I use trafficcamnet to detect the car, but no matter how I adjust the parameters, the results are very poor.
Can someone tell me why?
Can you share the training spec file?
And upload full training log as well?
i was facing the same problem when training my first custom model using tlt.
for it me the YOLO to KITTI dataset conversion wasnāt done properly. Just draw bounding boxes and check .
You can use my code to draw boxes if you require :
Thx , but maybe tomorrow I can upload it on the company computer
Thx!!! I have the foresight that it should be an error in the format of the dataset. I used a previous script to transfer YOLO to KITTI. Previously it performed well in license plate recognition let me think itās a correct conversion . but maybe now I need to try your methodļ¼š
detectnet_v2_train_resnet18_kitti_car.txt (3.0 KB)
status.json (31.7 KB)
this
Oh, I made some changes in your code to draw boxes (change location of kitti label xmin=float(ls[5]) to xmin=float(ls[4])) and then found the result seem to be correct
Thanks, for the heads ups.
haha, Bad thing is that there is nothing wrong with my KITTI dataset
@user101152
How many images in your training dataset?
According to your status.json, you have run training for 120 epochs for 10 minutes.
More, how about the average resolution for the class car? Is the car a small object?
About 1000 imagesļ¼ this status.json is just a part of the data, In fact, the car image resolution varies greatly, which comes from the data collected by the 1080p camera. From the picture, maybe one part is big and the other part is smallā¦
For detectnet_v2, the train tool does not support training on images of multiple resolutions.
Do your training images have the same resolution?
Yeah I think they are all 1920Ć1080
Since you set 960x544 in the spec, please resize images/labels from 1920x1080 to 960x544 .
Refer to below.
The
traintool does not support training on images of multiple resolutions, or resizing images during training. All of the images must be resized offline to the final training size and the corresponding bounding boxes must be scaled accordingly.
Or use below way.
the dataloader does support resizing images to the input resolution defined in the specification file. This can be enabled by setting the
enable_auto_resizeparameter totruein theaugmentation_configmodule of the spec file.
Oh!! I ignored them, maybe because I got good results when I used lpdnet to train license plate recognition and I didnāt adjust the label at that time.
Oh god thx very much!!! This problem bothered me for several days. After setting the **enable_auto_resize** parameter, the accuracy improved too much. and Iād like to know what is the expected training accuracy?
Thanks for the info.
It is hard to draw a conclusion for it. It depends on the input size, backbones, images quantities, etc.
