TLT DetectnetV2, Problem (Solved! -> RTX 3070 not supported by tlt 2.0_py3)
Getting the following error rather quickly. Tried different batch sizes. Any ideas?
Thank you!
NVIDIA-SMI 460.32.03, Driver Version: 460.32.03, CUDA Version: 11.2, RTX 3070
ERROR
2021-02-03 12:47:16.599473: E tensorflow/stream_executor/cuda/cuda_blas.cc:429] failed to run cuBLAS routine: CUBLAS_STATUS_EXECUTION_FAILED
2021-02-03 12:47:16.599505: E tensorflow/stream_executor/cuda/cuda_blas.cc:2437] Internal: failed BLAS call, see log for details
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1365, in _do_call
return fn(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1350, in _run_fn
target_list, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InternalError: 2 root error(s) found.
(0) Internal: Blas xGEMMBatched launch failed : a.shape=[4,3,3], b.shape=[4,3,3], m=3, n=3, k=3, batch_size=4
[[{{node CompositeTransform_6/CompositeTransform_5/CompositeTransform_4/CompositeTransform_3/CompositeTransform_2/CompositeTransform_1/CompositeTransform/RandomFlip/MatMul}}]]
[[resnet18_nopool_bn_detectnet_v2/block_3b_bn_2/AssignMovingAvg/_4241]]
(1) Internal: Blas xGEMMBatched launch failed : a.shape=[4,3,3], b.shape=[4,3,3], m=3, n=3, k=3, batch_size=4
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
  File "/usr/local/bin/tlt-train-g1", line 8, in <module>
    sys.exit(main())
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 55, in main
  File "<decorator-gen-2>", line 2, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 773, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 691, in run_experiment
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 624, in train_gridbox
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 149, in run_training_loop
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
    run_metadata=run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
    raise six.reraise(*original_exc_info)
  File "/usr/local/lib/python3.6/dist-packages/six.py", line 693, in reraise
    raise value
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
    return self._sess.run(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
    run_metadata_ptr)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
    feed_dict_tensor, options, run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
    run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
    raise type(e)(node_def, op, message)
	 [[node CompositeTransform_6/CompositeTransform_5/CompositeTransform_4/CompositeTransform_3/CompositeTransform_2/CompositeTransform_1/CompositeTransform/RandomFlip/MatMul (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'CompositeTransform_6/CompositeTransform_5/CompositeTransform_4/CompositeTransform_3/CompositeTransform_2/CompositeTransform_1/CompositeTransform/RandomFlip/MatMul':
    sys.exit(main())
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 599, in train_gridbox
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 430, in build_training_graph
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py", line 579, in get_dataset_tensors
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/processors/pipeline.py", line 231, in __call__
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/processors/transform_processor.py", line 146, in process
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/processors/processors.py", line 240, in __call__
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/processors/transform_processor.py", line 275, in call
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/processors/augment/random_flip.py", line 78, in call
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/dispatch.py", line 180, in wrapper
    return target(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/math_ops.py", line 2716, in matmul
    return batch_mat_mul_fn(a, b, adj_x=adjoint_a, adj_y=adjoint_b, name=name)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_math_ops.py", line 1712, in batch_mat_mul_v2
    "BatchMatMulV2", x=x, y=y, adj_x=adj_x, adj_y=adj_y, name=name)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
    op_def=op_def)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 507, in new_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
    attrs, op_def, compute_device)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
    op_def=op_def)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
    self._traceback = tf_stack.extract_stack()
CONFIG
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: “/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*”
image_directory_path: “/workspace/tlt-experiments/data/training”
image_extension: “png”
target_class_mapping {
key: “car”
value: “car”
key: “cyclist”
value: “cyclist”
key: “pedestrian”
value: “pedestrian”
key: “person_sitting”
value: “pedestrian”
key: “van”
value: “car”
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 480
output_image_height: 272
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: “car”
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: “cyclist”
value {
clustering_config {
dbscan_eps: 0.15000000596
key: “pedestrian”
value {
clustering_config {
coverage_threshold: 0.00749999983236
dbscan_eps: 0.230000004172
model_config {
pretrained_model_file: “/workspace/tlt-experiments/detectnet_v2/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5”
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: “resnet”
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: “car”
value: 0.699999988079
key: “cyclist”
value: 0.5
key: “pedestrian”
value: 0.5
evaluation_box_config {
key: “car”
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: “cyclist”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “pedestrian”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 8.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: “car”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
key: “cyclist”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “pedestrian”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
For RTX30xx series, the tlt 2.0_py3 docker has not supported yet.
Ouch, what are my options?
The future release will support it. Please stay tune.
Ok will do. Are we talking weeks or month? Thanks
The next release will release soon.
Hi @Morganh
Any date info about the release?
can we update cuda to 11.0 inside docker and install nvidia-tensorflow instead?
Please stay tune. The new TLT will release soon.
Thanks @Morganh
Reason being, im just buying the RTX 3090 which is quite expensive and surprised when i cannot utilize that with TLT…
But yeah, will wait for the release
Sorry for inconvenience. The TLT 2.0_py3 is released last August. So it does not support RTX30xx yet.
The new TLT will release very soon.
Released!
@HanzoHan
Thanks @Subframe! but do you know where is the latest release information?
i saw from https://docs.nvidia.com/metropolis/TLT/tlt-release-notes/index.html
and it looks like updated at July 2020
