The TensorRT engine produces different inference results when loaded using Python compared to C++
Description
I have a regression model that predicts face quality from input images. Initially, I trained the model using PyTorch and exported it to ONNX format. Then, I converted the ONNX model to a TensorRT engine using the provided onnx_to_tensorrt.py script (I also tried using trtexec).
When I load the TensorRT engine in Python (test_trt.py), the output is nearly identical to the ONNX model, with a precision up to three decimal places. However, when I load the same engine in C++ (main.cpp), the output differs slightly. For example, the Python script may output 0.12, while the C++ version gives 0.18 for the same input.
Is this behavior normal, or could there be an issue in my C++ inference code?
Environment
TensorRT Version: 8.5.3.1
GPU Type: NVIDIA GeForce RTX 3060
Nvidia Driver Version: 570.86.15
CUDA Version: 12.1
CUDNN Version: 8.8.1
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8.10
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/deepstream:6.3-gc-triton-devel
Relevant Files
Unfortunately, I’m not able to share the trained model, but I can provide some details (I can send it to private message). The model takes an input with shape 1x3x112x112.
Other files: data_tesnorrt.zip - Google Drive
Reproduce
  1. Run docker
  2. pip install -r requirements.txt
  3. get some tesnorrt engine
  4. change engine path in test_trt.py
  5. python test_trt.py
  6. make
  7. ./test <model_path> in.jpg
We discovered that the mismatch was caused by differences in preprocessing: during training, the model used torchvision transforms and Pillow, while during inference in C++ we used OpenCV for preprocessing. After retraining the model using OpenCV preprocessing in both training and inference, we observed that the results are consistent and match closely.
