Description
Hi
I’m trying to start jarvis server with NeMo model . I am trying onlt ASR models.
I successfully completed the Build process according to Deploying Your Custom Model into Jarvis — NVIDIA Jarvis Speech Skills v1.0.0-b.2 documentation. I am using only pre trained model from NGC for asr.First i modify config.sh and then run jarvis_init.sh.Both are successfully completed.But when i am running jarvis_start.sh i am ended in + echo ‘Health ready check failed.’
- echo ‘Check Jarvis logs with: docker logs jarvis-speech’
Check Jarvis logs with: docker logs jarvis-speech - exit 1
Log for jarvis-speech
== Jarvis Speech Skills ==
NVIDIA Release 20.11 (build 19933361)
Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION. All rights reserved.
NVIDIA modifications are covered by the license terms that apply to the underlying
project or file.
NOTE: Legacy NVIDIA Driver detected. Compatibility mode ENABLED.
Jarvis waiting for Triton server to load all models…retrying in 1 second
I0316 10:17:42.394441 76 metrics.cc:219] Collecting metrics for GPU 0: A100-SXM4-40GB
I0316 10:17:42.569791 76 pinned_memory_manager.cc:199] Pinned memory pool is created at ‘0x7f5ba2000000’ with size 268435456
I0316 10:17:42.571922 76 cuda_memory_manager.cc:99] CUDA memory pool is created on device 0 with size 1000000000
I0316 10:17:42.617245 76 model_repository_manager.cc:810] loading: jarvis-trt-quartznet:1
I0316 10:17:42.617367 76 model_repository_manager.cc:810] loading: jarvis-trt-jasper:1
I0316 10:17:42.617448 76 model_repository_manager.cc:810] loading: jarvis-trt-jarvis_punctuation-nn-bert-base-uncased:1
I0316 10:17:42.617541 76 model_repository_manager.cc:810] loading: jarvis_detokenize:1
I0316 10:17:42.617648 76 model_repository_manager.cc:810] loading: jarvis_punctuation_gen_output:1
I0316 10:17:42.617744 76 model_repository_manager.cc:810] loading: jarvis_punctuation_label_tokens_cap:1
I0316 10:17:42.617867 76 model_repository_manager.cc:810] loading: jarvis_punctuation_label_tokens_punct:1
I0316 10:17:42.617969 76 model_repository_manager.cc:810] loading: jarvis_punctuation_merge_labels:1
I0316 10:17:42.618075 76 model_repository_manager.cc:810] loading: jarvis_tokenizer:1
I0316 10:17:42.618217 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming:1
I0316 10:17:42.618361 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-feature-extractor-streaming:1
I0316 10:17:42.618506 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-offline-ctc-decoder-cpu-streaming-offline:1
I0316 10:17:42.618645 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-offline-feature-extractor-streaming-offline:1
I0316 10:17:42.618771 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-offline-voice-activity-detector-ctc-streaming-offline:1
I0316 10:17:42.618899 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming:1
I0316 10:17:42.619019 76 model_repository_manager.cc:810] loading: quartznet-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming:1
I0316 10:17:42.619170 76 model_repository_manager.cc:810] loading: quartznet-asr-trt-ensemble-vad-streaming-feature-extractor-streaming:1
I0316 10:17:42.619298 76 model_repository_manager.cc:810] loading: quartznet-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming:1
I0316 10:17:42.628787 76 custom_backend.cc:198] Creating instance jarvis_detokenize_0_0_cpu on CPU using libtriton_jarvis_nlp_detokenizer.so
I0316 10:17:42.631374 76 custom_backend.cc:198] Creating instance jarvis_punctuation_gen_output_0_0_cpu on CPU using libtriton_jarvis_nlp_punctuation.so
I0316 10:17:42.632153 76 custom_backend.cc:198] Creating instance jarvis_punctuation_label_tokens_punct_0_0_cpu on CPU using libtriton_jarvis_nlp_seqlabel.so
I0316 10:17:42.632609 76 custom_backend.cc:198] Creating instance jarvis_punctuation_label_tokens_cap_0_0_cpu on CPU using libtriton_jarvis_nlp_seqlabel.so
I0316 10:17:42.633322 76 custom_backend.cc:198] Creating instance jarvis_tokenizer_0_0_cpu on CPU using libtriton_jarvis_nlp_tokenizer.so
I0316 10:17:42.633672 76 custom_backend.cc:198] Creating instance jasper-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming_0_0_cpu on CPU using libtriton_jarvis_asr_decoder_cpu.so
I0316 10:17:42.634353 76 custom_backend.cc:198] Creating instance jasper-asr-trt-ensemble-vad-streaming-offline-ctc-decoder-cpu-streaming-offline_0_0_cpu on CPU using libtriton_jarvis_asr_decoder_cpu.so
I0316 10:17:42.634561 76 custom_backend.cc:198] Creating instance jasper-asr-trt-ensemble-vad-streaming-offline-voice-activity-detector-ctc-streaming-offline_0_0_cpu on CPU using libtriton_jarvis_asr_vad.so
I0316 10:17:42.634654 76 custom_backend.cc:198] Creating instance jasper-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming_0_0_cpu on CPU using libtriton_jarvis_asr_vad.so
I0316 10:17:42.634763 76 custom_backend.cc:198] Creating instance quartznet-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming_0_0_cpu on CPU using libtriton_jarvis_asr_decoder_cpu.so
I0316 10:17:42.635181 76 custom_backend.cc:198] Creating instance quartznet-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming_0_0_cpu on CPU using libtriton_jarvis_asr_vad.so
I0316 10:17:42.636621 76 custom_backend.cc:198] Creating instance jarvis_punctuation_merge_labels_0_0_cpu on CPU using libtriton_jarvis_nlp_labels.so
I0316 10:17:42.638784 76 custom_backend.cc:201] Creating instance jasper-asr-trt-ensemble-vad-streaming-feature-extractor-streaming_0_0_gpu0 on GPU 0 (8.0) using libtriton_jarvis_asr_features.so
I0316 10:17:42.638893 76 custom_backend.cc:201] Creating instance jasper-asr-trt-ensemble-vad-streaming-offline-feature-extractor-streaming-offline_0_0_gpu0 on GPU 0 (8.0) using libtriton_jarvis_asr_features.so
I0316 10:17:42.639099 76 custom_backend.cc:201] Creating instance quartznet-asr-trt-ensemble-vad-streaming-feature-extractor-streaming_0_0_gpu0 on GPU 0 (8.0) using libtriton_jarvis_asr_features.so
I0316 10:17:42.644346 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_detokenize’ version 1
I0316 10:17:42.685363 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_punctuation_merge_labels’ version 1
I0316 10:17:42.699455 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_punctuation_label_tokens_cap’ version 1
I0316 10:17:42.758812 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_punctuation_label_tokens_punct’ version 1
I0316 10:17:42.758823 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_punctuation_gen_output’ version 1
I0316 10:17:42.774087 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-offline-voice-activity-detector-ctc-streaming-offline’ version 1
I0316 10:17:42.775556 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming’ version 1
I0316 10:17:42.779942 76 model_repository_manager.cc:983] successfully loaded ‘quartznet-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming’ version 1
I0316 10:17:42.812422 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_tokenizer’ version 1
I0316 10:17:47.246180 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming’ version 1
I0316 10:17:47.711642 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-offline-ctc-decoder-cpu-streaming-offline’ version 1
I0316 10:17:47.973334 76 model_repository_manager.cc:983] successfully loaded ‘quartznet-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming’ version 1
I0316 10:17:54.198836 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-feature-extractor-streaming’ version 1
I0316 10:17:54.198936 76 model_repository_manager.cc:983] successfully loaded ‘quartznet-asr-trt-ensemble-vad-streaming-feature-extractor-streaming’ version 1
I0316 10:17:54.199011 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-offline-feature-extractor-streaming-offline’ version 1
I0316 10:17:55.169379 76 plan_backend.cc:333] Creating instance jarvis-trt-quartznet_0_0_gpu0 on GPU 0 (8.0) using model.plan
I0316 10:17:55.546025 76 plan_backend.cc:666] Created instance jarvis-trt-quartznet_0_0_gpu0 on GPU 0 with stream priority 0 and optimization profile default[0];
I0316 10:17:55.548244 76 model_repository_manager.cc:983] successfully loaded ‘jarvis-trt-quartznet’ version 1
I0316 10:17:56.925388 76 plan_backend.cc:333] Creating instance jarvis-trt-jarvis_punctuation-nn-bert-base-uncased_0_0_gpu0 on GPU 0 (8.0) using model.plan
I0316 10:17:58.276515 76 plan_backend.cc:666] Created instance jarvis-trt-jarvis_punctuation-nn-bert-base-uncased_0_0_gpu0 on GPU 0 with stream priority 0 and optimization profile default[0];
I0316 10:17:58.299358 76 model_repository_manager.cc:983] successfully loaded ‘jarvis-trt-jarvis_punctuation-nn-bert-base-uncased’ version 1
I0316 10:18:02.187086 76 plan_backend.cc:333] Creating instance jarvis-trt-jasper_0_0_gpu0 on GPU 0 (8.0) using model.plan
I0316 10:18:05.855726 76 plan_backend.cc:666] Created instance jarvis-trt-jasper_0_0_gpu0 on GPU 0 with stream priority 0 and optimization profile default[0];
I0316 10:18:05.876726 76 model_repository_manager.cc:983] successfully loaded ‘jarvis-trt-jasper’ version 1
I0316 10:18:05.877997 76 model_repository_manager.cc:810] loading: jarvis_punctuation:1
I0316 10:18:05.878138 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming:1
I0316 10:18:05.878263 76 model_repository_manager.cc:810] loading: jasper-asr-trt-ensemble-vad-streaming-offline:1
I0316 10:18:05.878350 76 model_repository_manager.cc:983] successfully loaded ‘jarvis_punctuation’ version 1
I0316 10:18:05.878392 76 model_repository_manager.cc:810] loading: quartznet-asr-trt-ensemble-vad-streaming:1
I0316 10:18:05.878522 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming’ version 1
I0316 10:18:05.878683 76 model_repository_manager.cc:983] successfully loaded ‘quartznet-asr-trt-ensemble-vad-streaming’ version 1
I0316 10:18:05.879043 76 model_repository_manager.cc:983] successfully loaded ‘jasper-asr-trt-ensemble-vad-streaming-offline’ version 1
I0316 10:18:05.879172 76 server.cc:141]
| Backend | Config | Path |
I0316 10:18:05.879291 76 server.cc:184]
| Model | Version | Status |
| jarvis-trt-jarvis_punctuation-nn-bert-base-uncased | 1 | READY |
| jarvis-trt-jasper | 1 | READY |
| jarvis-trt-quartznet | 1 | READY |
| jarvis_detokenize | 1 | READY |
| jarvis_punctuation | 1 | READY |
| jarvis_punctuation_gen_output | 1 | READY |
| jarvis_punctuation_label_tokens_cap | 1 | READY |
| jarvis_punctuation_label_tokens_punct | 1 | READY |
| jarvis_punctuation_merge_labels | 1 | READY |
| jarvis_tokenizer | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-feature-extractor-streaming | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-offline | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-offline-ctc-decoder-cpu-streaming-offline | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-offline-feature-extractor-streaming-offline | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-offline-voice-activity-detector-ctc-streaming-offline | 1 | READY |
| jasper-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming | 1 | READY |
| quartznet-asr-trt-ensemble-vad-streaming | 1 | READY |
| quartznet-asr-trt-ensemble-vad-streaming-ctc-decoder-cpu-streaming | 1 | READY |
| quartznet-asr-trt-ensemble-vad-streaming-feature-extractor-streaming | 1 | READY |
| quartznet-asr-trt-ensemble-vad-streaming-voice-activity-detector-ctc-streaming | 1 | READY |
I0316 10:18:05.879388 76 tritonserver.cc:1620]
| Option | Value |
| server_id | triton |
| server_version | 2.5.0 |
| server_extensions | classification sequence model_repository schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data statistics |
| model_repository_path[0] | /data/models |
| model_control_mode | MODE_NONE |
| strict_model_config | 1 |
| pinned_memory_pool_byte_size | 268435456 |
| cuda_memory_pool_byte_size{0} | 1000000000 |
| min_supported_compute_capability | 6.0 |
| strict_readiness | 1 |
| exit_timeout | 30 |
I0316 10:18:05.881152 76 grpc_server.cc:3979] Started GRPCInferenceService at 0.0.0.0:8001
I0316 10:18:05.881430 76 http_server.cc:2717] Started HTTPService at 0.0.0.0:8000
I0316 10:18:05.922536 76 http_server.cc:2736] Started Metrics Service at 0.0.0.0:8002
Environment
TensorRT Version:
GPU Type: A100
Nvidia Driver Version: 450.51.06
CUDA Version: 11.0
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
