Timeout issue connecting ncu to a python application
When running a python binary under ncu I keep hitting an error message
==ERROR== Failed to connect to process
This happens in both launch-and-attach as well as launch mode (followed by an attach). I tried to get more debug information by creation config to flush output using a config as described here (NSight Compute not finding kernels - #6 by veraj). the logs there point to a timeout when trying to attach the process, see logs below.
I16:24:03:852|CmdlineProfiler|PID415001|TID415001|:294[]:Connecting to new process 414901
I16:24:03:852|profiler_multi_api_debugger_client|PID415001|TID415001|:270[]:Creating an API debugger and attaching...
I16:24:03:852|TPS_Comms|PID415001|TID415001|:87[]:Remaining transactions: 1
I16:24:03:852|tps_sync|PID415001|TID415001|:54[]:Begin WaitForCompletion
I16:24:03:852|tps_sync|PID415001|TID415001|:30[]:Create: 0x1f981080
I16:24:08:852|tps_sync|PID415001|TID415001|:40[]:result: Timeout
I16:24:08:852|tps_sync|PID415001|TID415001|:97[]:End WaitForCompletion
I16:24:08:852|tps_sync|PID415001|TID415001|:35[]:Destroy: 0x1f981080
E16:24:08:852|synchronous_multi_api_debugger_client|PID415001|TID415001|:285[]:Failed to attach to ApiDebugger.
E16:24:08:852|profiler_multi_api_debugger_client|PID415001|TID415001|:278[]:Failed to attach ApiDebugger.
E16:24:08:852|CmdlineProfiler|PID415001|TID415001|:331[]:Failed to create ProfilerMultiApiDebugger.
I16:24:08:852|CmdlineProfiler|PID415001|TID415001|:1307[]:End
I16:24:08:852|CmdlineProfiler|PID415001|TID415001|:1331[]:Profiler shutdown requested
I am able to profile simple python applications with my setup, but I’m having issues with a specific python application (which I am unable to share more details about). I am using CUDA 12.4 with NCU 2023.1 and python 3.9
Can you please try the same with the latest version of Nsight Compute? You can download and install it independently from the CUDA toolkit. It is also compatible with CUDA 12.4, but there have been several fixes to the launch process since 2023.1.
This topic was automatically closed 21 days after the last reply. New replies are no longer allowed.
