我们使用ORIN NX 8G,测试断电上电,然后在某一次之后系统就无法启动了,以下是串口日志
COM.txt (33.4 KB)
Hi @tiancai1234,
The log stops at a UEFI assertion in FvbNorFlashStandaloneMm.c(978).
Could you please confirm:
- Your exact JetPack/L4T version and carrier board model.
- Whether UEFI or OP-TEE has been customized or patched.
- Whether power was cut during boot or after the system had fully started.
1、版本是35.6.1,载板是我们自研的
2、标准版本,没有定制
3、完全启动后,上电10分钟之后再断电
Hi @tiancai1234,
Could you confirm whether the board can enter Force Recovery Mode using your custom carrier’s recovery procedure? Once connected, run this on the Linux host and share the output:
lsusb -d 0955:7423
Hi @tiancai1234,
Please refer to Assertion 3 in this NVIDIA post, which matches your original boot error. For L4T R35.6.1, refer to the R35.x patches and the StandaloneMM/TOS rebuild steps. The example flashing command is for a JP6.0 devkit and needs adjustment for your R35.6.1 custom-carrier BSP.
我们使用的是两款SSD,A款SSD没有出现此问题,B款SSD出现了这个问题,请问这个BUG触发会跟SSD的品牌有关系么
It has nothing to do with your SSD.
