HI,
使用如下命令,网路camera能正常出图,但是软件编解码,导致摄像头会很卡,没办法使用,请问一下有没有什么办法,感谢
gst-launch-1.0 uridecodebin uri=rtsp://admin:ZKCD1234@192.168.1.64:554 latency=0 ! nv3dsink
HI,
Please set the environment variable and check if hardware decoder is used:
$ export GST_DEBUG=*FACTORY*:4
Please try the pipeline and see if hardware decoder can decode the stream:
$ gst-launch-1.0 rtspsrc location="rtsp://admin:ZKCD1234@192.168.1.64:554" ! rtph265depay ! h265parse ! nvv4l2decoder ! "video/x-raw(memory:NVMM)" ! nv3dsink sync=0
下面命令指令会报错
log.txt (698 Bytes)
Seems like the available memory is insufficient in the system. Please run the commands and see if nvv4l2decoder is present:
$ rm .cache/gstreamer-1.0/registry.aarch64.bin
$ gst-inspect-1.0 nvv4l2decoder
If nvv4l2decoder is present, please try the command for decoding RTSP again. If it still does not work, we suggest re-flash Jetpack 5.1.2 through SDKManager and try again.
这个办法不行,升级到5.1.2时间比较久,我们在我们自己板子上做的,需要移植很多驱动,有没有不升级的办法。我们在orin nx上试过 gst-launch-1.0 uridecodebin uri=rtsp://admin:ZKCD1234@192.168.1.64:554 latency=0 ! nv3dsink这个命令就能硬件码,延迟也比较低
If you cannot re-flash the system, please investigate why this happens on your environment:
ERROR: from element /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0: Could not open device '/dev/nvhost-nvdec' for reading and writing.
Additional debug info:
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-v4l2/gst-v4l2/v4l2_calls.c(651): gst_v4l2_open (): /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0:
system error: Cannot allocate memory
On default L4T release this error is not seen. So it may be triggered by your customization.
我们在我们自己板子上,64G的模组硬解码能打开,32G的模组硬解码是关闭的,同一个工程的代码,Jetpack 5.1.1的,但是现象不太一样,请问一下我们如何去修复此问题,谢谢
32GB of DRAM may be insufficient for the use-case, so decoder cannot allocate the memory in initialization. Suggest you check and try to reduce the memory usage when using Orin 32GB.
