Identifier "__HALF2_TO_UI" is undefined when using asm for cuda
Hi Forum,
I am trying to use asm code to implement ldg128 and stg128 for cuda global memory access, and here is my main code for this part:
__device__ __forceinline__ void ldg128(const __half2* addr, __half2 &reg0, __half2 &reg1, __half2 &reg2, __half2 &reg3){
    asm volatile(
        "ld.global.nc.v4.b32 {%1, %2, %3, %4}, [%0];\n"
        : "=r"(__HALF2_TO_UI(reg0)),
          "=r"(__HALF2_TO_UI(reg1)),
          "=r"(__HALF2_TO_UI(reg2)),
          "=r"(__HALF2_TO_UI(reg3))
        : "l"(addr)
__device__ __forceinline__ void stg128(__half2* addr, __half2 &reg0, __half2 &reg1, __half2 &reg2, __half2 &reg3) {
    asm volatile(
        "st.global.v4.b32 [%0], {%1, %2, %3, %4};\n"
        : "l"(addr),
          "r"(__HALF2_TO_UI(reg0)),
          "r"(__HALF2_TO_UI(reg1)),
          "r"(__HALF2_TO_UI(reg2)),
          "r"(__HALF2_TO_UI(reg3))
To compile, I have included
#include <cuda.h>
#include <cuda_runtime.h>
#include <cuda_fp16.h>
#include <cuda_fp16.hpp>
and add my cuda arch in the Cmake (so functions like __hfma. __hfma2 works fine). When I want to compile the code above, an error occured saying:
common.cu(41): error: identifier "__HALF2_TO_UI" is undefined
common.cu(41): error: an asm operand must have scalar type
common.cu(42): error: an asm operand must have scalar type
common.cu(43): error: an asm operand must have scalar type
common.cu(44): error: an asm operand must have scalar type
May I know where did I do wrong? I cat the /usr/local/cuda/include/cuda_fp16.hpp and found the definition of __HALF2_TO_UI, but seems that the code cannot find that…
Thank you for your help!
Chengzhe
That macro is not usable in PTX assembly. The header file you reference is for CUDA C++, not PTX.
Why not just do this operation in CUDA C++?
Oh I see… how I could include PTX?
I am learning how to use those macros lol, the code is from a former working project, and I try to learn how to utilize the vector ldg/stgs
The first version of my code is using __ldg()s, and trying to play around vector ldg
these are 32-bit registers. How about just using the variable itself?
instead of:
do:
 "=r"(reg0),
according to my testing, that compiles cleanly for me
Thank you!
I change my code to
    asm volatile(
        : "=r"(reg0),
          "=r"(reg1),
          "=r"(reg2),
          "=r"(reg3)
        : "l"(addr)
    asm volatile(
        : "l"(addr),
          "r"(reg0),
          "r"(reg1),
          "r"(reg2),
          "r"(reg3)
but it says that error: an asm operand must have scalar type. Do you know what does that means?
Which CUDA version are you using? Please switch to CUDA 12.2 or newer.
Oh, it’s cuda_11.4.r11.4… Got it, I will install CUDA 12.2! Thank you!!
// btw do we have some cuda 12.2 based dockers for orin developer kit lol?
cancel that, I made a mistake.
you mean about the cuda version12.2? lol
This seems to work:
# cat t63.cu
    unsigned reg0u, reg1u, reg2u, reg3u;
    asm volatile(
        "ld.global.nc.v4.b32 {%0, %1, %2, %3}, [%4];\n"
        : "=r"(reg0u),
          "=r"(reg1u),
          "=r"(reg2u),
          "=r"(reg3u)
        : "l"(addr)
    reg0 = *(reinterpret_cast<__half2 *>(&reg0u));
    reg1 = *(reinterpret_cast<__half2 *>(&reg1u));
    reg2 = *(reinterpret_cast<__half2 *>(&reg2u));
    reg3 = *(reinterpret_cast<__half2 *>(&reg3u));
__global__ void k(__half2* a, __half2 *b){
        __half2 reg0, reg1, reg2, reg3;
        ldg128(a, reg0, reg1, reg2, reg3);
        b[0] = reg0;
        b[1] = reg1;
        b[2] = reg2;
        b[3] = reg3;
int main(){
  __half2 *a = NULL;
  k<<<1,1>>>(a, a);
  cudaDeviceSynchronize();
# nvcc t63.cu -o t63
# cuobjdump -sass ./t63
Fatbin elf code:
arch = sm_52
code version = [1,7]
host = linux
compile_size = 64bit
        code for sm_52
Fatbin elf code:
arch = sm_52
host = linux
        code for sm_52
                Function : _Z1kP7__half2S0_
        .headerflags    @"EF_CUDA_TEXMODE_UNIFIED EF_CUDA_64BIT_ADDRESS EF_CUDA_SM52 EF_CUDA_VIRTUAL_SM(EF_CUDA_SM52)"
                                                              /* 0x001fc800fe2007f6 */
        /*0008*/                   MOV R1, c[0x0][0x20] ;     /* 0x4c98078000870001 */
        /*0010*/                   MOV R2, c[0x0][0x140] ;    /* 0x4c98078005070002 */
        /*0018*/                   MOV R3, c[0x0][0x144] ;    /* 0x4c98078005170003 */
                                                              /* 0x001fc800fe2007b1 */
        /*0028*/                   LDG.E.CI.U.128 R8, [R2] ;  /* 0xeed7a00000070208 */
        /*0030*/                   MOV R4, c[0x0][0x148] ;    /* 0x4c98078005270004 */
        /*0038*/                   MOV R5, c[0x0][0x14c] ;    /* 0x4c98078005370005 */
                                                              /* 0x001fc400fe2107f1 */
        /*0048*/                   STG.E [R4], R8 ;           /* 0xeedc200000070408 */
        /*0050*/                   STG.E [R4+0x4], R9 ;       /* 0xeedc200000470409 */
        /*0058*/                   STG.E [R4+0x8], R10 ;      /* 0xeedc20000087040a */
                                                              /* 0x001fbc00fde007f1 */
        /*0068*/                   STG.E [R4+0xc], R11 ;      /* 0xeedc200000c7040b */
        /*0070*/                   NOP ;                      /* 0x50b0000000070f00 */
        /*0078*/                   NOP ;                      /* 0x50b0000000070f00 */
                                                              /* 0x001ffc00ffe007e2 */
        /*0088*/                   NOP ;                      /* 0x50b0000000070f00 */
        /*0090*/                   EXIT ;                     /* 0xe30000000007000f */
        /*0098*/                   BRA 0x98 ;                 /* 0xe2400fffff87000f */
                                                              /* 0x001f8000fc0007e0 */
        /*00a8*/                   NOP;                       /* 0x50b0000000070f00 */
        /*00b0*/                   NOP;                       /* 0x50b0000000070f00 */
        /*00b8*/                   NOP;                       /* 0x50b0000000070f00 */
Fatbin ptx code:
arch = sm_52
code version = [8,2]
host = linux
compressed
You can see in the compiled code there aren’t any extra instructions.
Thank you! I will try it!
So it seems that we need to pass registers as unsigned ints into the asm function, either use __HALF2_TO_UI or use reinterpret_cast to convert __half2, right?
I haven’t studied __HALF2_TO_UI
btw is the cuobjdump converting c to sass? can it do PTX? super cool tools!
__HALF2_TO_UI is not in cuda_fp16.h, it is in cuda_fp16.hpp
I took a look in that file, and it seems to be doing what I did:
#define __HALF2_TO_UI(var) *(reinterpret_cast<unsigned int *>(&(var)))
The CUDA documentation is here. cuobjdump is part of the binary utilities, look for “CUDA Binary Utilities” on the left, and click on it.
That’s really awesome. Thank you so much!
This is how I would do the same thing using CUDA C++. I don’t see a need to use inline PTX for this.
# cat t63.cu
    const int4 val = __ldg(reinterpret_cast<const int4 *>(addr));
    reg0 = *(reinterpret_cast<const __half2 *>(&val.x));
    reg1 = *(reinterpret_cast<const __half2 *>(&val.y));
    reg2 = *(reinterpret_cast<const __half2 *>(&val.z));
    reg3 = *(reinterpret_cast<const __half2 *>(&val.w));
        b[0] = reg0;
        b[1] = reg1;
        b[2] = reg2;
        b[3] = reg3;
int main(){
  __half2 *a = NULL;
  k<<<1,1>>>(a, a);
Fatbin elf code:
arch = sm_52
host = linux
        code for sm_52
Fatbin elf code:
arch = sm_52
host = linux
        code for sm_52
Fatbin ptx code:
arch = sm_52
host = linux
compressed
This of course requires the __half pointer to be properly aligned for a 128 bit load, but the other variants require that also.
Side-remark: My understanding is that bit_cast (new in C++20) is generally preferable to reinterpret_cast, as discussed here, for example:
The CUDA Programming Guide seems to list excluded C++20 features rather than providing a positive list of included features, and I have not yet tried to use it myself.
