So, this is one of my source files and I’m getting quite a few warnings from the internal Thrust implementations.
#include "globals.hpp"
#include "lib/nominate.hpp"
#include <thrust/device_vector.h>
#include <thrust/fill.h>
#include <thrust/tuple.h>
#include <thrust/sort.h>
#include <thrust/iterator/zip_iterator.h>
#include <thrust/unique.h>
#include <thrust/for_each.h>
#include <thrust/pair.h>
#include <thrust/distance.h>
#include <thrust/transform.h>
using thrust::device_vector;
using thrust::fill;
using thrust::tuple;
using thrust::get;
using thrust::make_zip_iterator;
using thrust::make_tuple;
using thrust::sort;
using thrust::unique_by_key_copy;
using thrust::for_each;
using thrust::pair;
using thrust::distance;
using thrust::transform;
* This function is used to determine which points will
* be used in this round of insertion.
* nm is an array aligned to the number of points that
* are available
* pa, ta, la are the association tuple
auto nominate(
long long const assoc_size,
thrust::device_vector<long long>& pa,
thrust::device_vector<long long>& ta,
thrust::device_vector<long long>& la,
thrust::device_vector<long long>& nm) -> void
// the first thing we want to do is sort everything
// by ta
auto zip_begin =
make_zip_iterator(
make_tuple(
pa.begin(),
ta.begin(),
la.begin()));
sort(
zip_begin, zip_begin + assoc_size,
[] __device__ (
tuple<long long, long long, long long> const& a,
tuple<long long, long long, long long> const& b) -> bool
long long const a_ta_id{get<1>(a)};
long long const a_pa_id{get<0>(a)};
long long const b_ta_id{get<1>(b)};
long long const b_pa_id{get<0>(b)};
return a_ta_id == b_ta_id ? a_pa_id < b_pa_id : a_ta_id < b_ta_id;
// we then want to allocate copies of our
// association arrays to write our stream
// compaction to
device_vector<long long> pa_cpy{static_cast<unsigned long long>(assoc_size), -1};
device_vector<long long> ta_cpy{static_cast<unsigned long long>(assoc_size), -1};
// remove tuple elements, using ta as the
// unique key
auto last_pair = unique_by_key_copy(
ta.begin(), ta.begin() + assoc_size,
pa.begin(),
ta_cpy.begin(),
pa_cpy.begin());
// unique_by_key_copy returns a pair of iterators (keys_last, values_last)
long long const assoc_cpy_size{static_cast<long long>(distance(ta_cpy.begin(), last_pair.first))};
fill(nm.begin(), nm.end(), 0);
device_vector<long long> nm_cpy{nm};
long long* nm_data = nm.data().get();
long long* nm_cpy_data = nm_cpy.data().get();
// this is how we count the number of occurrences for a particular
// point index
// if the copy doesn't match up with the original count array, that
// means that the point had some non-unique tetrahedra associated
// with it and as such is not up for nomination
for_each(
pa.begin(), pa.begin() + assoc_size,
[=] __device__ (long long const pa_id) -> void
atomicAdd(reinterpret_cast<unsigned long long*>(nm_data + pa_id), 1);
for_each(
pa_cpy.begin(), pa_cpy.begin() + assoc_cpy_size,
atomicAdd(reinterpret_cast<unsigned long long*>(nm_cpy_data + pa_id), 1);
// we perform a simple transformation over both ranges and
// check for equality.
// if the point occurred the same amount of times then all
// of its tetrahedra were unique and is able to be nominated
transform(
nm_cpy.begin(),
nm.begin(),
[] __device__ (long long const a, long long const b) -> long long
return (a != 0) && (a - b == 0);
These are the errors that I’m getting:
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/system/cuda/detail/detail/stable_sort_each.inl(299): warning C4244: 'initializing': conversion from 'difference_type' t
o 'int', possible loss of data [C:\Users\christian\cuda\cuda-stuff\build-debug\regulus.vcxproj]
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/detail/function.h(60): warning C4800: 'const int': forcing value to bool 'true' or 'false' (performance warning) [C:\Us
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/detail/function.h(96): warning C4800: 'int': forcing value to bool 'true' or 'false' (performance warning) [C:\Users\ch
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/detail/function.h(87): warning C4800: 'int': forcing value to bool 'true' or 'false' (performance warning) [C:\Users\ch
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/detail/internal_functional.h(322): warning C4244: '=': conversion from '__int64' to 'unsigned int', possible loss of da
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/system/cuda/detail/detail/stable_merge_sort.inl(313): warning C4319: '~': zero extending 'unsigned int' to '__int64' of
greater size [C:\Users\christian\cuda\cuda-stuff\build-debug\regulus.vcxproj]
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/system/cuda/detail/detail/stable_merge_sort.inl(328): warning C4244: 'argument': conversion from '__int64' to 'const un
signed int', possible loss of data [C:\Users\christian\cuda\cuda-stuff\build-debug\regulus.vcxproj]
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0\include\thrust/system/detail/generic/sequence.inl(48): warning C4244: 'return': conversion from '__int64' to 'unsigned int', possible
This is a link to the project for reference. The file is right here. Not all the source files are being built right now.
Is there something I’m missing?
