Hi all,
For a long time there has been a problem with timing our application (the COSMO numerical weather prediction and climate model) using the Portland Group compiler, since negative/strange values were sometimes present in the timing output. Now that I’ve finally found some time to investigate this issue, I’ve stumbled upon two of the sources of the problem. PGI’s system_clock command does not seem to be standard conformant. Two facts violate the standard (see example below):
The clock count is not always monotonically increasing
When a overflow in the counter occurs, the clock count does not restart with 0 but with -count_max
Any suggestions?
Oli
olifu@rosa1:~[226]> cat test_clock.f90
program test_clock
implicit none
integer :: icount,ir,im,iold
real*8 :: rtime
call system_clock (count=icount,count_rate=ir,count_max=im)
iold=icount
write(*,'(5A15)') 'current','old','rate (1/s)','max','deltaT (s)'
do
! get current count
call system_clock (count=icount)
! normal way to compute elapsed time in COSMO
if (icount >= iold) then
rtime = dble(icount-iold)/dble(ir)
else
rtime = dble(im-(iold-icount))/dble(ir)
end if
! only output when something strange or counter overflow
if (icount < iold) then
write(*,'(4I15,F15.7)') icount,iold,ir,im,rtime
end if
! save for next loop iteration
iold = icount
end do
end program test_clock
olifu@rosa1:~[227]> pgf90 test_clock.f90 -o test_clock
olifu@rosa1:~[228]> ./test_clock
current old rate (1/s) max deltaT (s)
2122468 2122469 1000000 2147483647 2147.4836460
2990456 2990457 1000000 2147483647 2147.4836460
16206258 16206259 1000000 2147483647 2147.4836460
16806248 16806250 1000000 2147483647 2147.4836450
17538238 17538239 1000000 2147483647 2147.4836460
17738234 17738235 1000000 2147483647 2147.4836460
2011928352 2011928353 1000000 2147483647 2147.4836460
2042503892 2042503894 1000000 2147483647 2147.4836450
2095707096 2095707097 1000000 2147483647 2147.4836460
2142302397 2142302398 1000000 2147483647 2147.4836460
-2147483648 2147483647 1000000 2147483647 -2147.4836480
-2129233250 -2129233249 1000000 2147483647 2147.4836460
-2128229264 -2128229263 1000000 2147483647 2147.4836460
