I am trying to use cutCreateTimer(…) in CUDA 4.0
Witch librairy I should include to use timer in CUDA 4.0
in CUDA 3.2 I include shrUtils library, withc I think is no longer available on CUDA 4.0
Thnak’s
Thnak’s
Hi!
You can find shared utils in $(CUDA_SDK_ROOT)/shared/. You need to compile it (for Linux).
Best regards,
Assuming that you’re looking for a GPU-based timer, use events, i.e.
cudaEvent_t start, stop;
float time;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord( start, 0 );
kernel<<<grid,threads>>> ( d_odata, d_idata, size_x, size_y, NUM_REPS);
cudaEventRecord( stop, 0 );
cudaEventSynchronize( stop );
cudaEventElapsedTime( &time, start, stop );
cudaEventDestroy( start );
cudaEventDestroy( stop );
If you need clarification, I’d advise reading the CUDA Best Practices guide. The above code is from there, and section 2.1 of the guide is exclusively devoted to timing.
Thank’s guy…
I should read that “Best Practices Guides” from the beginning to the end…not just a few section like I did…
@alrikai very well answer, but you forgot to write, that time is expressed in miliseconds.
