I’ve encountered the same problem with setting up the RTC on my Jetson Orin Nano:
Kinda crazy that there’s no connector or battery housing installed on the dev board.
I followed what I could. I found this document:
It shows the location of J3 on page 6 and says pin 1 is power, pin 2 is ground on page 26. I assume the arrow is pin 1. I verified this by probing pin 2 and saw that it shares a ground with the rest of the chassis. Given this, I installed a CR1220 battery holder and ensured it was delivering at least +3 volts between pin 1 and 2. No dice. RTC kept resetting between power cycles. Then I realized I needed to install a resistor. I installed a 1K ohm resistor on a near by pair of tiny pads but have no idea if it’s the correct one. This also didn’t work so I assume not. I see R560 in the schematics but I can’t find any documentation saying where those pads are physically on the board.
Can anyone assist here? Since this feature is clearly lacking on this dev board, does anyone recommend a way to get an external RTC through I2C or something?
Oh I see. I wasn’t sure what I was looking at. The rectangle you’ve highlighted is the resistor location. So it’s a little to the left of the J3 pads. I installed a 1K ohm resistor there and it still didn’t work. Does that mean R222 needs to be shorted? I see the diagram has a 0ohm / 0.05 ohm label on it.
Just curious. Why was this omitted from the dev board when all previous models have these components? or at least larger solder pads so they can be added.
Hello, I managed to use the RTC in the Orin Nano successfully! It seems there was a mistake with the resistor you used. I utilized the 560mOhm resistor, ERJ-2BQJR56X, which was quite small and challenging to mount. However, it functions without any additional settings:)
