To access/use the RTC in Jetson Nano Developer Kit
I am using the Jetson Nano Developer Kit and I want to use the RTC with it. I found that the CS1220 can be used by soldering it onto the provided pins on the Jetson Nano board. Will using the CS1220 in this manner affect the warranty? Alternatively, is there another recommended method? Please advise.
It is ok if you just mount battery/capacitor on it and do not damage board.
