Based on the commands you noted, I have ran the commands from the top - and I recieved multiple reboots on the NVIDIA Thor that did not render the device able to login for more than a couple minutes maximum. I was attempting to run the commands via SSH but instead (while the demuxer was running) I simply attached to the demuxer session while the system was rebooting.
I am attaching two logs (from two attempts each, attempts meaning waiting for reboot):
Thank you @AastaLLL for the direction and the update. Additionally, thank you for spending the time and effort pushing for testing this in an internal environment.
I attempted to run the command (with updated filenames) to help capture data we are looking for:
sudo minicom -D /dev/ttyACM0 | tee -a <logname>.txt
During a reboot cycle, I attempted to run sudo dmesg > log.txt (inside the NVIDIA Thor via UART session - which ran successfully), and then the system rebooted. After the reboot, I reran the command sudo minicom -D /dev/ttyACM0 | tee -a <logname>.txt, which I believe shows in the respective log.
Thank you for continuing to support this thread! I apologize if previous communications were mixed up on my side. I have run the commands you have noted and attached the output below:
Thank you for the research and the support! I see the software you are referring to is hosted on GitHub. It looks like it’s maintained by a person / org that is not Nvidia.
Could Nvidia Support prove this software is NVIDIA approved?
If I am mistaken in your request, please send an update. Please let me know if there is anything else I can help to troubleshoot.
UPDATE: It appears that the Thor is not able to stay powered on for very long. I have only used the Nvidia Thor for troubleshooting since before starting this post. I have a video here of the same data we requested. I have updated the previous photo / video album here: https://photos.app.goo.gl/PyszcqPKEZ29bn8s6. As evident in this video, the Nvidia Thor does not respond to power on / restart requests. The Nvidia Thor only turns on if it is plugged in.
Thank you for the information and feedback from you and the team’s research. Thank you and @whitesscott for doing incredible troubleshooting of this issue with me.
I am able to confirm a number of things:
Using a different NVIDIA Thor Power supply provided by a local MicroCenter results in the same issue (plugged in at MicroCenter, then later plugged in at home) renders no difference in result
Using a different outlet (many around the house) renders no difference in result
Using no surge protector renders no difference in result
Regardless of changes, there is no difference in result (Nvidia Thor continues to restart automatically).
I do not believe device will stay powered on long enough for a reflash to occur. I can confirm when upgrading from 38 to 39, it took around an hour. Based on previous messages - I believe we have narrowed this down to hardware.
I also wanted to add some information to answer a previous response - I have attempted to use both USB Type-C (vertical, not the debug port) to power the unit. Additionally, I have tried all possible combinations of the above (12 of 12) - with no change in results (Nvidia Thor reboots all by itself).
Is there any way we could discuss other options to get to a resolution?
Simply put - I am wondering if you could confirm whether (based on everything done / collected so far) you believe the device is exhibiting a hardware fault, and you recommend an RMA?
To clarify, the power stability issue mentioned above refers to instability from the extension cord, not a hardware problem with the Thor device itself.
To help us further investigate and isolate the issue, could you please re-flash the device firmware and check if the problem still occurs?
