I want to try the tao toolkits.
It seems like I need to use tlt_converter in my Orin AGX.
Note: Where shall I download the tlt_converter?
I somehow downloaded the tlt_converter
However, when I ran it, it could not find libnvinfer.so.7
I was searching the forum and it seems it’s the Cuda version issue, I guess I have downloaded the old version of tlt_converter? Thx
root@ubuntu:/opt/nvidia/deepstream/deepstream-6.1/samples/experiment_dir_final# ./tlt-converter
./tlt-converter: error while loading shared libraries: libnvinfer.so.7: cannot open shared object file: No such file or directory
I am following this link on my Orin AGX, TAO Converter | NVIDIA NGC, but there is an error, still checking if the export path is not correct…
Thx
Btw, Do I use tao-converter or Tlt_converter? I am a little confused… If there is any tutorial of using the pbnet in my Orin AGX, that is all I need. Thx
wget --content-disposition https://api.ngc.nvidia.com/v2/resources/nvidia/tao/tao-converter/versions/v3.21.11_trt7.1_agx/zip -O tao-converter_v3.21.11_trt7.1_agx.zip
#unzip
sudo apt-get install libssl-dev
export TRT_LIB_PATH=”/usr/lib/aarch64-linux-gnu”
export TRT_INC_PATH=”/usr/include/aarch64-linux-gnu”
cd tao-converter_v3.21.11_trt7.1_agx/
pip3 install nvidia-pyindex
pip3 install nvidia-tao>=0.1.20
tao-converter
nvidia@ubuntu:~/Downloads/tao-converter_v3.21.11_trt7.1_agx$ tao-converter
bash: tao-converter: command not found
root@ubuntu:/opt/nvidia/deepstream/deepstream-6.1/samples/experiment_dir_final# dpkg -l |grep cuda
ii cuda-cccl-11-4 11.4.167-1 arm64 CUDA CCCL
ii cuda-command-line-tools-11-4 11.4.14-1 arm64 CUDA command-line tools
ii cuda-compiler-11-4 11.4.14-1 arm64 CUDA compiler
ii cuda-cudart-11-4 11.4.167-1 arm64 CUDA Runtime native Libraries
ii cuda-cudart-dev-11-4 11.4.167-1 arm64 CUDA Runtime native dev links, headers
ii cuda-cuobjdump-11-4 11.4.167-1 arm64 CUDA cuobjdump
ii cuda-cupti-11-4 11.4.167-1 arm64 CUDA profiling tools runtime libs.
ii cuda-cupti-dev-11-4 11.4.167-1 arm64 CUDA profiling tools interface.
ii cuda-cuxxfilt-11-4 11.4.167-1 arm64 CUDA cuxxfilt
ii cuda-documentation-11-4 11.4.167-1 arm64 CUDA documentation
ii cuda-driver-dev-11-4 11.4.167-1 arm64 CUDA Driver native dev stub library
ii cuda-gdb-11-4 11.4.167-1 arm64 CUDA-GDB
ii cuda-libraries-11-4 11.4.14-1 arm64 CUDA Libraries 11.4 meta-package
ii cuda-libraries-dev-11-4 11.4.14-1 arm64 CUDA Libraries 11.4 development meta-package
ii cuda-nvcc-11-4 11.4.166-1 arm64 CUDA nvcc
ii cuda-nvdisasm-11-4 11.4.167-1 arm64 CUDA disassembler
ii cuda-nvml-dev-11-4 11.4.167-1 arm64 NVML native dev links, headers
ii cuda-nvprof-11-4 11.4.166-1 arm64 CUDA Profiler tools
ii cuda-nvprune-11-4 11.4.167-1 arm64 CUDA nvprune
ii cuda-nvrtc-11-4 11.4.166-1 arm64 NVRTC native runtime libraries
ii cuda-nvrtc-dev-11-4 11.4.166-1 arm64 NVRTC native dev links, headers
ii cuda-nvtx-11-4 11.4.166-1 arm64 NVIDIA Tools Extension
ii cuda-samples-11-4 11.4.166-1 arm64 CUDA example applications
ii cuda-sanitizer-11-4 11.4.166-1 arm64 CUDA Sanitizer
ii cuda-toolkit-11-4 11.4.14-1 arm64 CUDA Toolkit 11.4 meta-package
ii cuda-toolkit-11-4-config-common 11.4.167-1 all Common config package for CUDA Toolkit 11.4.
ii cuda-toolkit-11-config-common 11.4.167-1 all Common config package for CUDA Toolkit 11.
ii cuda-toolkit-config-common 11.4.167-1 all Common config package for CUDA Toolkit.
ii cuda-tools-11-4 11.4.14-1 arm64 CUDA Tools meta-package
ii cuda-visual-tools-11-4 11.4.14-1 arm64 CUDA visual tools
ii graphsurgeon-tf 8.4.0-1+cuda11.4 arm64 GraphSurgeon for TensorRT package
ii libcudnn8 8.3.2.49-1+cuda11.4 arm64 cuDNN runtime libraries
ii libcudnn8-dev 8.3.2.49-1+cuda11.4 arm64 cuDNN development libraries and headers
ii libcudnn8-samples 8.3.2.49-1+cuda11.4 arm64 cuDNN samples
ii libnvinfer-bin 8.4.0-1+cuda11.4 arm64 TensorRT binaries
ii libnvinfer-dev 8.4.0-1+cuda11.4 arm64 TensorRT development libraries and headers
ii libnvinfer-doc 8.4.0-1+cuda11.4 all TensorRT documentation
ii libnvinfer-plugin-dev 8.4.0-1+cuda11.4 arm64 TensorRT plugin libraries
ii libnvinfer-plugin8 8.4.0-1+cuda11.4 arm64 TensorRT plugin libraries
ii libnvinfer-samples 8.4.0-1+cuda11.4 all TensorRT samples
ii libnvinfer8 8.4.0-1+cuda11.4 arm64 TensorRT runtime libraries
ii libnvonnxparsers-dev 8.4.0-1+cuda11.4 arm64 TensorRT ONNX libraries
ii libnvonnxparsers8 8.4.0-1+cuda11.4 arm64 TensorRT ONNX libraries
ii libnvparsers-dev 8.4.0-1+cuda11.4 arm64 TensorRT parsers libraries
ii libnvparsers8 8.4.0-1+cuda11.4 arm64 TensorRT parsers libraries
ii nvidia-l4t-cuda 34.1.1-20220516211757 arm64 NVIDIA CUDA Package
ii python3-libnvinfer 8.4.0-1+cuda11.4 arm64 Python 3 bindings for TensorRT
ii python3-libnvinfer-dev 8.4.0-1+cuda11.4 arm64 Python 3 development package for TensorRT
ii tensorrt 8.4.0.11-1+cuda11.4 arm64 Meta package of TensorRT
ii uff-converter-tf 8.4.0-1+cuda11.4 arm64 UFF converter for TensorRT package
