27 20:20:42,124 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
