I’m trying to interface an camera. Can anyone give any insight into this error?
kworker/4:1-11285 [004] .... 1186.329937: rtcpu_string: tstamp:37844597383 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-29623 [002] .... 1200.199442: tegra_channel_open: vi-output, ORB mux 2-001a
v4l2-ctl-29623 [002] .... 1200.201167: tegra_channel_set_power: ORB mux 2-001a : 0x1
v4l2-ctl-29623 [002] .... 1200.201169: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-29623 [002] .... 1200.201171: csi_s_power: enable : 0x1
v4l2-ctl-29623 [002] .... 1200.201263: tegra_channel_capture_setup: vnc_id 0 W 1280 H 960 fmt 5
v4l2-ctl-29623 [001] .... 1200.207135: tegra_channel_set_stream: enable : 0x1
kworker/4:1-11285 [004] .... 1200.210018: rtcpu_string: tstamp:38278483431 id:0x04010000 str:"VM0 activating."
v4l2-ctl-29623 [002] .... 1200.211606: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-29623 [002] .... 1200.211609: csi_s_stream: enable : 0x1
v4l2-ctl-29623 [002] .... 1200.211899: tegra_channel_set_stream: ORB mux 2-001a : 0x1
kworker/4:1-11285 [004] .... 1200.265941: rtcpu_vinotify_event: tstamp:38278928281 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1224915226240 data:0x759e300010000000
kworker/4:1-11285 [004] .... 1200.265943: rtcpu_vinotify_event: tstamp:38278928440 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1224915232704 data:0x0000000031000001
kworker/4:1-11285 [004] .... 1200.265943: rtcpu_vinotify_event: tstamp:38278928597 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1224915273056 data:0x759e2d0010000000
kworker/4:1-11285 [004] .... 1200.265944: rtcpu_vinotify_event: tstamp:38278928731 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1224915279648 data:0x0000000031000002
kworker/4:1-11285 [004] .... 1200.321937: rtcpu_nvcsi_intr: tstamp:38281971421 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x00000002
kworker/4:1-11285 [004] .... 1200.321939: rtcpu_nvcsi_intr: tstamp:38281971421 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:14 status:0x00000002
kworker/4:1-11285 [004] .... 1200.321939: rtcpu_nvcsi_intr: tstamp:38281972003 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321940: rtcpu_nvcsi_intr: tstamp:38281972003 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321940: rtcpu_n vcsi_intr: tstamp:38281972663 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321940: rtcpu_nvcsi_intr: tstamp:38281972663 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321940: rtcpu_nvcsi_intr: tstamp:38281973326 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321941: rtcpu_nvcsi_intr: tstamp:38281973326 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321941: rtcpu_nvcsi_intr: tstamp:38281974101 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321941: rtcpu_nvcsi_intr: tstamp:38281974101 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321941: rtcpu_nvcsi_intr: tstamp:38281974699 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x00000008
kworker/4:1-11285 [004] .... 1200.321942: rtcpu_nvcsi_intr: tstamp:38281974699 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x00000008
kworker/4:1-11285 [004] .... 1200.321942: rtcpu_nvcsi_intr: tstamp:38281975367 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321942: rtcpu_nvcsi_intr: tstamp:38281975367 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321942: rtcpu_nvcsi_intr: tstamp:38281975984 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321943: rtcpu_nvcsi_intr: tstamp:38281975984 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:2 vc:0 status:0x00000001
kworker/4:1-11285 [004] .... 1200.321943: rtcpu_nvcsi_intr: tstamp:38281976666 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321943: rtcpu_nvcsi_intr: tstamp:38281976666 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321944: rtcpu_vinotify_error: tstamp:38281977811 cch:-1 vi:1 tag:CSIMUX_STREAM channel:0x00 frame:32 vi_tstamp:1225023144768 data:0x0000000000000100
kworker/4:1-11285 [004] .... 1200.321944: rtcpu_nvcsi_intr: tstamp:38281977313 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321945: rtcpu_nvcsi_intr: tstamp:38281977313 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
kworker/4:1-11285 [004] .... 1200.321945: rtcpu_nvcsi_intr: tstamp:38281977951 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:2 status:0x0000000a
