Here are two config file one will generate normal mp4 file and one will not.
There are two things that should note.
- When [source-attr-all] type = 3, the issue will happen. If type = 4, all the thing work great.
- The different between this two file is the number of the source. When num-source-bins=1, this issue happen. If num-source-bins=4, it work fine.
Working config
# Copyright (c) 2018-2022, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source-list]
num-source-bins = 4
list = rtsp://192.168.8.53/live1.sdp;rtsp://192.168.8.53/live1.sdp;rtsp://192.168.8.53/live1.sdp;rtsp://192.168.8.53/live1.sdp;
use-nvmultiurisrcbin = 1
stream-name-display = 0
sensor-id-list = d6c3a0fb-13c4-4e61-b959-d75e1026d1eb;d6c3a0fb-13c4-4e61-b959-d75e1026d2eb;d6c3a0fb-13c4-4e61-b959-d75e1026d3eb;d6c3a0fb-13c4-4e61-b959-d75e1026d4eb;
sensor-name-list = d6c3a0fb-13c4-4e61-b959-d75e1026d1eb;d6c3a0fb-13c4-4e61-b959-d75e1026d2eb;d6c3a0fb-13c4-4e61-b959-d75e1026d3eb;d6c3a0fb-13c4-4e61-b959-d75e1026d4eb;
max-batch-size = 1
http-ip = localhost
http-port = 9001
sgie-batch-size = 1
[source-attr-all]
enable = 1
type = 3
num-sources = 1
gpu-id = 0
cudadec-memtype = 0
latency = 100
select-rtp-protocol = 4
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink (Jetson only) 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
# set profile only for hw encoder, sw encoder selects profile based on sw-preset
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
enc-type=0
#sw-preset=1 #for SW enc=(0)None (1)ultrafast (2)superfast (3)veryfast (4)faster
#(5)fast (6)medium (7)slow (8)slower (9)veryslow (10)placebo
sync=0
#iframeinterval=10
bitrate=400000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=4
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=config_tracker_IOU.yml
# ll-config-file=config_tracker_NvSORT.yml
ll-config-file=config_tracker_NvDCF_perf.yml
# ll-config-file=config_tracker_NvDCF_accuracy.yml
# ll-config-file=config_tracker_NvDeepSORT.yml
gpu-id=0
display-tracking-id=1
[secondary-gie0]
enable=1
model-engine-file=../../models/Secondary_VehicleTypes/resnet18_vehicletypenet.etlt_b16_gpu0_int8.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=../../models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_vehiclemake.txt
[tests]
file-loop=0
Problem config
[application]
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source-list]
num-source-bins = 1
max-batch-size = 1
http-ip = localhost
http-port = 9001
sgie-batch-size = 1
[source-attr-all]
enable = 1
type = 3
num-sources = 1
gpu-id = 0
cudadec-memtype = 0
latency = 100
[sink0]
enable=0
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=400000
profile=0
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
buffer-pool-size=4
batch-size=4
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=4
interval=0
gie-unique-id=1
nvbuf-memory-type=0
[tracker]
enable=1
tracker-width=960
tracker-height=544
gpu-id=0
[secondary-gie0]
enable=1
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
[secondary-gie1]
enable=1
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
[tests]
file-loop=0
