SDK version: Tegra_Linux_Sample-Root-Filesystem_R35.3.1_aarch64.tbz2
Connect HDMI, reboot command, the system crashes with error message.
Do you use our Orin Nano carrier board and hit the issue? The reference platform is Orin NX module + Orin Nano carrier board. Not sure if you hit the issue on the setup, or you are using a 3rdparty carrier board.
The carrier board is customized by the company.
Could you help me look into this issue?
This is known issue on rel-35 and won’t fix. Please upgrade to rel-36.4.3.
