• Hardware: T4
• Network Type: Detectnet_v2
• TLT Version
• Training spec file
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: “/shared/users/3ce93a7c-0889-537e-8991-7d76b64a7194/datasets/c71df972-db7b-45af-ae21-976bf2c34d8d/tfrecords/"
image_directory_path: “/shared/users/3ce93a7c-0889-537e-8991-7d76b64a7194/datasets/c71df972-db7b-45af-ae21-976bf2c34d8d/”
image_extension: “jpg”
target_class_mapping {
key: “face”
value: “face”
key: “person”
value: “person”
validation_data_source {
tfrecords_path: "/shared/users/3ce93a7c-0889-537e-8991-7d76b64a7194/datasets/84096349-00b9-4ab5-93cc-3edcb12dda4d/tfrecords/”
image_directory_path: “/shared/users/3ce93a7c-0889-537e-8991-7d76b64a7194/datasets/84096349-00b9-4ab5-93cc-3edcb12dda4d/”
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298023224
contrast_scale_max: 0.10000000149011612
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: “face”
value {
clustering_config {
coverage_threshold: 0.007499999832361937
minimum_bounding_box_height: 20
dbscan_eps: 0.23000000417232513
dbscan_min_samples: 1
dbscan_confidence_threshold: 0.7200000286102295
nms_iou_threshold: 0.20000000298023224
key: “person”
value {
clustering_config {
dbscan_confidence_threshold: 0.10000000149011612
model_config {
pretrained_model_file: “/shared/users/3ce93a7c-0889-537e-8991-7d76b64a7194/models/0870c02c-f79d-4bad-bf92-3a1a5f77d464/peoplenet_vtrainable_v2.6/resnet34_peoplenet.tlt”
num_layers: 34
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
freeze_blocks: 0.0
freeze_blocks: 1.0
freeze_blocks: 2.0
freeze_blocks: 3.0
freeze_blocks: 4.0
arch: “resnet”
evaluation_config {
validation_period_during_training: 1
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: “face”
value: 0.5
key: “person”
value: 0.5
evaluation_box_config {
key: “face”
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: “person”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
cost_function_config {
target_classes {
class_weight: 4.0
coverage_foreground_weight: 0.05000000074505806
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.9998999834060669
min_objective_weight: 9.999999747378752e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 100
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 3.5999998999614036e-06
max_learning_rate: 0.0005000000237487257
soft_start: 1.0000000116860974e-07
annealing: 1.0000000116860974e-07
regularizer {
type: L2
weight: 3.000000026176508e-09
optimizer {
adam {
epsilon: 9.99999993922529e-09
beta1: 0.8999999761581421
beta2: 0.9990000128746033
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 1
visualizer {
num_images: 3
infrequent_logging_frequency: 5
bbox_rasterizer_config {
key: “face”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
bbox_min_radius: 1.0
key: “person”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.4000000059604645
Results logs:
2024-03-20 12:32:35,976 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2c_bn_2 weights set from pre-trained model.
2024-03-20 12:32:35,977 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_6 weights set from pre-trained model.
2024-03-20 12:32:35,977 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2c_relu weights set from pre-trained model.
2024-03-20 12:32:36,451 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_conv_1 weights set from pre-trained model.
2024-03-20 12:32:36,934 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_bn_1 weights set from pre-trained model.
2024-03-20 12:32:36,935 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_relu_1 weights set from pre-trained model.
2024-03-20 12:32:37,405 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_conv_2 weights set from pre-trained model.
2024-03-20 12:32:37,882 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_bn_2 weights set from pre-trained model.
2024-03-20 12:32:37,882 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_7 weights set from pre-trained model.
2024-03-20 12:32:37,882 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_2d_relu weights set from pre-trained model.
2024-03-20 12:32:38,361 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_conv_1 weights set from pre-trained model.
2024-03-20 12:32:38,845 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_bn_1 weights set from pre-trained model.
2024-03-20 12:32:38,845 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_relu_1 weights set from pre-trained model.
2024-03-20 12:32:39,325 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_conv_2 weights set from pre-trained model.
2024-03-20 12:32:39,792 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_conv_shortcut weights set from pre-trained model.
2024-03-20 12:32:40,282 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_bn_2 weights set from pre-trained model.
2024-03-20 12:32:40,765 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_bn_shortcut weights set from pre-trained model.
2024-03-20 12:32:40,765 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_8 weights set from pre-trained model.
2024-03-20 12:32:40,765 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3a_relu weights set from pre-trained model.
2024-03-20 12:32:41,240 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_conv_1 weights set from pre-trained model.
2024-03-20 12:32:41,722 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_bn_1 weights set from pre-trained model.
2024-03-20 12:32:41,722 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_relu_1 weights set from pre-trained model.
2024-03-20 12:32:42,202 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_conv_2 weights set from pre-trained model.
2024-03-20 12:32:42,682 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_bn_2 weights set from pre-trained model.
2024-03-20 12:32:42,682 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_9 weights set from pre-trained model.
2024-03-20 12:32:42,682 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3b_relu weights set from pre-trained model.
2024-03-20 12:32:43,166 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_conv_1 weights set from pre-trained model.
2024-03-20 12:32:43,649 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_bn_1 weights set from pre-trained model.
2024-03-20 12:32:43,649 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_relu_1 weights set from pre-trained model.
2024-03-20 12:32:44,133 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_conv_2 weights set from pre-trained model.
2024-03-20 12:32:44,624 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_bn_2 weights set from pre-trained model.
2024-03-20 12:32:44,624 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_10 weights set from pre-trained model.
2024-03-20 12:32:44,624 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3c_relu weights set from pre-trained model.
2024-03-20 12:32:45,106 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_conv_1 weights set from pre-trained model.
2024-03-20 12:32:45,614 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_bn_1 weights set from pre-trained model.
2024-03-20 12:32:45,614 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_relu_1 weights set from pre-trained model.
2024-03-20 12:32:46,104 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_conv_2 weights set from pre-trained model.
2024-03-20 12:32:46,593 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_bn_2 weights set from pre-trained model.
2024-03-20 12:32:46,593 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_11 weights set from pre-trained model.
2024-03-20 12:32:46,594 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3d_relu weights set from pre-trained model.
2024-03-20 12:32:47,080 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_conv_1 weights set from pre-trained model.
2024-03-20 12:32:47,566 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_bn_1 weights set from pre-trained model.
2024-03-20 12:32:47,566 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_relu_1 weights set from pre-trained model.
2024-03-20 12:32:48,051 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_conv_2 weights set from pre-trained model.
2024-03-20 12:32:48,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_bn_2 weights set from pre-trained model.
2024-03-20 12:32:48,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_12 weights set from pre-trained model.
2024-03-20 12:32:48,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3e_relu weights set from pre-trained model.
2024-03-20 12:32:49,038 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_conv_1 weights set from pre-trained model.
2024-03-20 12:32:49,527 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_bn_1 weights set from pre-trained model.
2024-03-20 12:32:49,527 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_relu_1 weights set from pre-trained model.
2024-03-20 12:32:50,010 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_conv_2 weights set from pre-trained model.
2024-03-20 12:32:50,510 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_bn_2 weights set from pre-trained model.
2024-03-20 12:32:50,510 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_13 weights set from pre-trained model.
2024-03-20 12:32:50,510 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_3f_relu weights set from pre-trained model.
2024-03-20 12:32:51,007 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_conv_1 weights set from pre-trained model.
2024-03-20 12:32:51,518 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_bn_1 weights set from pre-trained model.
2024-03-20 12:32:51,518 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_relu_1 weights set from pre-trained model.
2024-03-20 12:32:52,013 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_conv_2 weights set from pre-trained model.
2024-03-20 12:32:52,509 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_conv_shortcut weights set from pre-trained model.
2024-03-20 12:32:53,014 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_bn_2 weights set from pre-trained model.
2024-03-20 12:32:53,519 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_bn_shortcut weights set from pre-trained model.
2024-03-20 12:32:53,519 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_14 weights set from pre-trained model.
2024-03-20 12:32:53,519 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4a_relu weights set from pre-trained model.
2024-03-20 12:32:54,015 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_conv_1 weights set from pre-trained model.
2024-03-20 12:32:54,521 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_bn_1 weights set from pre-trained model.
2024-03-20 12:32:54,521 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_relu_1 weights set from pre-trained model.
2024-03-20 12:32:55,021 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_conv_2 weights set from pre-trained model.
2024-03-20 12:32:55,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_bn_2 weights set from pre-trained model.
2024-03-20 12:32:55,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_15 weights set from pre-trained model.
2024-03-20 12:32:55,544 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4b_relu weights set from pre-trained model.
2024-03-20 12:32:56,056 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_conv_1 weights set from pre-trained model.
2024-03-20 12:32:56,561 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_bn_1 weights set from pre-trained model.
2024-03-20 12:32:56,561 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_relu_1 weights set from pre-trained model.
2024-03-20 12:32:57,069 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_conv_2 weights set from pre-trained model.
2024-03-20 12:32:57,566 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_bn_2 weights set from pre-trained model.
2024-03-20 12:32:57,566 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer add_16 weights set from pre-trained model.
2024-03-20 12:32:57,566 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.model.detectnet_model 142: Layer block_4c_relu weights set from pre-trained model.
2024-03-20 12:32:57,700 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.objectives.bbox_objective 78: Default L1 loss function will be used.
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 544, 960) 0
conv1 (Conv2D) (None, 64, 272, 480) 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 272, 480) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 272, 480) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 136, 240) 36928 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 136, 240) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 136, 240) 36928 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 136, 240) 4160 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 136, 240) 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 136, 240) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 136, 240) 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 136, 240) 36928 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 136, 240) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 136, 240) 36928 block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_2[0][0]
add_2 (Add) (None, 64, 136, 240) 0 block_1b_bn_2[0][0]
block_1a_relu[0][0]
block_1b_relu (Activation) (None, 64, 136, 240) 0 add_2[0][0]
block_1c_conv_1 (Conv2D) (None, 64, 136, 240) 36928 block_1b_relu[0][0]
block_1c_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1c_conv_1[0][0]
block_1c_relu_1 (Activation) (None, 64, 136, 240) 0 block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D) (None, 64, 136, 240) 36928 block_1c_relu_1[0][0]
block_1c_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1c_conv_2[0][0]
add_3 (Add) (None, 64, 136, 240) 0 block_1c_bn_2[0][0]
block_1b_relu[0][0]
block_1c_relu (Activation) (None, 64, 136, 240) 0 add_3[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 68, 120) 73856 block_1c_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 68, 120) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 68, 120) 8320 block_1c_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 68, 120) 512 block_2a_conv_shortcut[0][0]
add_4 (Add) (None, 128, 68, 120) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 68, 120) 0 add_4[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 68, 120) 147584 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 68, 120) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_2[0][0]
add_5 (Add) (None, 128, 68, 120) 0 block_2b_bn_2[0][0]
block_2a_relu[0][0]
block_2b_relu (Activation) (None, 128, 68, 120) 0 add_5[0][0]
block_2c_conv_1 (Conv2D) (None, 128, 68, 120) 147584 block_2b_relu[0][0]
block_2c_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2c_conv_1[0][0]
block_2c_relu_1 (Activation) (None, 128, 68, 120) 0 block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2c_relu_1[0][0]
block_2c_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2c_conv_2[0][0]
add_6 (Add) (None, 128, 68, 120) 0 block_2c_bn_2[0][0]
block_2b_relu[0][0]
block_2c_relu (Activation) (None, 128, 68, 120) 0 add_6[0][0]
block_2d_conv_1 (Conv2D) (None, 128, 68, 120) 147584 block_2c_relu[0][0]
block_2d_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2d_conv_1[0][0]
block_2d_relu_1 (Activation) (None, 128, 68, 120) 0 block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2d_relu_1[0][0]
block_2d_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2d_conv_2[0][0]
add_7 (Add) (None, 128, 68, 120) 0 block_2d_bn_2[0][0]
block_2c_relu[0][0]
block_2d_relu (Activation) (None, 128, 68, 120) 0 add_7[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 34, 60) 295168 block_2d_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 34, 60) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 34, 60) 33024 block_2d_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 34, 60) 1024 block_3a_conv_shortcut[0][0]
add_8 (Add) (None, 256, 34, 60) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 34, 60) 0 add_8[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 34, 60) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_2[0][0]
add_9 (Add) (None, 256, 34, 60) 0 block_3b_bn_2[0][0]
block_3a_relu[0][0]
block_3b_relu (Activation) (None, 256, 34, 60) 0 add_9[0][0]
block_3c_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3b_relu[0][0]
block_3c_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3c_conv_1[0][0]
block_3c_relu_1 (Activation) (None, 256, 34, 60) 0 block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3c_relu_1[0][0]
block_3c_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3c_conv_2[0][0]
add_10 (Add) (None, 256, 34, 60) 0 block_3c_bn_2[0][0]
block_3b_relu[0][0]
block_3c_relu (Activation) (None, 256, 34, 60) 0 add_10[0][0]
block_3d_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3c_relu[0][0]
block_3d_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3d_conv_1[0][0]
block_3d_relu_1 (Activation) (None, 256, 34, 60) 0 block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3d_relu_1[0][0]
block_3d_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3d_conv_2[0][0]
add_11 (Add) (None, 256, 34, 60) 0 block_3d_bn_2[0][0]
block_3c_relu[0][0]
block_3d_relu (Activation) (None, 256, 34, 60) 0 add_11[0][0]
block_3e_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3d_relu[0][0]
block_3e_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3e_conv_1[0][0]
block_3e_relu_1 (Activation) (None, 256, 34, 60) 0 block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3e_relu_1[0][0]
block_3e_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3e_conv_2[0][0]
add_12 (Add) (None, 256, 34, 60) 0 block_3e_bn_2[0][0]
block_3d_relu[0][0]
block_3e_relu (Activation) (None, 256, 34, 60) 0 add_12[0][0]
block_3f_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3e_relu[0][0]
block_3f_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3f_conv_1[0][0]
block_3f_relu_1 (Activation) (None, 256, 34, 60) 0 block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3f_relu_1[0][0]
block_3f_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3f_conv_2[0][0]
add_13 (Add) (None, 256, 34, 60) 0 block_3f_bn_2[0][0]
block_3e_relu[0][0]
block_3f_relu (Activation) (None, 256, 34, 60) 0 add_13[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 34, 60) 1180160 block_3f_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 34, 60) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 34, 60) 2359808 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 34, 60) 131584 block_3f_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 34, 60) 2048 block_4a_conv_shortcut[0][0]
add_14 (Add) (None, 512, 34, 60) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 34, 60) 0 add_14[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 34, 60) 2359808 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 34, 60) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 34, 60) 2359808 block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_2[0][0]
2024-03-20 12:32:57,725 [TAO Toolkit] [INFO] root 2102: DetectNet V2 model built.
2024-03-20 12:32:57,725 [TAO Toolkit] [INFO] root 2102: Building rasterizer.
2024-03-20 12:32:57,726 [TAO Toolkit] [INFO] root 2102: Rasterizers built.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/training_proto_utilities.py:102: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
2024-03-20 12:32:57,726 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/training_proto_utilities.py:102: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/train.py:718: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
2024-03-20 12:32:57,741 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/train.py:718: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
2024-03-20 12:32:57,742 [TAO Toolkit] [INFO] root 2102: Building training graph.
2024-03-20 12:32:57,744 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 175: Serial augmentation enabled = False
2024-03-20 12:32:57,744 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 177: Pseudo sharding enabled = False
2024-03-20 12:32:57,744 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 269: Max Image Dimensions (all sources): (0, 0)
2024-03-20 12:32:57,744 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 380: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2024-03-20 12:32:57,744 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 387: total dataset size 3799, number of sources: 1, batch size per gpu: 4, steps: 950
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2024-03-20 12:32:57,784 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2024-03-20 12:32:59,766 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.dataloader.default_dataloader 546: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2024-03-20 12:33:02,487 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 409: shuffle: True - shard 0 of 1
2024-03-20 12:33:02,491 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 479: sampling 1 datasets with weights:
2024-03-20 12:33:02,491 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 481: source: 0 weight: 1.000000
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.image.resize_images is deprecated. Please use tf.image.resize instead.
2024-03-20 12:33:03,254 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.image.resize_images is deprecated. Please use tf.image.resize instead.
2024-03-20 12:33:04,034 [TAO Toolkit] [INFO] main 536: Found 3799 samples in training set
2024-03-20 12:33:04,035 [TAO Toolkit] [INFO] root 2102: Rasterizing tensors.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/rasterizers/bbox_rasterizer.py:348: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
2024-03-20 12:33:04,136 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/rasterizers/bbox_rasterizer.py:348: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
2024-03-20 12:33:04,249 [TAO Toolkit] [INFO] root 2102: Tensors rasterized.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/training_proto_utilities.py:49: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
2024-03-20 12:33:04,249 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/training_proto_utilities.py:49: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/cost_function/cost_functions.py:29: The name tf.log is deprecated. Please use tf.math.log instead.
2024-03-20 12:33:04,500 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/cost_function/cost_functions.py:29: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/cost_function/cost_auto_weight_hook.py:250: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2024-03-20 12:33:04,524 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/cost_function/cost_auto_weight_hook.py:250: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2024-03-20 12:33:05,958 [TAO Toolkit] [INFO] root 2102: Training graph built.
2024-03-20 12:33:05,958 [TAO Toolkit] [INFO] root 2102: Building validation graph.
2024-03-20 12:33:05,959 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 175: Serial augmentation enabled = False
2024-03-20 12:33:05,959 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 177: Pseudo sharding enabled = False
2024-03-20 12:33:05,959 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 269: Max Image Dimensions (all sources): (0, 0)
2024-03-20 12:33:05,959 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 380: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2024-03-20 12:33:05,959 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 387: total dataset size 898, number of sources: 1, batch size per gpu: 4, steps: 225
2024-03-20 12:33:05,989 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.dataloader.default_dataloader 546: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2024-03-20 12:33:06,232 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 409: shuffle: False - shard 0 of 1
2024-03-20 12:33:06,236 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 479: sampling 1 datasets with weights:
2024-03-20 12:33:06,236 [TAO Toolkit] [INFO] nvidia_tao_tf1.blocks.multi_source_loader.data_loader 481: source: 0 weight: 1.000000
2024-03-20 12:33:06,476 [TAO Toolkit] [INFO] main 591: Found 898 samples in validation set
2024-03-20 12:33:06,476 [TAO Toolkit] [INFO] root 2102: Rasterizing tensors.
2024-03-20 12:33:06,683 [TAO Toolkit] [INFO] root 2102: Tensors rasterized.
2024-03-20 12:33:07,324 [TAO Toolkit] [INFO] root 2102: Validation graph built.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/tfhooks/validation_hook.py:58: The name tf.summary.FileWriterCache is deprecated. Please use tf.compat.v1.summary.FileWriterCache instead.
2024-03-20 12:33:07,325 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/tfhooks/validation_hook.py:58: The name tf.summary.FileWriterCache is deprecated. Please use tf.compat.v1.summary.FileWriterCache instead.
2024-03-20 12:33:08,825 [TAO Toolkit] [INFO] root 2102: Running training loop.
2024-03-20 12:33:08,825 [TAO Toolkit] [INFO] main 135: Checkpoint interval: 1
2024-03-20 12:33:08,825 [TAO Toolkit] [INFO] main 175: Scalars logged at every 95 steps
2024-03-20 12:33:08,826 [TAO Toolkit] [INFO] main 180: Images logged at every 0 steps
INFO:tensorflow:Create CheckpointSaverHook.
2024-03-20 12:33:08,828 [TAO Toolkit] [INFO] tensorflow 541: Create CheckpointSaverHook.
WARNING:tensorflow:From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/utilities.py:154: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
2024-03-20 12:33:08,830 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/training/utilities.py:154: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
INFO:tensorflow:Graph was finalized.
2024-03-20 12:33:11,750 [TAO Toolkit] [INFO] tensorflow 240: Graph was finalized.
INFO:tensorflow:Running local_init_op.
2024-03-20 12:33:15,183 [TAO Toolkit] [INFO] tensorflow 500: Running local_init_op.
INFO:tensorflow:Done running local_init_op.
2024-03-20 12:33:16,051 [TAO Toolkit] [INFO] tensorflow 502: Done running local_init_op.
INFO:tensorflow:Saving checkpoints for step-0.
2024-03-20 12:33:25,855 [TAO Toolkit] [INFO] tensorflow 81: Saving checkpoints for step-0.
INFO:tensorflow:epoch = 0.0, learning_rate = 1.6191649e-06, loss = 0.11848829, step = 0
2024-03-20 12:34:17,568 [TAO Toolkit] [INFO] tensorflow 262: epoch = 0.0, learning_rate = 1.6191649e-06, loss = 0.11848829, step = 0
2024-03-20 12:34:17,570 [TAO Toolkit] [INFO] root 2102: None
2024-03-20 12:34:17,570 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.tfhooks.task_progress_monitor_hook 149: Epoch 0/50: loss: 0.11849 learning rate: 1.6191649e-06 Time taken: 0:00:00 ETA: 0:00:00
2024-03-20 12:34:17,570 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 0.237
INFO:tensorflow:epoch = 0.002105263157894737, learning_rate = 1.6199589e-06, loss = 0.120211534, step = 2 (6.014 sec)
2024-03-20 12:34:23,582 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.002105263157894737, learning_rate = 1.6199589e-06, loss = 0.120211534, step = 2 (6.014 sec)
INFO:tensorflow:epoch = 0.02526315789473684, learning_rate = 1.628708e-06, loss = 0.11866148, step = 24 (5.432 sec)
2024-03-20 12:34:29,014 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.02526315789473684, learning_rate = 1.628708e-06, loss = 0.11866148, step = 24 (5.432 sec)
2024-03-20 12:34:29,014 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 3.530
INFO:tensorflow:epoch = 0.04842105263157895, learning_rate = 1.6375061e-06, loss = 0.11982238, step = 46 (5.361 sec)
2024-03-20 12:34:34,375 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.04842105263157895, learning_rate = 1.6375061e-06, loss = 0.11982238, step = 46 (5.361 sec)
2024-03-20 12:34:35,085 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 16.471
INFO:tensorflow:epoch = 0.07263157894736842, learning_rate = 1.6467552e-06, loss = 0.11932705, step = 69 (5.445 sec)
2024-03-20 12:34:39,820 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.07263157894736842, learning_rate = 1.6467552e-06, loss = 0.11932705, step = 69 (5.445 sec)
2024-03-20 12:34:41,006 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 16.889
INFO:tensorflow:epoch = 0.0968421052631579, learning_rate = 1.6560549e-06, loss = 0.11662158, step = 92 (5.448 sec)
2024-03-20 12:34:45,268 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.0968421052631579, learning_rate = 1.6560549e-06, loss = 0.11662158, step = 92 (5.448 sec)
INFO:tensorflow:global_step/sec: 3.34396
2024-03-20 12:34:45,979 [TAO Toolkit] [INFO] tensorflow 692: global_step/sec: 3.34396
2024-03-20 12:34:46,928 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 16.890
INFO:tensorflow:epoch = 0.12105263157894737, learning_rate = 1.6654088e-06, loss = 0.1136293, step = 115 (5.455 sec)
2024-03-20 12:34:50,723 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.12105263157894737, learning_rate = 1.6654088e-06, loss = 0.1136293, step = 115 (5.455 sec)
2024-03-20 12:34:52,863 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 16.849
INFO:tensorflow:epoch = 0.14526315789473684, learning_rate = 1.6748138e-06, loss = 0.114168674, step = 138 (5.463 sec)
2024-03-20 12:34:56,186 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.14526315789473684, learning_rate = 1.6748138e-06, loss = 0.114168674, step = 138 (5.463 sec)
2024-03-20 12:38:04,583 [TAO Toolkit] [INFO] nvidia_tao_tf1.core.hooks.sample_counter_hook 76: Train Samples / sec: 16.626
INFO:tensorflow:epoch = 0.9810526315789474, learning_rate = 2.0342488e-06, loss = 0.09080703, step = 932 (5.287 sec)
2024-03-20 12:38:06,502 [TAO Toolkit] [INFO] tensorflow 260: epoch = 0.9810526315789474, learning_rate = 2.0342488e-06, loss = 0.09080703, step = 932 (5.287 sec)
INFO:tensorflow:Saving checkpoints for step-950.
2024-03-20 12:38:10,589 [TAO Toolkit] [INFO] tensorflow 81: Saving checkpoints for step-950.
2024-03-20 12:38:14,192 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 0 / 224, 0.00s/step
2024-03-20 12:38:25,496 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 10 / 224, 1.13s/step
2024-03-20 12:38:35,179 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 20 / 224, 0.97s/step
2024-03-20 12:38:44,881 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 30 / 224, 0.97s/step
2024-03-20 12:38:54,526 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 40 / 224, 0.96s/step
2024-03-20 12:39:04,197 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 50 / 224, 0.97s/step
2024-03-20 12:39:14,048 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 60 / 224, 0.99s/step
2024-03-20 12:39:23,754 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 70 / 224, 0.97s/step
2024-03-20 12:39:33,639 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 80 / 224, 0.99s/step
2024-03-20 12:39:43,352 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 90 / 224, 0.97s/step
2024-03-20 12:39:53,099 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 100 / 224, 0.97s/step
2024-03-20 12:40:02,808 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 110 / 224, 0.97s/step
2024-03-20 12:40:12,443 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 120 / 224, 0.96s/step
2024-03-20 12:40:22,069 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 130 / 224, 0.96s/step
2024-03-20 12:40:31,620 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 140 / 224, 0.96s/step
2024-03-20 12:40:41,173 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 150 / 224, 0.96s/step
2024-03-20 12:40:50,750 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 160 / 224, 0.96s/step
2024-03-20 12:41:00,370 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 170 / 224, 0.96s/step
2024-03-20 12:41:10,069 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 180 / 224, 0.97s/step
2024-03-20 12:41:19,690 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 190 / 224, 0.96s/step
2024-03-20 12:41:29,325 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 200 / 224, 0.96s/step
2024-03-20 12:41:38,933 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 210 / 224, 0.96s/step
2024-03-20 12:41:48,513 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.detectnet_v2.evaluation.evaluation 130: step 220 / 224, 0.96s/step
add_15 (Add) (None, 512, 34, 60) 0 block_4b_bn_2[0][0]
block_4a_relu[0][0]
block_4b_relu (Activation) (None, 512, 34, 60) 0 add_15[0][0]
block_4c_conv_1 (Conv2D) (None, 512, 34, 60) 2359808 block_4b_relu[0][0]
block_4c_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4c_conv_1[0][0]
block_4c_relu_1 (Activation) (None, 512, 34, 60) 0 block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D) (None, 512, 34, 60) 2359808 block_4c_relu_1[0][0]
block_4c_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4c_conv_2[0][0]
add_16 (Add) (None, 512, 34, 60) 0 block_4c_bn_2[0][0]
block_4b_relu[0][0]
block_4c_relu (Activation) (None, 512, 34, 60) 0 add_16[0][0]
output_bbox (Conv2D) (None, 8, 34, 60) 4104 block_4c_relu[0][0]
output_cov (Conv2D) (None, 2, 34, 60) 1026 block_4c_relu[0][0]
Total params: 21,319,754
Trainable params: 22,282
Non-trainable params: 21,297,472
Matching predictions to ground truth, class 1/2.: 100%|██████████| 13152/13152 [00:00<00:00, 15996.90it/s]
Matching predictions to ground truth, class 2/2.: 100%|██████████| 461/461 [00:00<00:00, 36889.71it/s]2024-03-20 12:41:53,472 [TAO Toolkit] [INFO] root 2102: Evaluation metrics generated.
Epoch 1/50
Validation cost: 0.001752
Mean average_precision (in %): 0.0265
| class name | average precision (in %) |
| face | 0.0 |
| person | 0.05305001756385717 |
