Time Measurement for CUBLAS why time (clock()) for CUBLAS is always 0 ms for any array size?
The following is the code I am using for testing CUBLAS. However, i found the CUBLAS always take 0 ms no matter what the array size. :blink: Is it correct or is it some mistake in my code? :wacko:
/* Includes, system */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
/* Includes, cuda */
#include “cublas.h”
/* Main /
int main(int argc, char
* argv)
cublasStatus status;
float* h_A;
float* h_B;
float* h_C;
float* d_A = 0;
float* d_B = 0;
float* d_C = 0;
float alpha = 1.0f;
float beta = 0.0f;
int n2;
int i, size; /* Matrix size */
clock_t time_ffsum_start, time_ffsum_end ;
double looptime_ffsum ;
size = 4000;
	n2 = size * size;
/* Initialize CUBLAS */
printf("simpleCUBLAS test running..\n");
status = cublasInit();
if (status != CUBLAS_STATUS_SUCCESS) {
    fprintf (stderr, "!!!! CUBLAS initialization error\n");
    return EXIT_FAILURE;
/* Allocate host memory for the matrices */
h_A = (float*)malloc(n2 * sizeof(h_A[0]));
if (h_A == 0) {
    fprintf (stderr, "!!!! host memory allocation error (A)\n");
h_B = (float*)malloc(n2 * sizeof(h_B[0]));
if (h_B == 0) {
    fprintf (stderr, "!!!! host memory allocation error (B)\n");
h_C = (float*)malloc(n2 * sizeof(h_C[0]));
if (h_C == 0) {
    fprintf (stderr, "!!!! host memory allocation error ©\n");
/* Fill the matrices with test data */
for (i = 0; i < n2; i++) {
    h_A[i] = 1.0 ;
    h_B[i] = 1.0 ;
    h_C[i] = 0.0 ;
/* Allocate device memory for the matrices */
status = cublasAlloc(n2, sizeof(d_A[0]), (void**)&d_A);
    fprintf (stderr, "!!!! device memory allocation error (A)\n");
status = cublasAlloc(n2, sizeof(d_B[0]), (void**)&d_B);
    fprintf (stderr, "!!!! device memory allocation error (B)\n");
status = cublasAlloc(n2, sizeof(d_C[0]), (void**)&d_C);
    fprintf (stderr, "!!!! device memory allocation error ©\n");
/* Initialize the device matrices with the host matrices */
status = cublasSetVector(n2, sizeof(h_A[0]), h_A, 1, d_A, 1);
    fprintf (stderr, "!!!! device access error (write A)\n");
status = cublasSetVector(n2, sizeof(h_B[0]), h_B, 1, d_B, 1);
    fprintf (stderr, "!!!! device access error (write B)\n");
status = cublasSetVector(n2, sizeof(h_C[0]), h_C, 1, d_C, 1);
    fprintf (stderr, "!!!! device access error (write C)\n");
/* Clear last error */
cublasGetError();
/* Performs operation using cublas */
time_ffsum_start = clock(); // begin timing ffsum loop
cublasSgemm('n', 'n', size, size, size, alpha, d_A, size, d_B, size, beta, d_C, size);
time_ffsum_end = clock(); // end timing ffsum loop
status = cublasGetError();
    fprintf (stderr, "!!!! kernel execution error.\n");
/* Allocate host memory for reading back the result from device memory */
if (h_C == 0) {
/* Read the result back */
status = cublasGetVector(n2, sizeof(h_C[0]), d_C, 1, h_C, 1);
    fprintf (stderr, "!!!! device access error (read C)\n");
/*Printing the result*/
looptime_ffsum = (double)(time_ffsum_end - time_ffsum_start);
printf("\t %f \n", looptime_ffsum );
/* for (i = 0; i < n2; i++) {
	 printf("%f \t", *(h_C + i));
/* Memory clean up */
free(h_A);
free(h_B);
free(h_C);
  status = cublasFree(d_A);
    fprintf (stderr, "!!!! memory free error (A)\n");
status = cublasFree(d_B);
    fprintf (stderr, "!!!! memory free error (B)\n");
status = cublasFree(d_C);
    fprintf (stderr, "!!!! memory free error ©\n");
/* Shutdown */
status = cublasShutdown();
    fprintf (stderr, "!!!! shutdown error (A)\n");
if (argc > 1) {
    if (!strcmp(argv[1], "-noprompt") ||
        !strcmp(argv[1], "-qatest") )
        return EXIT_SUCCESS;
else
    printf("\nPress ENTER to exit...\n");
    getchar();
I am not 100% sure about CUBLAS, but for CUDA kernel launches, the control is returned to your program before the kernel execution is completed on GPU. Try using cudaThreadSynchronize() before the last timing call. Also, time() is only accurate up to a second. For proper timing techniques, lookup “bandwidthTest” project in SDK:
[codebox]
    unsigned int timer = 0;
CUT_SAFE_CALL(cutCreateTimer(&timer));
CUT_SAFE_CALL(cutStartTimer(timer));
// setup execution parameters
     CUDA_CALL();
// check if kernel execution generated and error
CUT_CHECK_ERROR("Kernel execution failed");
// stop and destroy timer
cudaThreadSynchronize();
CUT_SAFE_CALL(cutStopTimer(timer));
cout<<"\tKernel Processing time: "<<cutGetTimerValue(timer)/1000.<<" (s) \n";
CUT_SAFE_CALL(cutDeleteTimer(timer));
[/codebox]
Cheers!
Thank you Demq. External Media
Yes I need to wait until the threads synchronized and finish the job.
Regards,
Satakarni Bommuluri
