The PCIE device cannot be identified. Procedure
I have a device with PCIE interface. After I load it to Xavier, it is wrong. I am using “lspci-vvv” to check the PCIE card status, and the two bar space addresses are not allocated correctly. unassigned> ".
I’m going to ignore this problem and I’ll compile my source code into a *. Ko file and then apply “insmod” to load the driver.The driver can be loaded properly, but the sample program cannot be run because of the state of the PCIE interface.
I use “dmesg” to see the information that comes with installing the driver. I’ve read “cant’ enable device: Bar 0 [mem 0x00000000-0x000fffff] not claimed”. This is a deadly problem.
The PCIE card chip is SmartFusion2 SoC FPGA PCIe.
Duplicated with The PCIE device cannot be identified. Procedure - Jetson & Embedded Systems / Jetson AGX Xavier - NVIDIA Developer Forums
Sorry, I don’t think I should put this case in the “kernel” category
*******************************************Jetson agx xavier arm64 info
0005:01:00.0 Non-VGA unclassified device: Actel Device 11aa
Subsystem: Actel Device 0000
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 0
Region 0: Memory at (32-bit, non-prefetchable) [disabled] [size=1M]
Region 1: Memory at (32-bit, non-prefetchable) [disabled] [size=64K]
Capabilities:
*******************************************X86 info
19:00.0 Non-VGA unclassified device: Actel Device 11aa
Control:I/O0 Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- FastB2B- DisINTx-
Status: Cap+66MHZ- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- SERR- <PERR- INTx-
Latency:0,Cache Line Size:32 bytes
Interrupt:Pin A routed to IRQ 11
NUMA node:0
Region 0:Memroy at b5c00000(32-bit,non-prefetchable) [size=1M]
Region 1:Memroy at b5d00000(32-bit,non-prefetchable) [size=64K]
Capbilities:
Is there a better solution now?
Feel like pcie device driver problem. Maybe dig into driver code and see what goes wrong.
Hi Wayne
I have checked the source code of PCIE device driver. In my opinion, it is not the problem of driver source code, but the incompatibility between ARM platform and “SmartFusion2” device.
I tried Xilinx’s FPGA PCIE device and it works.
