Hi @trivedi.nagaraj ,
I could run the trtexec binary with tabby_tiger.data and got below output.
nvidia@tegra-ubuntu:~/siva/sampleUtils$ /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/resnet50/ResNet50.onnx --loadInputs=gpu_0/data_0:tabby_tiger_new.dat --dumpOutput
&&&& RUNNING TensorRT.trtexec [TensorRT v8502] # /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/resnet50/ResNet50.onnx --loadInputs=gpu_0/data_0:tabby_tiger_new.dat --dumpOutput
[01/06/2024-21:17:35] [I] === Model Options ===
[01/06/2024-21:17:35] [I] Format: ONNX
[01/06/2024-21:17:35] [I] Model: /usr/src/tensorrt/data/resnet50/ResNet50.onnx
[01/06/2024-21:17:35] [I] Output:
[01/06/2024-21:17:35] [I] === Build Options ===
[01/06/2024-21:17:35] [I] Max batch: explicit batch
[01/06/2024-21:17:35] [I] Memory Pools: workspace: default, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[01/06/2024-21:17:35] [I] minTiming: 1
[01/06/2024-21:17:35] [I] avgTiming: 8
[01/06/2024-21:17:35] [I] Precision: FP32
[01/06/2024-21:17:35] [I] LayerPrecisions:
[01/06/2024-21:17:35] [I] Calibration:
[01/06/2024-21:17:35] [I] Refit: Disabled
[01/06/2024-21:17:35] [I] Sparsity: Disabled
[01/06/2024-21:17:35] [I] Safe mode: Disabled
[01/06/2024-21:17:35] [I] DirectIO mode: Disabled
[01/06/2024-21:17:35] [I] Restricted mode: Disabled
[01/06/2024-21:17:35] [I] Build only: Disabled
[01/06/2024-21:17:35] [I] Save engine:
[01/06/2024-21:17:35] [I] Load engine:
[01/06/2024-21:17:35] [I] Profiling verbosity: 0
[01/06/2024-21:17:35] [I] Tactic sources: Using default tactic sources
[01/06/2024-21:17:35] [I] timingCacheMode: local
[01/06/2024-21:17:35] [I] timingCacheFile:
[01/06/2024-21:17:35] [I] Heuristic: Disabled
[01/06/2024-21:17:35] [I] Preview Features: Use default preview flags.
[01/06/2024-21:17:35] [I] Input(s)s format: fp32:CHW
[01/06/2024-21:17:35] [I] Output(s)s format: fp32:CHW
[01/06/2024-21:17:35] [I] Input build shapes: model
[01/06/2024-21:17:35] [I] Input calibration shapes: model
[01/06/2024-21:17:35] [I] === System Options ===
[01/06/2024-21:17:35] [I] Device: 0
[01/06/2024-21:17:35] [I] DLACore:
[01/06/2024-21:17:35] [I] Plugins:
[01/06/2024-21:17:35] [I] === Inference Options ===
[01/06/2024-21:17:35] [I] Batch: Explicit
[01/06/2024-21:17:35] [I] Input inference shapes: model
[01/06/2024-21:17:35] [I] Iterations: 10
[01/06/2024-21:17:35] [I] Duration: 3s (+ 200ms warm up)
[01/06/2024-21:17:35] [I] Sleep time: 0ms
[01/06/2024-21:17:35] [I] Idle time: 0ms
[01/06/2024-21:17:35] [I] Streams: 1
[01/06/2024-21:17:35] [I] ExposeDMA: Disabled
[01/06/2024-21:17:35] [I] Data transfers: Enabled
[01/06/2024-21:17:35] [I] Spin-wait: Disabled
[01/06/2024-21:17:35] [I] Multithreading: Disabled
[01/06/2024-21:17:35] [I] CUDA Graph: Disabled
[01/06/2024-21:17:35] [I] Separate profiling: Disabled
[01/06/2024-21:17:35] [I] Time Deserialize: Disabled
[01/06/2024-21:17:35] [I] Time Refit: Disabled
[01/06/2024-21:17:35] [I] NVTX verbosity: 0
[01/06/2024-21:17:35] [I] Persistent Cache Ratio: 0
[01/06/2024-21:17:35] [I] Inputs:
[01/06/2024-21:17:35] [I] gpu_0/data_0<-tabby_tiger_new.dat
[01/06/2024-21:17:35] [I] === Reporting Options ===
[01/06/2024-21:17:35] [I] Verbose: Disabled
[01/06/2024-21:17:35] [I] Averages: 10 inferences
[01/06/2024-21:17:35] [I] Percentiles: 90,95,99
[01/06/2024-21:17:35] [I] Dump refittable layers:Disabled
[01/06/2024-21:17:35] [I] Dump output: Enabled
[01/06/2024-21:17:35] [I] Profile: Disabled
[01/06/2024-21:17:35] [I] Export timing to JSON file:
[01/06/2024-21:17:35] [I] Export output to JSON file:
[01/06/2024-21:17:35] [I] Export profile to JSON file:
[01/06/2024-21:17:35] [I] === Device Information ===
[01/06/2024-21:17:35] [I] Selected Device: Xavier
[01/06/2024-21:17:35] [I] Compute Capability: 7.2
[01/06/2024-21:17:35] [I] SMs: 8
[01/06/2024-21:17:35] [I] Compute Clock Rate: 1.377 GHz
[01/06/2024-21:17:35] [I] Device Global Memory: 31010 MiB
[01/06/2024-21:17:35] [I] Shared Memory per SM: 96 KiB
[01/06/2024-21:17:35] [I] Memory Bus Width: 256 bits (ECC disabled)
[01/06/2024-21:17:35] [I] Memory Clock Rate: 1.377 GHz
[01/06/2024-21:17:35] [I] TensorRT version: 8.5.2
[01/06/2024-21:17:35] [I] [TRT] [MemUsageChange] Init CUDA: CPU +187, GPU +0, now: CPU 216, GPU 7473 (MiB)
[01/06/2024-21:17:37] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +106, GPU +100, now: CPU 344, GPU 7594 (MiB)
[01/06/2024-21:17:37] [I] Start parsing network model
[01/06/2024-21:17:37] [I] [TRT] ----------------------------------------------------------------
[01/06/2024-21:17:37] [I] [TRT] Input filename: /usr/src/tensorrt/data/resnet50/ResNet50.onnx
[01/06/2024-21:17:37] [I] [TRT] ONNX IR version: 0.0.3
[01/06/2024-21:17:37] [I] [TRT] Opset version: 9
[01/06/2024-21:17:37] [I] [TRT] Producer name: onnx-caffe2
[01/06/2024-21:17:37] [I] [TRT] Producer version:
[01/06/2024-21:17:37] [I] [TRT] Domain:
[01/06/2024-21:17:37] [I] [TRT] Model version: 0
[01/06/2024-21:17:37] [I] [TRT] Doc string:
[01/06/2024-21:17:37] [W] [TRT] onnx2trt_utils.cpp:375: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[01/06/2024-21:17:37] [I] Finish parsing network model
[01/06/2024-21:17:37] [I] [TRT] ---------- Layers Running on DLA ----------
[01/06/2024-21:17:37] [I] [TRT] ---------- Layers Running on GPU ----------
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/conv1_1 + node_of_gpu_0/res_conv1_bn_1 + node_of_gpu_0/res_conv1_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] POOLING: node_of_gpu_0/pool1_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_0_branch2a_1 + node_of_gpu_0/res2_0_branch2a_bn_1 + node_of_gpu_0/res2_0_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_0_branch2b_1 + node_of_gpu_0/res2_0_branch2b_bn_1 + node_of_gpu_0/res2_0_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_0_branch1_1 + node_of_gpu_0/res2_0_branch1_bn_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_0_branch2c_1 + node_of_gpu_0/res2_0_branch2c_bn_1 + node_of_gpu_0/res2_0_branch2c_bn_2 + node_of_gpu_0/res2_0_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_1_branch2a_1 + node_of_gpu_0/res2_1_branch2a_bn_1 + node_of_gpu_0/res2_1_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_1_branch2b_1 + node_of_gpu_0/res2_1_branch2b_bn_1 + node_of_gpu_0/res2_1_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_1_branch2c_1 + node_of_gpu_0/res2_1_branch2c_bn_1 + node_of_gpu_0/res2_1_branch2c_bn_2 + node_of_gpu_0/res2_1_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_2_branch2a_1 + node_of_gpu_0/res2_2_branch2a_bn_1 + node_of_gpu_0/res2_2_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_2_branch2b_1 + node_of_gpu_0/res2_2_branch2b_bn_1 + node_of_gpu_0/res2_2_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res2_2_branch2c_1 + node_of_gpu_0/res2_2_branch2c_bn_1 + node_of_gpu_0/res2_2_branch2c_bn_2 + node_of_gpu_0/res2_2_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_0_branch2a_1 + node_of_gpu_0/res3_0_branch2a_bn_1 + node_of_gpu_0/res3_0_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_0_branch2b_1 + node_of_gpu_0/res3_0_branch2b_bn_1 + node_of_gpu_0/res3_0_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_0_branch1_1 + node_of_gpu_0/res3_0_branch1_bn_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_0_branch2c_1 + node_of_gpu_0/res3_0_branch2c_bn_1 + node_of_gpu_0/res3_0_branch2c_bn_2 + node_of_gpu_0/res3_0_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_1_branch2a_1 + node_of_gpu_0/res3_1_branch2a_bn_1 + node_of_gpu_0/res3_1_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_1_branch2b_1 + node_of_gpu_0/res3_1_branch2b_bn_1 + node_of_gpu_0/res3_1_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_1_branch2c_1 + node_of_gpu_0/res3_1_branch2c_bn_1 + node_of_gpu_0/res3_1_branch2c_bn_2 + node_of_gpu_0/res3_1_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_2_branch2a_1 + node_of_gpu_0/res3_2_branch2a_bn_1 + node_of_gpu_0/res3_2_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_2_branch2b_1 + node_of_gpu_0/res3_2_branch2b_bn_1 + node_of_gpu_0/res3_2_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_2_branch2c_1 + node_of_gpu_0/res3_2_branch2c_bn_1 + node_of_gpu_0/res3_2_branch2c_bn_2 + node_of_gpu_0/res3_2_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_3_branch2a_1 + node_of_gpu_0/res3_3_branch2a_bn_1 + node_of_gpu_0/res3_3_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_3_branch2b_1 + node_of_gpu_0/res3_3_branch2b_bn_1 + node_of_gpu_0/res3_3_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res3_3_branch2c_1 + node_of_gpu_0/res3_3_branch2c_bn_1 + node_of_gpu_0/res3_3_branch2c_bn_2 + node_of_gpu_0/res3_3_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_0_branch2a_1 + node_of_gpu_0/res4_0_branch2a_bn_1 + node_of_gpu_0/res4_0_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_0_branch2b_1 + node_of_gpu_0/res4_0_branch2b_bn_1 + node_of_gpu_0/res4_0_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_0_branch1_1 + node_of_gpu_0/res4_0_branch1_bn_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_0_branch2c_1 + node_of_gpu_0/res4_0_branch2c_bn_1 + node_of_gpu_0/res4_0_branch2c_bn_2 + node_of_gpu_0/res4_0_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_1_branch2a_1 + node_of_gpu_0/res4_1_branch2a_bn_1 + node_of_gpu_0/res4_1_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_1_branch2b_1 + node_of_gpu_0/res4_1_branch2b_bn_1 + node_of_gpu_0/res4_1_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_1_branch2c_1 + node_of_gpu_0/res4_1_branch2c_bn_1 + node_of_gpu_0/res4_1_branch2c_bn_2 + node_of_gpu_0/res4_1_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_2_branch2a_1 + node_of_gpu_0/res4_2_branch2a_bn_1 + node_of_gpu_0/res4_2_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_2_branch2b_1 + node_of_gpu_0/res4_2_branch2b_bn_1 + node_of_gpu_0/res4_2_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_2_branch2c_1 + node_of_gpu_0/res4_2_branch2c_bn_1 + node_of_gpu_0/res4_2_branch2c_bn_2 + node_of_gpu_0/res4_2_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_3_branch2a_1 + node_of_gpu_0/res4_3_branch2a_bn_1 + node_of_gpu_0/res4_3_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_3_branch2b_1 + node_of_gpu_0/res4_3_branch2b_bn_1 + node_of_gpu_0/res4_3_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_3_branch2c_1 + node_of_gpu_0/res4_3_branch2c_bn_1 + node_of_gpu_0/res4_3_branch2c_bn_2 + node_of_gpu_0/res4_3_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_4_branch2a_1 + node_of_gpu_0/res4_4_branch2a_bn_1 + node_of_gpu_0/res4_4_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_4_branch2b_1 + node_of_gpu_0/res4_4_branch2b_bn_1 + node_of_gpu_0/res4_4_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_4_branch2c_1 + node_of_gpu_0/res4_4_branch2c_bn_1 + node_of_gpu_0/res4_4_branch2c_bn_2 + node_of_gpu_0/res4_4_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_5_branch2a_1 + node_of_gpu_0/res4_5_branch2a_bn_1 + node_of_gpu_0/res4_5_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_5_branch2b_1 + node_of_gpu_0/res4_5_branch2b_bn_1 + node_of_gpu_0/res4_5_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res4_5_branch2c_1 + node_of_gpu_0/res4_5_branch2c_bn_1 + node_of_gpu_0/res4_5_branch2c_bn_2 + node_of_gpu_0/res4_5_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_0_branch2a_1 + node_of_gpu_0/res5_0_branch2a_bn_1 + node_of_gpu_0/res5_0_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_0_branch2b_1 + node_of_gpu_0/res5_0_branch2b_bn_1 + node_of_gpu_0/res5_0_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_0_branch1_1 + node_of_gpu_0/res5_0_branch1_bn_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_0_branch2c_1 + node_of_gpu_0/res5_0_branch2c_bn_1 + node_of_gpu_0/res5_0_branch2c_bn_2 + node_of_gpu_0/res5_0_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_1_branch2a_1 + node_of_gpu_0/res5_1_branch2a_bn_1 + node_of_gpu_0/res5_1_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_1_branch2b_1 + node_of_gpu_0/res5_1_branch2b_bn_1 + node_of_gpu_0/res5_1_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_1_branch2c_1 + node_of_gpu_0/res5_1_branch2c_bn_1 + node_of_gpu_0/res5_1_branch2c_bn_2 + node_of_gpu_0/res5_1_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_2_branch2a_1 + node_of_gpu_0/res5_2_branch2a_bn_1 + node_of_gpu_0/res5_2_branch2a_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_2_branch2b_1 + node_of_gpu_0/res5_2_branch2b_bn_1 + node_of_gpu_0/res5_2_branch2b_bn_2
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/res5_2_branch2c_1 + node_of_gpu_0/res5_2_branch2c_bn_1 + node_of_gpu_0/res5_2_branch2c_bn_2 + node_of_gpu_0/res5_2_branch2c_bn_3
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] POOLING: node_of_gpu_0/pool5_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] CONVOLUTION: node_of_gpu_0/pred_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] SHUFFLE: reshape_after_node_of_gpu_0/pred_1
[01/06/2024-21:17:37] [I] [TRT] [GpuLayer] SOFTMAX: (Unnamed Layer* 180) [Softmax]
[01/06/2024-21:17:39] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +261, GPU +239, now: CPU 794, GPU 8020 (MiB)
[01/06/2024-21:17:39] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +82, GPU +88, now: CPU 876, GPU 8108 (MiB)
[01/06/2024-21:17:39] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[01/06/2024-21:18:06] [I] [TRT] Total Activation Memory: 32563448320
[01/06/2024-21:18:06] [I] [TRT] Detected 1 inputs and 1 output network tensors.
[01/06/2024-21:18:07] [I] [TRT] Total Host Persistent Memory: 134960
[01/06/2024-21:18:07] [I] [TRT] Total Device Persistent Memory: 291328
[01/06/2024-21:18:07] [I] [TRT] Total Scratch Memory: 0
[01/06/2024-21:18:07] [I] [TRT] [MemUsageStats] Peak memory usage of TRT CPU/GPU memory allocators: CPU 105 MiB, GPU 4520 MiB
[01/06/2024-21:18:07] [I] [TRT] [BlockAssignment] Started assigning block shifts. This will take 59 steps to complete.
[01/06/2024-21:18:07] [I] [TRT] [BlockAssignment] Algorithm ShiftNTopDown took 2.50731ms to assign 3 blocks to 59 nodes requiring 7225344 bytes.
[01/06/2024-21:18:07] [I] [TRT] Total Activation Memory: 7225344
[01/06/2024-21:18:07] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in building engine: CPU +89, GPU +128, now: CPU 89, GPU 128 (MiB)
[01/06/2024-21:18:07] [I] Engine built in 32.0571 sec.
[01/06/2024-21:18:07] [I] [TRT] Loaded engine size: 108 MiB
[01/06/2024-21:18:07] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +108, now: CPU 0, GPU 108 (MiB)
[01/06/2024-21:18:07] [I] Engine deserialized in 0.0264037 sec.
[01/06/2024-21:18:07] [I] [TRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +7, now: CPU 0, GPU 115 (MiB)
[01/06/2024-21:18:07] [I] Setting persistentCacheLimit to 0 bytes.
[01/06/2024-21:18:07] [I] Using values loaded from tabby_tiger_new.dat for input gpu_0/data_0
[01/06/2024-21:18:07] [I] Created input binding for gpu_0/data_0 with dimensions 1x3x224x224
[01/06/2024-21:18:07] [I] Using random values for output gpu_0/softmax_1
[01/06/2024-21:18:07] [I] Created output binding for gpu_0/softmax_1 with dimensions 1x1000
[01/06/2024-21:18:07] [I] Starting inference
[01/06/2024-21:18:10] [I] Warmup completed 25 queries over 200 ms
[01/06/2024-21:18:10] [I] Timing trace has 368 queries over 3.02551 s
[01/06/2024-21:18:10] [I] === Trace details ===
[01/06/2024-21:18:10] [I] Trace averages of 10 runs:
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18617 ms - Host latency: 8.24604 ms (enqueue 0.898984 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.17549 ms - Host latency: 8.239 ms (enqueue 0.969962 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.1696 ms - Host latency: 8.22351 ms (enqueue 0.956189 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18177 ms - Host latency: 8.23889 ms (enqueue 0.94278 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.1959 ms - Host latency: 8.25107 ms (enqueue 0.843054 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.199 ms - Host latency: 8.26624 ms (enqueue 0.873383 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.16205 ms - Host latency: 8.2147 ms (enqueue 0.786859 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18692 ms - Host latency: 8.23406 ms (enqueue 0.847974 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.19838 ms - Host latency: 8.24911 ms (enqueue 0.793134 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.20027 ms - Host latency: 8.25245 ms (enqueue 0.882941 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.1801 ms - Host latency: 8.2303 ms (enqueue 0.759869 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.17186 ms - Host latency: 8.22761 ms (enqueue 0.798047 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18611 ms - Host latency: 8.23773 ms (enqueue 0.716687 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.1741 ms - Host latency: 8.21832 ms (enqueue 0.814709 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.17648 ms - Host latency: 8.22267 ms (enqueue 0.80946 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.24866 ms - Host latency: 8.30702 ms (enqueue 0.788538 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.2257 ms - Host latency: 8.28545 ms (enqueue 0.790173 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.19059 ms - Host latency: 8.24176 ms (enqueue 0.774915 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.21903 ms - Host latency: 8.26468 ms (enqueue 0.81355 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18147 ms - Host latency: 8.22831 ms (enqueue 0.792749 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.18661 ms - Host latency: 8.2334 ms (enqueue 0.860803 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.23063 ms - Host latency: 8.2746 ms (enqueue 0.752869 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.24011 ms - Host latency: 8.28914 ms (enqueue 0.793591 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.17722 ms - Host latency: 8.23274 ms (enqueue 0.794751 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.12122 ms - Host latency: 8.17615 ms (enqueue 0.749243 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.13369 ms - Host latency: 8.1853 ms (enqueue 0.788184 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.20225 ms - Host latency: 8.24851 ms (enqueue 0.759424 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.2021 ms - Host latency: 8.25151 ms (enqueue 0.748193 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.20247 ms - Host latency: 8.24915 ms (enqueue 0.745776 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.22815 ms - Host latency: 8.2773 ms (enqueue 0.811865 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.20508 ms - Host latency: 8.25596 ms (enqueue 0.792871 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.20718 ms - Host latency: 8.25557 ms (enqueue 0.78208 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.22878 ms - Host latency: 8.27707 ms (enqueue 0.7448 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.24929 ms - Host latency: 8.29609 ms (enqueue 0.744263 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.21614 ms - Host latency: 8.26428 ms (enqueue 0.7698 ms)
[01/06/2024-21:18:10] [I] Average on 10 runs - GPU latency: 8.22415 ms - Host latency: 8.26838 ms (enqueue 0.753809 ms)
[01/06/2024-21:18:10] [I] === Performance summary ===
[01/06/2024-21:18:10] [I] Throughput: 121.632 qps
[01/06/2024-21:18:10] [I] Latency: min = 8.08862 ms, max = 8.38208 ms, mean = 8.25002 ms, median = 8.24704 ms, percentile(90%) = 8.30786 ms, percentile(95%) = 8.33105 ms, percentile(99%) = 8.3739 ms
[01/06/2024-21:18:10] [I] Enqueue Time: min = 0.549316 ms, max = 1.31122 ms, mean = 0.805704 ms, median = 0.701355 ms, percentile(90%) = 1.09424 ms, percentile(95%) = 1.15619 ms, percentile(99%) = 1.28442 ms
[01/06/2024-21:18:10] [I] H2D Latency: min = 0.0306396 ms, max = 0.107422 ms, mean = 0.048564 ms, median = 0.0427246 ms, percentile(90%) = 0.0692139 ms, percentile(95%) = 0.0818176 ms, percentile(99%) = 0.0960693 ms
[01/06/2024-21:18:10] [I] GPU Compute Time: min = 8.05054 ms, max = 8.33057 ms, mean = 8.19876 ms, median = 8.1947 ms, percentile(90%) = 8.25244 ms, percentile(95%) = 8.27917 ms, percentile(99%) = 8.32007 ms
[01/06/2024-21:18:10] [I] D2H Latency: min = 0.00146484 ms, max = 0.00512695 ms, mean = 0.00269583 ms, median = 0.00262451 ms, percentile(90%) = 0.00317383 ms, percentile(95%) = 0.00415039 ms, percentile(99%) = 0.00482178 ms
[01/06/2024-21:18:10] [I] Total Host Walltime: 3.02551 s
[01/06/2024-21:18:10] [I] Total GPU Compute Time: 3.01714 s
[01/06/2024-21:18:10] [I] Explanations of the performance metrics are printed in the verbose logs.
[01/06/2024-21:18:10] [I] Output Tensors:
[01/06/2024-21:18:10] [I] gpu_0/softmax_1: (1x1000)
[01/06/2024-21:18:10] [I] 4.31219e-09 3.27232e-08 6.03102e-09 7.18321e-08 8.16481e-09 1.81365e-08 5.16522e-09 8.57955e-08 5.11415e-07 1.60392e-06 6.45662e-08 4.51378e-08 1.54967e-07 3.57323e-08 1.50919e-07 2.02957e-07 7.65038e-08 1.90281e-06 1.74306e-07 2.85584e-08 3.43507e-08 6.44649e-07 1.99142e-07 5.56715e-07 3.7378e-06 3.41553e-08 1.00956e-08 6.22791e-08 2.47408e-08 3.43196e-08 1.43985e-07 5.16512e-08 3.22884e-08 2.4746e-08 1.70658e-07 2.76592e-07 2.26479e-07 2.64818e-07 1.41553e-07 1.57544e-06 2.76394e-08 1.1691e-06 8.99859e-08 2.21168e-07 3.4883e-07 8.93799e-08 2.68247e-07 6.48447e-08 2.82481e-07 2.70294e-08 2.67875e-08 2.96821e-07 9.61721e-07 7.48387e-08 5.23036e-07 5.61955e-08 6.25804e-08 2.33416e-08 1.12503e-07 3.18197e-07 5.57254e-07 2.07291e-08 4.99568e-08 1.10107e-07 1.06207e-07 3.59789e-08 3.21541e-07 1.17124e-06 1.77877e-07 3.40172e-07 4.75466e-08 4.20288e-07 9.99052e-08 4.06495e-08 1.96554e-07 2.68796e-08 1.06138e-06 8.2752e-08 4.29385e-07 8.97167e-07 4.39071e-07 3.73672e-08 1.31639e-06 3.46636e-07 1.13394e-06 4.0564e-07 6.47102e-07 1.07446e-06 1.2565e-06 1.03746e-08 1.33707e-07 1.38764e-08 1.8123e-08 3.42457e-08 1.41741e-08 3.81502e-09 1.96164e-08 2.63373e-08 1.21651e-08 8.68709e-08 6.31099e-08 1.69948e-08 7.01094e-08 5.38871e-08 8.37287e-08 4.00074e-08 2.50307e-06 5.6799e-09 3.3906e-08 1.0181e-07 5.49512e-08 5.5593e-08 3.17932e-07 1.6816e-07 3.77826e-07 1.34098e-08 8.32268e-09 4.16739e-07 5.34258e-08 1.38523e-08 1.24534e-08 2.18278e-08 2.71875e-08 5.56683e-08 5.21856e-07 3.22795e-07 1.49402e-07 1.26212e-09 2.03107e-09 2.55109e-09 1.27947e-08 5.4118e-08 1.63819e-07 1.64926e-07 1.58095e-08 3.3948e-08 5.78881e-08 3.12724e-08 4.36633e-07 3.09818e-08 5.42449e-08 1.85306e-08 3.83025e-08 4.3818e-09 6.02894e-09 1.10333e-07 3.40501e-08 1.84608e-08 8.44784e-09 1.04001e-08 6.81149e-07 2.27807e-07 1.06525e-06 1.47929e-07 9.68131e-08 6.87125e-08 1.15556e-07 9.35603e-08 2.39817e-08 2.31128e-07 5.07244e-08 3.7144e-08 1.44836e-08 2.6576e-07 2.87379e-07 1.75414e-08 9.6001e-09 1.25015e-09 2.60274e-07 4.35331e-08 7.18117e-08 1.66704e-07 7.62806e-08 1.68137e-07 1.1277e-07 4.46677e-08 2.51944e-08 1.3368e-07 3.34865e-07 8.15782e-08 9.76842e-08 1.33335e-07 5.22618e-08 5.91053e-07 6.17981e-08 4.13658e-07 1.49203e-06 4.72318e-07 4.43317e-08 5.23025e-07 7.41547e-08 3.99494e-08 7.95538e-08 1.12667e-06 3.15917e-09 1.98114e-07 1.49298e-07 1.24126e-07 1.64913e-07 2.40972e-07 2.59106e-07 7.38615e-08 7.8473e-08 1.31038e-06 1.66646e-07 1.14513e-07 6.65491e-08 1.61169e-07 4.4621e-07 9.9237e-09 8.12422e-08 3.87257e-07 1.49381e-08 5.202e-08 2.28715e-07 7.87144e-08 1.19345e-07 5.88824e-08 5.04929e-08 1.05746e-07 4.39331e-08 5.89527e-08 7.00098e-08 5.36868e-07 1.29429e-06 6.34282e-08 7.08734e-08 3.25876e-07 2.49778e-08 1.33292e-07 2.13743e-08 5.03121e-08 1.65417e-06 1.3774e-06 1.84975e-07 5.55522e-07 1.33338e-07 2.3248e-08 3.4907e-08 1.14445e-07 7.24208e-08 7.43851e-08 2.9075e-07 5.99565e-07 3.40904e-08 7.90543e-08 3.7215e-07 1.78741e-08 1.167e-06 1.44256e-07 2.30053e-07 4.95958e-07 4.53147e-08 2.10106e-07 6.59327e-08 3.44226e-07 3.3919e-07 2.51628e-08 1.68144e-07 1.12057e-07 2.69027e-07 7.50873e-08 1.3233e-07 5.31296e-08 8.91849e-08 1.24447e-07 4.44719e-08 1.53876e-08 1.87676e-07 5.07761e-08 5.52412e-08 2.49056e-08 8.85184e-08 2.82941e-08 1.31065e-07 3.28248e-08 1.41085e-06 4.26582e-07 1.38685e-06 1.69765e-06 6.41466e-06 0.222164 0.649406 0.000265587 2.77833e-05 0.118299 2.35406e-05 0.00494512 0.000353588 0.000128664 4.27559e-05 7.96535e-06 0.0016923 7.9745e-07 1.81176e-08 2.7363e-08 1.32207e-08 6.3004e-08 2.14228e-06 7.05765e-06 5.43203e-08 7.3703e-08 6.37532e-08 2.01735e-07 6.12086e-09 1.12721e-07 3.1454e-07 5.10996e-08 2.344e-08 5.03263e-07 3.63736e-07 5.61937e-07 2.68328e-07 3.18183e-07 1.19748e-07 1.60634e-07 3.15427e-06 1.38529e-06 1.23261e-07 8.09803e-08 3.88762e-08 2.09217e-08 1.48431e-07 7.79221e-09 5.48808e-07 2.108e-08 1.58163e-06 9.35706e-08 5.03974e-08 1.09431e-08 1.50153e-07 5.40322e-07 7.59874e-07 4.30646e-07 3.85417e-08 1.20151e-07 2.48362e-08 1.1377e-07 1.29412e-07 7.6831e-09 0.000145024 2.39234e-07 1.18882e-07 1.26118e-07 1.63536e-08 8.83463e-08 3.54368e-08 1.2187e-08 2.03324e-08 1.05163e-08 1.93692e-08 3.95044e-08 7.40076e-08 5.42306e-08 1.98142e-08 1.8415e-07 2.08151e-06 1.24005e-06 1.42602e-06 1.76945e-07 9.70648e-07 7.16566e-07 8.0947e-07 9.00147e-07 8.18857e-09 8.99452e-08 3.16986e-07 7.41196e-08 5.48573e-09 1.22034e-08 4.96608e-07 1.08288e-07 4.89107e-08 6.31607e-07 1.28074e-07 1.02883e-08 1.04286e-08 2.10383e-07 1.10675e-08 9.83445e-09 1.34309e-07 7.04894e-09 1.61061e-08 4.00807e-06 2.61122e-07 1.35763e-07 1.08121e-07 9.20258e-08 2.74398e-08 5.57276e-09 8.3922e-08 4.32769e-07 3.37907e-08 7.07499e-09 3.25664e-08 6.72846e-08 1.46607e-08 1.31611e-08 4.43623e-07 2.61208e-07 5.22855e-08 7.40795e-08 1.15638e-07 3.40772e-09 2.36093e-09 5.5517e-09 4.81737e-08 5.2435e-09 1.48066e-07 2.05642e-06 2.83374e-08 6.31107e-08 6.43683e-06 4.46948e-07 9.72298e-07 6.55227e-08 2.40795e-07 2.57961e-08 3.251e-07 6.85664e-06 5.10334e-07 2.05943e-07 6.87812e-08 6.4403e-09 2.31994e-08 1.278e-08 6.71909e-07 8.00414e-08 5.60545e-06 7.52245e-06 3.30366e-08 3.14636e-08 2.76163e-08 1.84685e-07 2.31083e-06 5.14467e-07 3.52963e-08 1.26886e-08 4.29366e-07 5.01386e-07 5.95346e-07 3.26838e-07 5.24194e-08 8.48795e-07 7.83283e-08 2.44987e-07 1.01231e-07 2.11385e-07 4.59941e-08 2.99574e-08 7.32672e-09 1.31519e-07 8.63965e-07 4.51796e-06 2.55771e-07 2.2358e-06 1.43611e-07 4.68767e-06 5.54229e-07 8.72966e-07 2.3307e-07 6.94223e-08 1.52769e-06 7.60646e-06 5.10959e-07 2.35479e-07 1.43391e-08 1.29262e-08 1.43641e-07 7.22168e-07 4.21727e-07 7.44233e-08 1.44281e-07 1.35441e-07 5.333e-07 5.01447e-07 8.81705e-09 7.42319e-08 3.26115e-05 6.89304e-07 5.16655e-08 1.03141e-07 1.05753e-08 2.02052e-07 4.97318e-08 1.88022e-08 4.88042e-08 1.2219e-06 1.05701e-07 5.96129e-07 1.17827e-06 4.65682e-08 1.07844e-07 4.72346e-08 4.77986e-07 3.65281e-08 1.60299e-07 1.8169e-08 2.05875e-08 3.21797e-07 1.69961e-09 2.22464e-06 4.00111e-07 6.7832e-07 2.27729e-06 5.08218e-08 8.98886e-07 5.11845e-07 2.20215e-06 3.93419e-08 1.27971e-08 1.47525e-09 3.5842e-07 2.9207e-08 9.53878e-06 6.27738e-06 5.2522e-08 1.48063e-07 1.28023e-06 2.25112e-06 2.70763e-07 4.22606e-08 1.8201e-07 4.31097e-07 7.04557e-08 6.30349e-08 2.50493e-07 2.34575e-07 9.92349e-08 2.22665e-06 3.47416e-07 1.49393e-07 5.91125e-07 1.87736e-07 9.69455e-07 3.18923e-08 3.75779e-08 2.48435e-08 2.65921e-08 4.20734e-05 4.29164e-09 1.25327e-07 1.52806e-06 4.51428e-06 7.61211e-08 2.55164e-07 4.47047e-08 2.0341e-09 4.07301e-08 1.17877e-07 1.86437e-08 8.28405e-08 3.22565e-06 3.46128e-06 1.30752e-10 3.44816e-09 5.05364e-08 4.86761e-08 3.2116e-07 4.18953e-07 7.2722e-08 4.18564e-08 8.55961e-07 2.87197e-07 1.56506e-07 5.14765e-08 6.6774e-07 1.41904e-07 2.31405e-07 1.70621e-08 1.36616e-07 1.25413e-08 6.51188e-06 1.9827e-08 2.87298e-07 2.18521e-08 6.62322e-08 2.68944e-07 1.42141e-07 1.83672e-08 1.91614e-07 1.50257e-07 3.74416e-08 1.89776e-08 4.23657e-08 4.79333e-07 1.0926e-07 1.6216e-06 1.14329e-06 1.34294e-07 1.04939e-08 1.07619e-06 1.99505e-07 1.39986e-06 1.07741e-07 6.27208e-08 4.03869e-06 4.54529e-08 4.6653e-08 6.08309e-07 8.17019e-07 6.28137e-08 2.89075e-07 1.14106e-07 2.50617e-07 7.47386e-07 1.22178e-06 6.25064e-08 0.000401968 1.995e-08 8.0799e-07 1.81799e-05 6.74927e-08 8.15525e-08 1.54894e-07 7.19469e-07 1.00188e-07 3.43813e-07 4.36554e-07 5.30778e-07 4.98392e-06 5.38992e-07 0.000510889 4.49317e-07 5.84905e-08 5.6472e-09 4.88459e-06 1.51236e-08 4.43269e-09 1.34801e-07 1.88732e-07 6.88306e-06 1.25287e-07 4.29881e-07 2.15576e-08 1.68197e-08 5.77935e-08 2.65805e-06 9.51291e-07 1.79138e-06 1.02712e-07 7.92065e-08 6.17835e-08 2.07746e-07 1.19137e-07 8.93553e-09 1.36442e-07 1.69639e-07 3.54148e-07 2.53757e-08 1.60009e-07 9.06202e-08 3.82748e-06 9.70912e-08 1.18824e-08 4.13489e-07 3.10697e-08 4.50127e-08 1.65702e-07 6.16994e-07 2.45009e-07 1.57708e-08 1.47974e-07 2.83974e-08 9.61385e-07 4.57889e-07 2.87782e-08 1.07784e-07 8.28538e-09 5.68251e-07 1.0362e-06 2.63081e-07 6.69241e-08 1.46807e-05 4.25193e-06 2.40326e-08 2.43369e-07 4.72804e-06 6.44753e-08 1.24654e-06 9.60749e-07 2.665e-06 3.06748e-07 4.22162e-08 2.92427e-07 3.25192e-09 2.96528e-08 8.33966e-09 6.63828e-08 1.06968e-07 9.00791e-09 7.35332e-08 1.85577e-07 2.68262e-08 2.46429e-08 2.93231e-07 1.01367e-06 1.20959e-06 5.22922e-08 1.69608e-07 1.36372e-05 2.8331e-07 3.12253e-07 4.90316e-06 3.17488e-07 1.42068e-08 2.129e-08 1.18458e-07 1.58725e-06 1.99419e-07 8.66641e-08 1.70225e-06 6.07794e-08 6.14967e-07 4.31817e-07 2.98631e-07 1.01794e-06 3.27476e-08 9.34612e-08 1.422e-07 3.08467e-06 4.1963e-07 3.22064e-05 4.64545e-06 6.38533e-09 3.44031e-06 3.20264e-09 5.47952e-09 0.000508376 4.04581e-08 1.1234e-07 1.17033e-06 2.57371e-08 1.73591e-06 1.32384e-08 9.25029e-08 4.6047e-07 7.26198e-07 9.6773e-07 4.91101e-08 5.24099e-07 3.4001e-06 2.08103e-06 6.28604e-07 1.2712e-07 2.645e-08 3.99737e-07 3.7949e-06 3.96355e-08 9.1404e-08 1.45296e-05 4.03064e-08 9.10027e-08 1.87741e-05 4.65326e-07 2.73036e-08 1.13201e-06 1.3518e-07 2.4601e-07 7.95868e-08 2.02313e-06 9.92311e-05 8.18532e-09 7.17072e-07 2.94609e-07 1.41133e-07 7.069e-09 9.73874e-08 2.29791e-06 2.35752e-05 1.8678e-05 9.41717e-09 3.27657e-07 8.5668e-07 3.25826e-07 1.63054e-06 4.30985e-08 1.36001e-07 1.16965e-06 2.12713e-08 2.99713e-09 8.14538e-08 2.85041e-06 7.47095e-06 7.25229e-07 3.23639e-08 1.03043e-07 1.84035e-06 1.17752e-07 1.75386e-07 7.34599e-08 1.78589e-08 6.76068e-07 4.76833e-07 1.45566e-05 1.60689e-07 1.28724e-07 1.01615e-06 2.44808e-08 4.90249e-06 2.35065e-08 1.2155e-07 2.73978e-08 4.22545e-08 1.20204e-06 8.49469e-06 0.000110935 1.47411e-08 1.7354e-06 8.90351e-07 4.84894e-08 4.525e-06 5.31328e-09 1.49173e-06 1.845e-08 2.27357e-07 2.98362e-07 1.81945e-08 1.81187e-06 1.81624e-08 8.46259e-09 2.20169e-08 1.4298e-08 2.21175e-07 1.06652e-07 1.09752e-07 1.98087e-07 2.29561e-07 4.17271e-07 1.89741e-08 8.16455e-07 7.98417e-07 5.70521e-09 2.26532e-08 7.90286e-07 4.12424e-06 1.00397e-06 1.771e-06 2.30236e-06 2.27294e-08 5.22434e-06 2.00706e-05 8.904e-07 6.1891e-07 1.74583e-07 1.3251e-05 2.08552e-07 8.7916e-09 2.82986e-08 7.18589e-08 1.65902e-07 7.60535e-07 6.43047e-06 2.04698e-08 5.72088e-08 1.26994e-06 1.1042e-08 1.02745e-07 1.65413e-06 9.2257e-08 1.67806e-08 2.19027e-06 3.1811e-07 8.77542e-08 2.21991e-08 5.99528e-08 2.62875e-07 1.94251e-07 4.18546e-08 4.09085e-07 1.74893e-06 7.53293e-08 2.81697e-06 3.86782e-08 5.46469e-09 8.96562e-08 3.53197e-06 3.09246e-08 4.60778e-08 6.10538e-06 2.47808e-07 2.08653e-07 2.94466e-07 2.35702e-06 2.14683e-08 6.43639e-07 1.06576e-07 3.97759e-08 2.1646e-08 4.0269e-07 1.52702e-07 1.33815e-08 7.36706e-08 8.30909e-08 1.85075e-06 1.07603e-08 9.49883e-07 2.50373e-06 4.67766e-06 2.00213e-06 1.45547e-08 3.71791e-08 7.28418e-07 2.36864e-07 3.34534e-05 7.90807e-07 1.10756e-07 3.31662e-07 1.49803e-08 2.12927e-07 2.73291e-07 2.73512e-07 9.27414e-08 2.73608e-08 8.97993e-09 9.94292e-09 5.26084e-07 3.28558e-07 4.1904e-05 1.70534e-07 2.15817e-08 4.75436e-07 4.26341e-08 5.15595e-08 1.16952e-07 3.27501e-09 3.05879e-09 2.58485e-08 2.0689e-08 4.9584e-06 3.05773e-08 3.75785e-08 1.18929e-07 1.53957e-09 1.93365e-08 1.62997e-08 1.06609e-07 1.11543e-06 1.63069e-07 6.40267e-07 4.10568e-08 1.128e-08 1.67669e-07 5.65517e-07 7.37952e-08 2.78064e-07 5.35779e-08 3.93165e-07 4.64912e-07 6.59557e-08 8.85602e-07 1.08205e-07 8.13449e-08 3.4025e-07 4.81834e-07 9.92183e-08 1.66807e-07 9.00434e-08 1.8549e-06 1.12568e-08 1.14591e-08 6.0587e-07 1.3412e-08 1.67332e-08 1.64203e-08 1.11066e-08 3.31439e-07 1.3843e-07 9.92739e-07 7.68445e-08 2.95164e-08 7.48974e-06 1.90854e-08 1.8991e-08 3.28791e-08 1.05048e-07 1.91254e-08 5.89584e-07 5.12448e-07 1.78304e-08 6.61151e-09 7.97469e-07 4.15751e-08 1.09356e-08 1.43087e-07 4.54704e-08 1.89151e-08 6.62792e-07 3.76557e-07 1.95258e-08 9.73641e-08 2.4037e-08 1.33256e-08 9.10277e-09 6.11777e-09 5.82621e-08 5.62718e-08 1.01834e-08 7.20226e-07 1.05142e-06Inference result: Detected:
[01/06/2024-21:18:10] [I] [1] tiger cat
[01/06/2024-21:18:10] [I] [2] tabby
[01/06/2024-21:18:10] [I] [3] Egyptian cat
[01/06/2024-21:18:10] [I] [4] lynx
[01/06/2024-21:18:10] [I] [5] tiger
Firstly, I need to clarify few things
In general, trtexec app is used to know the performance of a model. So by default it feeds some random data to all input values.
Each model will have different set of pre-processing and post processing. The trtexec binary does not any preprocessing or post processing for a model.
When you try to perform inference using a input image with trtexec, we need to make sure the input data that feed into model should be preprocessed already.
So for ResNet50 onnx model below preprocessing(Resize to 224*224 → HWC to CHW conversion → normalization) is required. Please modify the DAT file preparation like below
import numpy as np
from PIL import Image
img = Image.open('/usr/src/tensorrt/data/resnet50/tabby_tiger_cat.jpg')
image_arr = (
np.asarray(img.resize((224, 224), Image.ANTIALIAS))
.transpose([2, 0, 1])
.astype(np.float32)
.ravel()
print(image_arr.size)
img_norm= (image_arr / 255.0 - 0.45) / 0.225
print(img_norm[0:10])
dat_file_path = 'tabby_tiger_new.dat'
with open(dat_file_path, "wb") as fp:
img_norm.tofile(fp)
