The Tegra K1 only boots partially and after that the serial terminal (UART4) stops working as well (can’t accept command, etc), here is screen copy from terminal log.
Could anyone help take a look and check what’s wrong in following logs?
[ 6.052566] ***********************************************
[ 6.052570] *Tuning values
[ 6.052572] estimated values
[ 6.052577] T2T_Vmax -111, T2T_Vmin 188, 1’st_hole_Vmax -272, UI_Vmax 0
[ 6.052580] Calculated values
[ 6.052584] T2T_Vmax 66, 1’st_hole_Vmax 38, UI_Vmax 75
[ 6.052668] T2T_Vmin -84, 1’st_hole_Vmin 156, UI_Vmin 0
[ 6.052671] ***********************************
[ 6.052677] *final tuning windows
[ 6.052681] win[0]: 26 - 150
[ 6.052684] win[1]: 47 - -32
[ 6.052687] win[2]: 75 - 150
[ 6.052691] win[3]: 127 - -91
[ 6.052694] win[4]: 150 - 150
[ 6.052703] win[5]: 208 - -150
[ 6.052706] win[6]: 226 - -189
[ 6.052709] ********************************
[ 6.052713] best tap win - (26-150), best tap value 88 prev_best_tap 88
[ 6.052724] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 88
[ 6.067781] mmc0: new HS200 MMC card at address 0001
[ 6.068010] mmcblk mmc0:0001: Card claimed for testing.
[ 6.068209] mmcblk0: mmc0:0001 HAG2e 14.6 GiB
[ 6.071589] Console: switching to colour frame buffer device 240x67
[ 6.072135] mmcblk0: p1
[ 6.270305] tegradc tegradc.0: fb registered
[ 6.277778] hdmi_state_machine_worker (tid edb8d5c0): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 6.291515] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 6.305083] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:10:06 UTC (946685406)
[ 6.317571] Disabling clocks left on by bootloader:
[ 6.325922] audio_2x
[ 6.331821] audio
[ 6.337367] audio4
[ 6.342996] audio3
[ 6.344766] hdmi_state_machine_worker (tid edb8d5c0): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 6.344771] hdmi_disable_l: audio_switch 0
[ 6.344773] hdmi_disable_l: hpd_switch 0
[ 6.344779] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 6.354766] hdmi_state_machine_worker (tid edb8d5c0): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 6.354771] hdmi_disable_l: audio_switch 0
[ 6.354774] hdmi_disable_l: hpd_switch 0
[ 6.354779] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 6.428782] audio2
[ 6.434783] audio1
[ 6.440741] audio0
[ 6.446679] hdmi_audio
[ 6.452856] entropy
[ 6.458740] dsi2-fixed
[ 6.464831] dsi1-fixed
[ 6.470894] usb3
[ 6.476430] usb2
[ 6.481988] mipi-cal-fixed
[ 6.488403] i2c3
[ 6.493910] i2c2
[ 6.499374] nor
[ 6.504699] trace
[ 6.510160] sdmmc4_ddr
[ 6.516058] sdmmc3_ddr
[ 6.521949] sdmmc3
[ 6.527513] cclk_lp
[ 6.533126] pciex
[ 6.538604] pll_x_out0
[ 6.544498] pll_m_out1
[ 6.550428] tegra_dvfs: vdd_cpu connected to regulator
[ 6.558882] tegra_dvfs: vdd_core connected to regulator
[ 6.567399] tegra_dvfs: vdd_gpu connected to regulator
[ 6.576477] CPU rate: 696 MHz
[ 6.582910] tegra cooling device gpu_scaling failed to register
[ 6.876620] tegra_simon_init_gpu: Failed to find gpu thermal zone
[ 6.886809] tegra_simon_add_grader: Failed to initialize grader for gpu
[ 6.897515] tegra_simon_init_cpu: Failed to find cpu thermal zone
[ 6.907749] tegra_simon_add_grader: Failed to initialize grader for cpu
[ 6.918514] ALSA device list:
[ 6.925646] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 6.938377] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 6.951367] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 7.049807] EXT4-fs (mmcblk0p1): recovery complete
[ 7.060275] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.072899] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.088109] devtmpfs: mounted
[ 7.095917] Freeing unused kernel memory: 508K (c0b1c000 - c0b9b000)
[ 7.355693] init: plymouth-upstart-bridge main process (108) terminated with status 1
[ 7.368918] init: plymouth-upstart-bridge main process ended, respawning
[ 7.419120] init: plymouth-upstart-bridge main process (118) terminated with status 1
[ 7.431545] init: plymouth-upstart-bridge main process ended, respawning
[ 7.444852] init: ureadahead main process (111) terminated with status 5
[ 7.494679] init: plymouth-upstart-bridge main process (121) terminated with status 1
[ 7.507093] init: plymouth-upstart-bridge main process ended, respawning
[ 9.444132] vi vi.1: vi_probe: couldn’t get regulator
[ 9.457332] vi vi.1: vi_probe: failed
[ 9.463586] vi vi.1: vi_create_debugfs: failed to create tegra_vi_1 directory
[ 9.475428] vi vi.1: vi_create_debugfs: could not create debugfs
[ 9.484278] vi vi.1: vi_probe: couldn’t get regulator
[ 9.495410] vi vi.1: vi_probe: failed
[ 9.502253] vi vi.1: vi_create_debugfs: failed to create tegra_vi_1 directory
[ 9.511190] vi vi.1: vi_create_debugfs: could not create debugfs
[ 9.519696] vi vi.1: vi_probe: couldn’t get regulator
[ 9.527394] vi vi.1: vi_probe: failed
- Starting Mount filesystems on boot [ OK ]
- Starting Signal sysvinit that the rootfs is mounted [ OK ]
- Starting Clean /tmp directory [ OK ]
- Starting Populate and link to /run filesystem [ OK ]
- Stopping Populate and link to /run filesystem [ OK ]
- Stopping Clean /tmp directory [ OK ]
- Stopping Track if upstart is running in a container [ OK ]
- Starting Initialize or finalize resolvconf [ OK ]
- Starting Signal sysvinit that virtual filesystems are mounted [ OK ]
- Starting Signal sysvinit that local filesystems are mounted [ OK ]
- Starting Bridge udev events into upstart [ OK ]
- Starting Signal sysvinit that remote filesystems are mounted [ OK ]
- Stopping Mount filesystems on boot [ OK ]
- Starting NFSv4 id <-> name mapper [ OK ]
- Starting Enabling additional executable binary formats [ OK ]
- Starting flush early job output to logs [ OK ]
- Starting D-Bus system message bus [ OK ]
- Starting device node and kernel event manager [ OK ]
- Stopping flush early job output to logs [ OK ]
- Starting NVIDIA specific init script [ OK ]
- Starting load modules from /etc/modules [ OK ]
- Starting cold plug devices [ OK ]
- Starting log initial device creation [ OK ]
- Starting SystemD login management service [ OK ]
- Stopping NVIDIA specific init script [ OK ]
- Stopping load modules from /etc/modules [ OK ]
- Stopping rpcsec_gss daemon [ OK ]
- Starting bluetooth daemon [ OK ]
- Stopping cold plug devices [ OK ]
- Starting system logging daemon [ OK ]
- Stopping NVIDIA specific first-boot script [ OK ]
- Stopping log initial device creation [ OK ]
- Starting CUPS printing spooler/server [ OK ]
- Starting userspace bootsplash [ OK ]
- Starting configure network device security [ OK ]
- Starting enable remaining boot-time encrypted block devices [ OK ]
- Stopping userspace bootsplash [ OK ]
- Starting Send an event to indicate plymouth is up [ OK ]
- Starting mDNS/DNS-SD daemon [ OK ]
- Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated [ OK ]
- Starting cups-browsed - Bonjour remote printer browsing daemon [ OK ]
- Stopping Send an event to indicate plymouth is up [ OK ]
- Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated [ OK ]
- Starting System V initialisation compatibility [ OK ]
- Starting modem connection manager [ OK ]
- Starting early crypto disks… [ OK ]
- Starting configure virtual network devices [ OK ]
- Setting sensors limits [ OK ]
- Starting network connection manager [ OK ]
- Setting up X socket directories… [ OK ]
- Stopping System V initialisation compatibility [ OK ]
- speech-dispatcher disabled; edit /etc/default/speech-dispatcher
- Starting NTP server ntpd [ OK ]
saned disabled; edit /etc/default/saned - Starting System V runlevel compatibility [ OK ]
- Starting anac(h)ronistic cron [ OK ]
- Starting save kernel messages [ OK ]
- Starting OpenSSH server [ OK ]
- Starting regular background program processing daemon [ OK ]
- Starting crash report submission daemon [ OK ]
- Stopping save kernel messages [ OK ]
- Stopping System V runlevel compatibility [ OK ]
- Stopping anac(h)ronistic cron [ OK ]
Ubuntu 14.04.3 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: ubuntu (automatic login)
Last login: Sat Jan 1 00:59:59 UTC 2000 on ttyS0
Welcome to Ubuntu 14.04.3 LTS (GNU/Linux 3.10.40-eniac armv7l)
Documentation: https://help.ubuntu.com/
