Rtsp-reconnect-interval-sec cause filesink save a broken mp4 file
Deepstream 6.4
Ubuntu 22.04
I use deepstream-app with following modify.
If rtsp-reconnect-interval-sec is not set, file sink will produce a normal mp4 file. If rtsp-reconnect-interval-sec is set, the mp4 file will become unreadable.
Here is the code I modify deepstream-app in order to properly stop filesink to save a mp4 file.
static gboolean
event_thread_func (gpointer arg)
    case 'q':
      quit = TRUE;
      GstState cur;
      GstState pending;
      instance_bin = &appCtx[i]->pipeline.instance_bins[0]; //NvDsInstanceBin
      bin = &instance_bin->sink_bin; //NvDsSinkBin
      gst_element_send_event(appCtx[i]->pipeline.pipeline, gst_event_new_eos());
      for(int sink_index = 0; sink_index < bin->num_bins ; sink_index++){
        printf("send eos to sink %d\n", sink_index);
        gst_element_send_event(bin->sub_bins[sink_index].sink, gst_event_new_eos());
      msg = gst_bus_timed_pop_filtered(GST_ELEMENT_BUS (appCtx[i]->pipeline.pipeline),
      10000000000,
      (GstMessageType) (GST_MESSAGE_ERROR | GST_MESSAGE_EOS));
      g_main_loop_quit (main_loop);
      ret = FALSE;
      break;
Here is the config file modify from /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
# Copyright (c) 2018-2022, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source-list]
num-source-bins = 1
#list = file:///root/apps/iisi-ds64/iisi-ds63/my_exp/vicent/CCTV_2024-09-27-1.mp4;
list = rtsp://192.168.8.53/live1.sdp;
use-nvmultiurisrcbin = 1
stream-name-display = 0
sensor-id-list = d6c3a0fb-13c4-4e61-b959-d75e1026d1eb;
sensor-name-list = d6c3a0fb-13c4-4e61-b959-d75e1026d1eb;
max-batch-size = 1
http-ip = localhost
http-port = 9001
sgie-batch-size = 1
[source-attr-all]
enable = 1
type = 4
num-sources = 1
gpu-id = 0
cudadec-memtype = 0
latency = 100
#rtsp-reconnect-interval-sec=10
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink (Jetson only) 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
# set profile only for hw encoder, sw encoder selects profile based on sw-preset
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
enc-type=0
#sw-preset=1 #for SW enc=(0)None (1)ultrafast (2)superfast (3)veryfast (4)faster
#(5)fast (6)medium (7)slow (8)slower (9)veryslow (10)placebo
sync=0
#iframeinterval=10
bitrate=400000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
buffer-pool-size=4
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=config_tracker_IOU.yml
# ll-config-file=config_tracker_NvSORT.yml
ll-config-file=config_tracker_NvDCF_perf.yml
# ll-config-file=config_tracker_NvDCF_accuracy.yml
# ll-config-file=config_tracker_NvDeepSORT.yml
gpu-id=0
display-tracking-id=1
[secondary-gie0]
enable=1
model-engine-file=../../models/Secondary_VehicleTypes/resnet18_vehicletypenet.etlt_b16_gpu0_int8.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=../../models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
batch-size=16
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_vehiclemake.txt
[tests]
file-loop=0
Could you verify the return value of the gst_bus_timed_pop_filtered to see if there is an EOS message?
You can also check the GST_MESSAGE_EOS message in the bus_callback API.
I changed gst_bus_timed_pop_filtered to wait for GST_MESSAGE_EOS. However, when I press ‘q’, the program hangs. No matter what config I use.
      GST_CLOCK_TIME_NONE,
This may be the rootcause why the mp4 cannot be played, because the EOS is not actually sent successfully. We’ll try to analyze this issue.
Also you haven’t changed anything except the code you attached, have you? And when you set the rtsp-reconnect-interval-sec, it just hangs. Is that right?
Yes, That is all the thing I modify. One thing to note is when gst_bus_timed_pop_filtered timeout is GST_CLOCK_TIME_NONE, program will always hangs. No matter rtsp-reconnect-interval-sec is set or not.
I have tried that. When I set the rtsp-reconnect-interval-sec, the mp4 file can be read normally.
    case 'q':
      quit = TRUE;
      sleep (1);
      ret = FALSE;
      break;
config file:
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (5.3 KB)
