Hi guys,
I have written a ray tracer for CUDA and want to time it as in I want to figure out how much time GPU is executing, how much time CPU is executing and waiting for GPU to return.
I have based my RT on postprocessGL example.
I tried the asynchAPI example for timing and all but somehow the cudacreateevent doesnt happen and it gives some memory error.
Basically I had written the block for creating timer and creating events in the process method in the postprocessgl.cu file.
I will post snippets telling exactly what I have done.
Thanks again.
psycloXPS
DenisR
February 26, 2008, 6:13am
2
use the visual profiler, it will tell you all sorts of details, runtime being one of them.
[snapback]333630[/snapback]
Thanks for the reply.
// Run the Cuda part of the computation //
void process(int pbo_in,int pbo_out,int width,int height, dimm3 center)
// for timing cuda calls
// create cuda event handles
cudaEvent_t start, stop;
CUDA_SAFE_CALL( cudaEventCreate(&start) );
CUDA_SAFE_CALL( cudaEventCreate(&stop) );
unsigned int timer;
CUT_SAFE_CALL( cutCreateTimer(&timer) );
CUT_SAFE_CALL( cutResetTimer(timer) );
CUDA_SAFE_CALL( cudaThreadSynchronize() );
float gpu_time = 0.0f;
// for the CUDA process
int *in_data;
int* out_data;
CUDA_SAFE_CALL(cudaGLMapBufferObject( (void**)&in_data, pbo_in));
CUDA_SAFE_CALL(cudaGLMapBufferObject( (void**)&out_data, pbo_out));
dim3 block(BLOCK_SIZE,BLOCK_SIZE,1);
dim3 grid(width / block.x, height / block.y,1);
CUT_SAFE_CALL( cutStartTimer(timer) );
cudaEventRecord(start, 0);
cudaEventSynchronize(start);
cudaRayTracer<<< grid, block,0,0>>>(out_data,width,height, center);
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
CUT_SAFE_CALL( cutStopTimer(timer) );
That is basically my code for timing.
Still it doesnt work.
It gives some memory errors I dont get otherwise.
The Visual Profiler…ehh that should solve all my problems :D
Cheers
– PsycloXPS
