• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hello
i’m trying to mix 3 streams
first stream needs to infer others don’t need
so first stream memory is converted NVMM
but when i mix 3 streams with glvideomixer
first stream does not video! just capture the first frame
other two stream was fine (they were x-raw)
Due to NVMM buffers, gl plugins may not work in DeepStream SDK.
Please share more information about your usecase. Generally we use streammux to bactch sources and send to nvinfer. And use nvmultistreamtiler to tile the sources. What is the purpose of doing inference to one source and two other sources are bypassed?
The layout is not supported in nvmultistreamtiler. You would need to use CPU plugins. Or you may use three nveglglessink to have three windows and put the three windows into the layout.
