Hello i have a new nvidia gtx 1660 and i’m trying to work in octane render but when i click on render, th e software show me that message “there is no cuda device which is selected”
how can i fix that problem?
thanks
thanks
Hola, tengo el mismo problema con el mismo ordenador, encontrarte alguna solucion?
@audiovisual.medina
Hi Mate, I have the same issue where you able to get a fix for this?
if yes, can you help me out?
The same problem with me. I have a Geforce gtx 1660 and when I try to render it shows the same message “there is no cuda device which is selected” My previous video card, a Geforce gtx 760 worked perfectly. Any way to solve this? Thanks!
This is cause of Octane render version if you are using octane 3.07 you will have this problem., you should upgrade it to octane 4.0
because your Video Card newer than octane version.
RTX 3060 Ti device not found in Cinema 4D as well. I tired render with Cyclec4D, Arnold and Redshift but none of them recognize my Rtx 3060 ti.
