Time CPU
Hello All,
I am new to CUDA, so I am sure this is a simple newbie question but how does one go about timing an operation using CUDA GPU and CPU? I would like to use the “timer” functions offered in the example for Matrix-Multiplication:
unsigned int timer = 0;
cutilCheckError(cutCreateTimer(&timer));
cutilCheckError(cutStartTimer(timer));
// Start Timer …
// Do the CPU version of Matrix Multiplication:
// End Timer …
Do you do the same procedure as for the GPU Timing operation?
Thank you.
yes, I use cuda timer to measure both GPU code and CPU code.
Thank you, it works fine.
