TPM compatibility with Jetpack 6 on Orin AGX
Dear Nvidia,
we have an Orin AGX SoC (integrated by forecr) for which we would like to implement full disk encryption, where the key encryption key is stored in the TPM. We require Secure Boot to confirm the hardware/firmware configuration and a pre-boot authentication PIN from the user.
As a preliminary step, to get the full disk encryption working in the first place, we followed your guide on https://docs.nvidia.com/jetson/archives/r36.5/DeveloperGuide/SD/Security/DiskEncryption.html.
We were able to create the flashable file system with an encrypted partition using a dummy disk_enc.key (using default values otherwise) and successfully flash it to the board. The board was able to load the BIOS and bootloader, but was unable to continue booting because it was unable to decrypt the encrypted partition with the error “No key available with this passphrase”.
We presume this is either because we were not able to properly configure the EKS image with this key (We were unable to find the OP-TEE tools to do so), or because the system was unable to retrieve the hardware-based passphrase from nvluks-srv-app (which by default should be the UUID of the encrypted disk according to the documentation).
Do you know this passphrase retrieval issue or have any experience with OP-TEE tools? Please provide support on what is the intended way to combine full disk encryption on this ARM SoC with TPM.
Please feel free to get in touch with me directly for contact details, especially if you have any dedicated business to business support line.
Thanks and kind regards,
Pascal Engelbarts
Airbus Defence and Space GmbH
Hello @pascal.eng_ADS ,
Here are some references regarding OP-TEE and TPM from our Platform Security Manual. They describe how to enable firmware TPM (fTPM) on Jetson via OP-TEE, provision keys securely, and integrate TPM-based key sealing into the Secure Boot chain.
We hope some of these resources can help you. Feel free to reach out to us for more details.
Felipe Solano
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Hi @felipe.solano
Thanks for the response.
We were now able to successfully build and flash an image using the flash.sh script. The system boots from an encrypted partition. We were also able to enroll the key in the TPM2 module.
From there we were not able to proceed because we had issues building the initrd with support for tpm2 decryption. One way we found to do this apparently would be to use tpm2-tss, but in the Ubuntu 22/ Jetpack 6 installation we have this package cannot be found or installed through apt. Is this maybe a known incompatibility on ARM systems? Alternatively, is there a way to create the proper initrd during the image generation before/during the flashing process?
What would be the proper way to link a TPM key to the encrypted partition (through the initrd)?
Kind regards,
Pascal
For the tpm2-tss availability, I checked in a couple of boards with Jetpack 6.x and everything seems to be fine regarding the tool. Can you please provide the output for:
apt-cache policy tpm2-tss tpm2-tools | cat
Regarding the initrd, it should be on the filesystem under Linux_for_Tegra, generated by initramfs.
Also, to link a TPM key to the encrypted partition, it should be enrolled by using LUKS, you can find some references to it here: RidgeRun Platform Security Manual - Embedded Platform Security:Disk Encryption
Feel free to contact us for more details.
Felipe Solano
apt search tmp2
This one looks interesting for initrd tpm2-initramfs-tool
jetson@forecrornx:~$ apt-cache policy tpm2-tools tpm2-tss | cat
tpm2-tools:
  Installed: 5.2-1build1
  Candidate: 5.2-1build1
  Version table:
 *** 5.2-1build1 500
        500 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages
        100 /var/lib/dpkg/status
What we do have is a package called tss2, without the tpm2.
Besides that, the following packages would be available:
tssactivatecredential          tsscreate                      tssevictcontrol
tsshmacstart                   tssnvdefinespace               tssobjectchangeauth
tsspolicygetdigest             tsspolicyticket                tssshutdown
tsscertify                     tsscreateek                    tssflushcontext
tssimaextend                   tssnvextend                    tsspcrallocate
tsspolicymaker                 tsspowerup                     tsssign
tsscertifycreation             tsscreateloaded                tssgetcapability
tssimport                      tssnvglobalwritelock           tsspcrevent
tsspolicymakerpcr              tssquote                       tsssignapp
tsschangeeps                   tsscreateprimary               tssgetcommandauditdigest
tssimportpem                   tssnvincrement                 tsspcrextend
tsspolicynv                    tssreadclock                   tssstartauthsession
tsschangepps                   tssdictionaryattacklockreset   tssgetrandom
tssload                        tssnvread                      tsspcrread
tsspolicynvwritten             tssreadpublic                  tssstartup
tssclear                       tssdictionaryattackparameters  tssgetsessionauditdigest
tssloadexternal                tssnvreadlock                  tsspcrreset
tsspolicyor                    tssreturncode                  tssstirrandom
tssclearcontrol                tssduplicate                   tssgettime
tssmakecredential              tssnvreadpublic                tsspolicyauthorize
tsspolicypassword              tssrewrap                      tsstimepacket
tssclockrateadjust             tsseccparameters               tsshash
tssntc2getconfig               tssnvsetbits                   tsspolicyauthorizenv
tsspolicypcr                   tssrsadecrypt                  tssunseal
tssclockset                    tssecephemeral                 tsshashsequencestart
tssntc2lockconfig              tssnvundefinespace             tsspolicyauthvalue
tsspolicyrestart               tssrsaencrypt                  tssverifysignature
tsscommit                      tssencryptdecrypt              tsshierarchychangeauth
tssntc2preconfig               tssnvundefinespacespecial      tsspolicycommandcode
tsspolicysecret                tsssequencecomplete            tsswriteapp
tsscontextload                 tsseventextend                 tsshierarchycontrol
tssnvcertify                   tssnvwrite                     tsspolicycountertimer
tsspolicysigned                tsssequenceupdate
tsscontextsave                 tsseventsequencecomplete       tsshmac
tssnvchangeauth                tssnvwritelock                 tsspolicycphash
tsspolicytemplate              tsssetprimarypolicy
