The role of nvvidconv and tiler in the code seems to be duplicated
  • deepstream6.1.1
  • on A6000
In the code of deepstream-test3 there is:
  gst_bin_add_many (GST_BIN (pipeline), queue1, pgie, queue2, nvdslogger, tiler,
      queue3, nvvidconv, queue4, nvosd, queue5, sink, NULL);
    /* we link the elements together
    * nvstreammux -> nvinfer -> nvdslogger -> nvtiler -> nvvidconv -> nvosd
    * -> video-renderer */
    if (!gst_element_link_many (streammux, queue1, pgie, queue2, nvdslogger, tiler,
          queue3, nvvidconv, queue4, nvosd, queue5, sink, NULL)) {
      g_printerr ("Elements could not be linked. Exiting.\n");
      return -1;
where tiler = gst_element_factory_make (“nvmultistreamtiler”, “nvtiler”).
And I found that the nvmultistreamtiler plugin has converted the gst batch into a gst buffer, but also added nvidconv, this nvidconv is necessary? I test to remove this nvidconv is also possible.
nvvideoconvert’s function is format convert(YUV to RGB, system memory to Nvidia GPU memeory or vice versa) and scaling. There is no conflict between nvmultistreamtiler and nvvideoconvert
But in this deepstream-test3 case code gst_element_link_many, I remove the nvidconv plugin is also working properly, why?
It is because nvdsosd and nveglglessink both support NVMM NV12 format buffers.
