I am using the Transfer Learning Toolkit container from NGC. I’ve trained a faster-rcnn model with a resnet10 backbone. I am now trying to export it in FP32 and FP16 mode and both times I get this error.
This is the command im using to export:
!tlt-export faster_rcnn -m $USER_EXPERIMENT_DIR/data/faster_rcnn/frcnn_kitti_resnet18.epoch12.tlt
-o $USER_EXPERIMENT_DIR/data/faster_rcnn/frcnn_kitti_resnet18_retrain_fp16.etlt
-e $SPECS_DIR/fastrcnn_retrain.txt
-k $KEY
–data_type fp16
And I get the following error:
2020-11-02 15:33:26.795166: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 4472 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1660, pci bus id: 0000:01:00.0, compute capability: 7.5)
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
DEBUG: convert reshape to flatten node
Warning: No conversion function registered for layer: CropAndResize yet.
Converting roi_pooling_conv_1/CropAndResize_new as custom op: CropAndResize
Warning: No conversion function registered for layer: Proposal yet.
Converting proposal as custom op: Proposal
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['proposal', 'dense_class_td/Softmax', 'dense_regress_td/BiasAdd'] as outputs
[TensorRT] ERROR: ../rtSafe/safeRuntime.cpp (25) - Cuda Error in allocate: 2 (out of memory)
[TensorRT] ERROR: ../builder/cudnnBuilderUtils.cpp (360) - Cuda Error in findFastestTactic: 2 (out of memory)
My spec file is as follows:
Copyright (c) 2017-2020, NVIDIA CORPORATION. All rights reserved.
random_seed: 42
enc_key: 'Z2o0aGRiaHNvcXFzNzViYWM0a3FuYW9vZzk6YWIxMDFhYmQtMDNhOS00OTYxLTg5YzMtODM4NzRmNmFlZTI0'
verbose: True
network_config {
input_image_config {
image_type: RGB
image_channel_order: 'bgr'
size_height_width {
height: 1080
width: 1920
image_channel_mean {
key: 'b'
value: 103.939
key: 'g'
value: 116.779
key: 'r'
value: 123.68
image_scaling_factor: 1.0
max_objects_num_per_image: 100
feature_extractor: "resnet:10"
anchor_box_config {
scale: 64.0
scale: 128.0
scale: 256.0
ratio: 1.0
ratio: 0.5
ratio: 2.0
freeze_bn: False
roi_mini_batch: 256
rpn_stride: 16
conv_bn_share_bias: True
roi_pooling_config {
pool_size: 7
pool_size_2x: False
all_projections: True
use_pooling:False
enable_qat: False
training_config {
kitti_data_config {
data_sources: {
tfrecords_path: "/workspace/tlt-experiments/tfrecords/kitti_trainval/kitti_trainval*"
image_directory_path: "/workspace/tlt-experiments/data"
image_extension: 'png'
target_class_mapping {
key: 'stone'
value: 'stone'
key: 'grass'
value: 'grass'
key: 'humus'
value: 'humus'
key: 'mineral'
value: 'mineral'
key: 'stub'
value: 'stub'
key: 'good_area'
value: 'good_area'
validation_fold: 0
data_augmentation {
preprocessing {
output_image_width: 1920
output_image_height: 1080
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 0
translate_max_y: 0
color_augmentation {
hue_rotation_max: 0.0
saturation_shift_max: 0.0
contrast_scale_max: 0.0
contrast_center: 0.5
enable_augmentation: True
batch_size_per_gpu: 1
num_epochs: 12
pretrained_weights: "/workspace/tlt-experiments/data/faster_rcnn/resnet_10.hdf5"
#resume_from_model: "/workspace/tlt-experiments/data/faster_rcnn/resnet10.epoch2.tlt"
output_model: "/workspace/tlt-experiments/data/faster_rcnn/frcnn_kitti_resnet10.tlt"
rpn_min_overlap: 0.3
rpn_max_overlap: 0.7
classifier_min_overlap: 0.0
classifier_max_overlap: 0.5
gt_as_roi: False
std_scaling: 1.0
classifier_regr_std {
key: 'x'
value: 10.0
key: 'y'
value: 10.0
key: 'w'
value: 5.0
key: 'h'
value: 5.0
rpn_mini_batch: 256
rpn_pre_nms_top_N: 12000
rpn_nms_max_boxes: 2000
rpn_nms_overlap_threshold: 0.7
reg_config {
type: L1
weight: 3e-5
optimizer {
sgd {
lr: 0.02
momentum: 0.9
decay: 0.0
nesterov: False
lr_scheduler {
soft_start {
base_lr: 0.02
start_lr: 0.002
soft_start: 0.1
annealing_points: 0.8
annealing_points: 0.9
annealing_divider: 10.0
lambda_rpn_regr: 1.0
lambda_rpn_class: 1.0
lambda_cls_regr: 1.0
lambda_cls_class: 1.0
inference_config {
images_dir: '/workspace/tlt-experiments/data/Test/images'
model: '/workspace/tlt-experiments/data/faster_rcnn/frcnn_kitti_resnet10.epoch12.tlt'
batch_size: 1
detection_image_output_dir: '/workspace/tlt-experiments/data/faster_rcnn/inference_results_imgs'
labels_dump_dir: '/workspace/tlt-experiments/data/faster_rcnn/inference_dump_labels'
rpn_pre_nms_top_N: 6000
rpn_nms_max_boxes: 300
bbox_visualize_threshold: 0.6
classifier_nms_max_boxes: 300
classifier_nms_overlap_threshold: 0.3
evaluation_config {
batch_size: 1
validation_period_during_training: 1
labels_dump_dir: '/workspace/tlt-experiments/data/faster_rcnn/test_dump_labels'
object_confidence_thres: 0.0001
use_voc07_11point_metric:False
I need help to export to .etlt.
