@Morganh PFB the files used in my experiment:
config.sh
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# Enable or Disable Jarvis Services
service_enabled_asr=true
service_enabled_nlp=true
service_enabled_tts=true
# Specify one or more GPUs to use
# specifying more than one GPU is currently an experimental feature, and may result in undefined behaviours.
gpus_to_use="device=0"
# Specify the encryption key to use to deploy models
MODEL_DEPLOY_KEY="tlt_encode"
# Locations to use for storing models artifacts
# If an absolute path is specified, the data will be written to that location
# Otherwise, a docker volume will be used (default).
# jarvis_init.sh will create a `jmir` and `models` directory in the volume or
# path specified.
# JMIR ($jarvis_model_loc/jmir)
# Jarvis uses an intermediate representation (JMIR) for models
# that are ready to deploy but not yet fully optimized for deployment. Pretrained
# versions can be obtained from NGC (by specifying NGC models below) and will be
# downloaded to $jarvis_model_loc/jmir by `jarvis_init.sh`
# Custom models produced by NeMo or TLT and prepared using jarvis-build
# may also be copied manually to this location $(jarvis_model_loc/jmir).
# Models ($jarvis_model_loc/models)
# During the jarvis_init process, the JMIR files in $jarvis_model_loc/jmir
# are inspected and optimized for deployment. The optimized versions are
# stored in $jarvis_model_loc/models. The jarvis server exclusively uses these
# optimized versions.
jarvis_model_loc="</path/to/finetuned-model-dir>"
# The default JMIRs are downloaded from NGC by default in the above $jarvis_jmir_loc directory
# If you'd like to skip the download from NGC and use the existing JMIRs in the $jarvis_jmir_loc
# then set the below $use_existing_jmirs flag to true. You can also deploy your set of custom
# JMIRs by keeping them in the jarvis_jmir_loc dir and use this quickstart script with the
# below flag to deploy them all together.
use_existing_jmirs=true
# Ports to expose for Jarvis services
jarvis_speech_api_port="50051"
jarvis_vision_api_port="60051"
# NGC orgs
jarvis_ngc_org="nvidia"
jarvis_ngc_team="jarvis"
jarvis_ngc_image_version="1.0.0-b.3"
jarvis_ngc_model_version="1.0.0-b.1"
# Pre-built models listed below will be downloaded from NGC. If models already exist in $jarvis-jmir
# then models can be commented out to skip download from NGC
models_asr=(
### Punctuation model
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_punctuation:${jarvis_ngc_model_version}"
### Jasper Streaming w/ CPU decoder, best latency configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_streaming:${jarvis_ngc_model_version}"
### Jasper Streaming w/ CPU decoder, best throughput configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_streaming_throughput:${jarvis_ngc_model_version}"
### Jasper Offline w/ CPU decoder
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_offline:${jarvis_ngc_model_version}"
### Quarztnet Streaming w/ CPU decoder, best latency configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_quartznet_english_streaming:${jarvis_ngc_model_version}"
### Quarztnet Streaming w/ CPU decoder, best throughput configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_quartznet_english_streaming_throughput:${jarvis_ngc_model_version}"
### Quarztnet Offline w/ CPU decoder
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_quartznet_english_offline:${jarvis_ngc_model_version}"
### Jasper Streaming w/ GPU decoder, best latency configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_streaming_gpu_decoder:${jarvis_ngc_model_version}"
### Jasper Streaming w/ GPU decoder, best throughput configuration
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_streaming_throughput_gpu_decoder:${jarvis_ngc_model_version}"
### Jasper Offline w/ GPU decoder
# "${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_asr_jasper_english_offline_gpu_decoder:${jarvis_ngc_model_version}"
models_nlp=(
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_named_entity_recognition:${jarvis_ngc_model_version}"
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_intent_slot:${jarvis_ngc_model_version}"
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_question_answering:${jarvis_ngc_model_version}"
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_text_classification:${jarvis_ngc_model_version}"
models_tts=(
"${jarvis_ngc_org}/${jarvis_ngc_team}/jmir_jarvis_tts_ljspeech:${jarvis_ngc_model_version}"
NGC_TARGET=${jarvis_ngc_org}
if [[ ! -z ${jarvis_ngc_team} ]]; then
NGC_TARGET="${NGC_TARGET}/${jarvis_ngc_team}"
else
team="\"\""
fi
# define docker images required to run Jarvis
image_client="nvcr.io/${NGC_TARGET}/jarvis-speech-client:${jarvis_ngc_image_version}"
image_speech_api="nvcr.io/${NGC_TARGET}/jarvis-speech:${jarvis_ngc_image_version}-server"
# define docker images required to setup Jarvis
image_init_speech="nvcr.io/${NGC_TARGET}/jarvis-speech:${jarvis_ngc_image_version}-servicemaker"
# daemon names
jarvis_daemon_speech="jarvis-speech"
jarvis_daemon_client="jarvis-client"
finetune.yaml
# Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
# TLT spec file for fine-tuning a previously trained ASR model (Jasper or QuartzNet) on the MCV Russian dataset.
exp_manager:
create_tensorboard_logger: true
trainer:
max_epochs: 50 # This is low for demo purposes
# Whether or not to change the decoder vocabulary.
# Note that this MUST be set if the labels change, e.g. to a different language's character set
# or if additional punctuation characters are added.
change_vocabulary: false
# Fine-tuning settings: training dataset
finetuning_ds:
manifest_filepath: ???
sample_rate: 16000
labels: [' ', 'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm',
'n', 'o', 'p', 'q', 'r', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z', "'"]
batch_size: 16
trim_silence: true
max_duration: 16.7
shuffle: true
is_tarred: false
tarred_audio_filepaths: null
# Fine-tuning settings: validation dataset
validation_ds:
sample_rate: 16000
batch_size: 16
shuffle: false
max_duration: 16.7
# Fine-tuning settings: optimizer
optim:
lr: 0.001
