The PTX and SASS codes corresponding to the device code are empty
I have a simple CUDA demo, when I tried to measure kernel execution time using nsys command, I find that the execution of kernel code is independent of the number of loops in the loop body.
My code is as follows :
#include <cuda_runtime.h>
#include <stdio.h>
#include <sys/time.h>
#define BDIMX 32
#define BDIMY 32
__global__ void setRowReadRow(int * out)
    unsigned int idx=threadIdx.y*blockDim.x+threadIdx.x;
    for(unsigned int e=0; e<65536*30000; e++)
    for(unsigned int w=0; w<65536*30000; w++)
    for(unsigned int q=0; q<65536*30000; q++)
    for(unsigned int i=0; i<65535*30000; i++)
    for(unsigned int j=0; j<65535*30000; j++)
    for(unsigned int k=0; k<65536*30000; k++)
    for(unsigned int l=0; l<65535*30000; l++)
    for(unsigned int m=0; m<65536; m++){
      out[idx] +=  m*j   ;
int main(int argc,char **argv)
  int nElem=BDIMX*BDIMY;
  int nBlock=1;
  int nByte=sizeof(int)*nElem*nBlock ;
  int * out = NULL;
  int * host_data = NULL;
  host_data = (int *)malloc(sizeof(int) * nElem);
  cudaMalloc((int**)&out,nByte);
  dim3 block(BDIMY,BDIMX);
  dim3 grid(1);
  setRowReadRow<<<grid,block>>>(out);
  cudaMemcpy(host_data, out, sizeof(int) * nElem,
                             cudaMemcpyDeviceToHost);
  cudaFree(out);
  return 0;
So I tried to get kernel PTX and SASS code,I used the following command to get the PTX and SASS code:
# compile
nvcc demo.cu -arch=sm_80 -o demo
# get ptx code
cuobjdump --dump-ptx ./demo
# get sass code
nvcc demo.cu -arch=sm_80 -c demo.cu
cuobjdump -sass demo.o
PTX code is as follows, only one ret command :
Fatbin elf code:
arch = sm_80
code version = [1,7]
host = linux
compile_size = 64bit
Fatbin elf code:
arch = sm_80
host = linux
Fatbin ptx code:
arch = sm_80
code version = [8,1]
host = linux
compressed
.version 8.1
.target sm_80
.address_size 64
.visible .entry _Z13setRowReadRowPi(
.param .u64 _Z13setRowReadRowPi_param_0
ret;
SASS code is as follows:
Fatbin elf code:
arch = sm_80
host = linux
        code for sm_80
                Function : _Z13setRowReadRowPi
        .headerflags    @"EF_CUDA_TEXMODE_UNIFIED EF_CUDA_64BIT_ADDRESS EF_CUDA_SM80 EF_CUDA_VIRTUAL_SM(EF_CUDA_SM80)"
        /*0000*/                   MOV R1, c[0x0][0x28] ;  /* 0x00000a0000017a02 */
                                                           /* 0x000fc40000000f00 */
        /*0010*/                   EXIT ;                  /* 0x000000000000794d */
                                                           /* 0x000fea0003800000 */
        /*0020*/                   BRA 0x20;               /* 0xfffffff000007947 */
                                                           /* 0x000fc0000383ffff */
        /*0030*/                   NOP;                    /* 0x0000000000007918 */
                                                           /* 0x000fc00000000000 */
        /*0040*/                   NOP;                    /* 0x0000000000007918 */
        /*0050*/                   NOP;                    /* 0x0000000000007918 */
        /*0060*/                   NOP;                    /* 0x0000000000007918 */
        /*0070*/                   NOP;                    /* 0x0000000000007918 */
        /*0080*/                   NOP;                    /* 0x0000000000007918 */
        /*0090*/                   NOP;                    /* 0x0000000000007918 */
        /*00a0*/                   NOP;                    /* 0x0000000000007918 */
        /*00b0*/                   NOP;                    /* 0x0000000000007918 */
So my question is why is this PTX and SASS code empty? My GPU is A800, OS is Ubuntu20.04.
In C++ overflow of a signed integer is undefined behavior. Reducing the for loop nesting and iteration per loop it can be observed that the compiler reduces the loops to a constant value. When the constant exceed MAX_INT the kernel becomes a NOP kernel. It is very quick to test this in godbolt.org using CUDA C++ compiler.
Thank you for your answer, but I have a new problem.
I made some changes to the kernel code as follows:
    for(unsigned int j=0; j<65536; j++)
            out[idx] +=  m ;
The representation range of the int data type is [-2^31, 2^32-1],and 65536*65536=2^32, Obviously the above kerenl code will overflow.
However in godbolt.org the corresponding ptx code is as follows:
.visible .entry setRowReadRow(int*)(
        .param .u64 setRowReadRow(int*)_param_0
        ld.param.u64    %rd1, [setRowReadRow(int*)_param_0];
        cvta.to.global.u64      %rd2, %rd1;
        mov.u32         %r1, %tid.y;
        mov.u32         %r2, %ntid.x;
        mov.u32         %r3, %tid.x;
        mad.lo.s32      %r4, %r1, %r2, %r3;
        mul.wide.u32    %rd3, %r4, 4;
        add.s64         %rd4, %rd2, %rd3;
        ld.global.u32   %r5, [%rd4];
        xor.b32         %r6, %r5, -2147483648;
        st.global.u32   [%rd4], %r6;
        ret;
So my new question is why the PTX code not empty in the case of this overflow.
As stated above:
Undefined behavior (UB) means just that: the behavior is undefined, anything can happen. In ancient programmer folklore this includes the possibility of nasal demons. When UB is present it makes no sense to try and analyze a compiler’s response.
