Train tlt detectnet_v2 resnet18 bbox out of range?
Dear guys,
any idea why this happen? I have the feeling this happen because i try to train object class “person & face” in same model, is this not possible?
Error:
2020-06-30 21:54:27,842 [INFO] iva.detectnet_v2.scripts.train: Found 45 samples in validation set
2020-06-30 21:55:21,484 [INFO] /usr/local/lib/python2.7/dist-packages/iva/detectnet_v2/tfhooks/task_progress_monitor_hook.pyc: Epoch 0/120: loss: 0.10135 Time taken: 0:00:00 ETA: 0:00:00
2020-06-30 21:55:35,892 [INFO] /usr/local/lib/python2.7/dist-packages/iva/detectnet_v2/tfhooks/sample_counter_hook.pyc: Samples / sec: 4.563
2020-06-30 21:55:41,171 [INFO] /usr/local/lib/python2.7/dist-packages/iva/detectnet_v2/tfhooks/sample_counter_hook.pyc: Samples / sec: 18.945
  File "/usr/local/bin/tlt-train-g1", line 8, in <module>
    sys.exit(main())
  File "./common/magnet_train.py", line 47, in main
  File "<decorator-gen-2>", line 2, in main
  File "./detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
  File "./detectnet_v2/scripts/train.py", line 667, in main
  File "./detectnet_v2/scripts/train.py", line 591, in run_experiment
  File "./detectnet_v2/scripts/train.py", line 525, in train_gridbox
  File "./detectnet_v2/scripts/train.py", line 144, in run_training_loop
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 676, in run
    run_metadata=run_metadata)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1270, in run
    raise six.reraise(*original_exc_info)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1255, in run
    return self._sess.run(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1327, in run
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1091, in run
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 929, in run
    run_metadata_ptr)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1152, in _run
    feed_dict_tensor, options, run_metadata)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1328, in _do_run
    run_metadata)
  File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py", line 1348, in _do_call
    raise type(e)(node_def, op, message)
tensorflow.python.framework.errors_impl.InvalidArgumentError: bboxes class ID out of range [0, 2[, got-1
	 [[node BboxRasterizer_2/RasterizeBbox (defined at <string>:159) ]]
	 [[node add_100 (defined at ./detectnet_v2/model/detectnet_model.py:525) ]]
Train config:
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tlt-experiments/data/training"
  image_extension: "jpg"
  target_class_mapping {
    key: "person"
    value: "person"
    key: "face"
    value: "face"
    key: "cart"
    value: "cart"
  validation_fold: 0
augmentation_config {
  preprocessing {
    output_image_width: 960
    output_image_height: 544
    min_bbox_width: 1.0
    min_bbox_height: 1.0
    output_image_channel: 3
  spatial_augmentation {
    hflip_probability: 0.5
    zoom_min: 1.0
    zoom_max: 1.0
    translate_max_x: 8.0
    translate_max_y: 8.0
  color_augmentation {
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
postprocessing_config {
  target_class_config {
    key: "person"
    value {
      clustering_config {
        coverage_threshold: 0.00499999988824
        dbscan_eps: 0.20000000298
        dbscan_min_samples: 0.0500000007451
        minimum_bounding_box_height: 20
    key: "face"
    value {
      clustering_config {
        dbscan_eps: 0.15000000596
model_config {
  pretrained_model_file: "/workspace/tlt-experiments/detectnet_v2/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
  num_layers: 18
  use_batch_norm: true
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  training_precision {
    backend_floatx: FLOAT32
  arch: "resnet"
evaluation_config {
  validation_period_during_training: 10
  first_validation_epoch: 30
  minimum_detection_ground_truth_overlap {
    key: "person"
    value: 0.699999988079
    key: "face"
    value: 0.5
  evaluation_box_config {
    key: "person"
    value {
      minimum_height: 20
      maximum_height: 9999
      minimum_width: 10
      maximum_width: 9999
    key: "face"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  average_precision_mode: INTEGRATE
cost_function_config {
  target_classes {
    class_weight: 1.0
    coverage_foreground_weight: 0.0500000007451
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      initial_weight: 10.0
      weight_target: 10.0
  target_classes {
    class_weight: 8.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 1.0
  enable_autoweighting: true
  max_objective_weight: 0.999899983406
  min_objective_weight: 9.99999974738e-05
training_config {
  batch_size_per_gpu: 4
  num_epochs: 120
  learning_rate {
    soft_start_annealing_schedule {
      min_learning_rate: 5e-06
      max_learning_rate: 5e-04
      soft_start: 0.10000000149
      annealing: 0.699999988079
  regularizer {
    type: L1
    weight: 3.00000002618e-09
  optimizer {
    adam {
      epsilon: 9.99999993923e-09
      beta1: 0.899999976158
      beta2: 0.999000012875
  cost_scaling {
    initial_exponent: 20.0
    increment: 0.005
    decrement: 1.0
  checkpoint_interval: 10
bbox_rasterizer_config {
    key: "person"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 0.40000000596
      cov_radius_y: 0.40000000596
      bbox_min_radius: 1.0
    key: "face"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
  deadzone_radius: 0.400000154972
Thanks for help / info.
Fixed/Solution:
bbox_rasterizer_config { } need for every class a “target_class_config” parameter. was not clear by reading the doc.
