I implemented a custom gstreamer plugin with basetransform as parent and oriented myself on the dsexample.
I want to access the buffer sent by nvarguscamerasrc. From what I understand I can do this (in place) with the transform_ip method.
In this method I made a GstMapInfo from the GstBuffer object and wanted to just print the buffer with the following code:
static GstFlowReturn gst_myplugin_transform_ip(GstBaseTransform *trans, GstBuffer *buf) {
GstMYPlugin *myplugin = GST_MYPLUGIN(trans);
GstMapInfo in_map_info;
std::memset(&in_map_info, 0, sizeof(in_map_info));
if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READ)) {
g_printerr("Could not map input buffer to info object");
return GST_FLOW_ERROR;
g_print("n_buffer: %d\n", gst_buffer_n_memory(buf));
for (int i = 0; i < in_map_info.size / 32; i++) {
for (int j = 0; j < 32; j++) {
g_print("%x ", in_map_info.data[i * j]);
g_print("\n\n");
g_print("\n\n\n\n");
GST_DEBUG_OBJECT(myplugin, "transform_ip");
return GST_FLOW_OK;
But all I get from this is the following repeatedly (with every frame of the camera?):
n_buffer: 1
f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0 f0
f0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 20 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 80 0 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 e 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 80 0 0 3 0 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0
f0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 20 0 0 e 0 0 0 0 0
I test it by using gst-launch-1.0 :
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! myplugin ! fakesink
The caps that were negotiated are the following:
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
So I would expect a much different size and content of the buffer.
What is my problem here ?
