**• Hardware Platform ** GPU
• DeepStream Version 6.4
• TensorRT Version Using official docker image
• NVIDIA GPU Driver Version (valid for GPU only) 555.58.02
• Issue Type( questions, new requirements, bugs) bug
I am facing a bug using deepstream’s nvtracker along with appsink.
On stopping the pipeline setting the state to NULL, the nvtracker thread will hang in the function TrackerMiscData::deInit probably on the m_Cond.wait(lock) statement.
This happens on multiple different pipelines, but all have this tracker in common.
appsource → queue → nvinfer → queue → nvtracker ->queue → nvanalytics → queue → nvtiler → converter → nvosd → converter → appsink
Now if I remplace the appsink by fakesink, filesink. or nveglglessink, it works fine. Same if I remove the tracker from the pipeline.
g_object_set(G_OBJECT(_sink), "sync", false, "async", false, "wait-on-eos",
true, "drop", true, "max-buffers", 60, nullptr);
g_object_set(_sink, "emit-signals", TRUE, nullptr);
g_object_set(G_OBJECT(_sink), "enable-last-sample", false, nullptr);
those are the appsink parameters (already tried to mix and match…)
GstFlowReturn VideoShmemWriter::toShmem(GstElement *sink,
const ShmemWriter *shmemWriter) {
GstSample *sample;
sample = gst_app_sink_pull_sample(GST_APP_SINK(sink));
if (gst_app_sink_is_eos(GST_APP_SINK(sink))) {
spdlog::info("EOS received in Appsink");
if (sample) {
GstBuffer *buffer = gst_sample_get_buffer(sample);
GstMapInfo info;
gst_buffer_map(buffer, &info, GST_MAP_READ);
unsigned char *buf = info.data;
if (shmemWriter->_frame && shmemWriter->_resource) {
spdlog::debug("Writing video frame to {}", shmemWriter->_shmem);
shmemWriter->_frame->SetSamplesPtr(buf, true, false);
shmemWriter->_resource->WriteVideoFrame(shmemWriter->_shmem,
shmemWriter->_frame);
gst_buffer_unmap(buffer, &info);
//gst_buffer_unref(buffer);
gst_sample_unref(sample);
return GST_FLOW_OK;
spdlog::error("No new sample to pull");
return GST_FLOW_ERROR;
The code above is the appsink’s callback.
I did try to unref the buffer, hopping to free the memory from the NvDS MetaPool, but I got some complains from gstreamer with the following error assertion 'GST_MINI_OBJECT_REFCOUNT_VALUE (mini_object) > 0' failed
I assume I am either missing something in my appsink or there is an issue in how the cleaning is implemented for the tracker, anyway I am a bit lost here. If there is a fix please let me know.
Updating the deesptream version is not an option.
