Sorry, but I think you don’t understand what I’m trying to say… Maybe the problem is in my description. Well, I will share my code.
First of all, I’m using the Ultralytics repository (GitHub - ultralytics/yolov3: YOLOv3 in PyTorch > ONNX > CoreML > TFLite). To replicate what I did, you need to clone it. After that, you may create a file (you can choose the name you want for it) and put this code in:
`import cv2
import torch
import torch_tensorrt
from utils.general import non_max_suppression, scale_coords
import matplotlib.pyplot as plt
from models.experimental import attempt_load
# Letterbox function
def letterbox(image, desired_size):
old_size = image.shape[:2]
ratio = float(desired_size)/max(old_size)
new_size = tuple([int(x*ratio) for x in old_size])
im = cv2.resize(image, (new_size[1], new_size[0]))
delta_w = desired_size - new_size[1]
delta_h = desired_size - new_size[0]
top, bottom = delta_h//2, delta_h-(delta_h//2)
left, right = delta_w//2, delta_w-(delta_w//2)
color = [0, 0, 0]
new_img = cv2.copyMakeBorder(im, top, bottom, left, right, cv2.BORDER_CONSTANT,value=color)
return new_img
weights = "yolov3.pt"
device = "cuda"
img_size = 416
outfile = "yolov3-traced.ts"
img_path = "/home/adriano/Pictures/zidane.jpg"
model = attempt_load(weights, map_location=device, inplace=True, fuse=True)
# Eval mode
model.eval()
# Image base
img_base = torch.rand((1, 3) + (img_size, img_size)).to(device)
# Model load
model(img_base)
# Create traced model
traced_model = torch.jit.trace(model, [img_base], strict=False)
# Compile settings to be used with TensorRT
compile_settings = {
"inputs": [torch_tensorrt.Input((1, 3, 416, 416), dtype=torch.float)],
"enabled_precisions": {torch.float, torch.half}, # Run with FP16
"workspace_size": 1 << 20
# Problematic code!!!
#traced_model = torch_tensorrt.compile(traced_model, **compile_settings)
# Save the jit file
torch.jit.save(traced_model, outfile)
# Torch_TensorRT inference
traced_model =torch.jit.load(outfile)
half = False
# Imagem processing
img = cv2.imread(img_path)
shape = img.shape
img_org = img.copy()
img = letterbox(img, 416)
im = torch.from_numpy(img).to("cuda").unsqueeze_(0)
im = im.half() if half else im.float() # uint8 to fp16/32
im /= 255 # 0 - 255 to 0.0 - 1.0
im = im.permute(0, 3, 1, 2)
# Detection steps
pred, _ = traced_model(im)
det = non_max_suppression(pred, 0.3, 0.3, None, False, max_det=1000)[0]
det[:, :4] = scale_coords(im.shape[2:], det[:, :4], shape).round()
out_detections = det.cpu().detach().numpy()
# Drawing the annotation
if (len(out_detections) > 0):
for d in out_detections:
cv2.rectangle(img_org,(int(d[0]), int(d[1])), (int(d[2]), int(d[3])), (0, 255, 0) ,2)
print(d)
Using this code, I can run the inference. Even with this warn:
/home/adriano/Documents/yolov3/models/yolo.py:58: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can't record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if self.onnx_dynamic or self.grid[i].shape[2:4] != x[i].shape[2:4]:
[ 740 41 1150 712 0.93587 0]
[ 439 430 515 718 0.8167 27]
However, if I remove the comment here:
#traced_model = torch_tensorrt.compile(traced_model, compile_settings)
I receive this error message:
WARNING: [Torch-TensorRT] - There may be undefined behavior using dynamic shape and aten::size
WARNING: [Torch-TensorRT] - Truncating weight (constant in the graph) from Int64 to Int32
WARNING: [Torch-TensorRT TorchScript Conversion Context] - IElementWiseLayer with inputs 360 and (Unnamed Layer* 250) [Shuffle]_output: first input has type Float but second input has type Int32.
ERROR: [Torch-TensorRT TorchScript Conversion Context] - 4: [layers.cpp::validate::2384] Error Code 4: Internal Error (%3080 : Tensor = aten::mul(%360, %10), scope: __module.model.28 # /home/adriano/Documents/yolov3/models/yolo.py:63:0: operation PROD has incompatible input types Float and Int32)
WARNING: [Torch-TensorRT] - Truncating weight (constant in the graph) from Float64 to Float32
ERROR: [Torch-TensorRT TorchScript Conversion Context] - 2: [elementWiseNode.cpp::computeOutputExtents::14] Error Code 2: Internal Error (Assertion x.nbDims == y.nbDims failed. )
ERROR: [Torch-TensorRT TorchScript Conversion Context] - 3: [network.cpp::addConstant::1191] Error Code 3: Internal Error (Parameter check failed at: optimizer/api/network.cpp::addConstant::1191, condition: !weights.values == !weights.count
File "/home/adriano/Documents/yolov3/test.py", line 59, in <module>
File "/home/adriano/anaconda3/envs/torchtensorrt/lib/python3.9/site-packages/torch_tensorrt/_compile.py", line 97, in compile
return torch_tensorrt.ts.compile(ts_mod, inputs=inputs, enabled_precisions=enabled_precisions, **kwargs)
File "/home/adriano/anaconda3/envs/torchtensorrt/lib/python3.9/site-packages/torch_tensorrt/ts/_compiler.py", line 119, in compile
compiled_cpp_mod = _C.compile_graph(module._c, _parse_compile_spec(spec))
RuntimeError: [Error thrown at core/conversion/converters/impl/select.cpp:236] Expected const_layer to be true but got false
Unable to create constant layer from node: %365 : Tensor = aten::slice(%y.1, %8, %25, %21, %27), scope: __module.model.28 # /home/adriano/Documents/yolov3/models/yolo.py:63:0
