I’m trying to run a segmentation network, the result of which is a 8x3x224x224 tensor.
This takes ~500ms, which seems excessive (this is the time it takes the .cpu() function to run, as measured by cProfile).
Is there a way to reduce this?
Have you maximized the device performance?
It should improve the data transfer performance.
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
