I’m experiencing a confusing problem in what should have been a simple program (I’m learning OptiX and playing around with the various options to prepare for a bigger project). Somehow, introducing a Transform into my scene structure breaks the acceleration structure, causing my intersection programs never to be called (tested with printf).
My scene is structured as follows:
1 Group, with 2 children, and a standard “Trbvh”, “Bvh” acceleration structure, set as top node.
Child 0: a geometry group that contains 1 sphere geometry instance and 1 triangle mesh geometry instance, also with a “Trbvh”, “Bvh” structure.
Child 1: a geometry group that contains one single triangle mesh geometry instance, also “Trbvh”, “Bvh”.
With this, my ray tracer works as expected. However, if I introduce a Transform (with unity matrix) in between the top node and child 1 OptiX never calls a single intersection function: not that of Child 1, but not those of Child 0 either. This seems to be related to the acceleration structures, as I can make the problem go away by giving my top group a “NoAccel”, NoAccel" structure instead. If I give either of the children a NoAccel structure very strange behavior ensues (calling the intersection function with ever increasing primitive indices way out of range of the number of primitives until the 2 second display drive crash occurs).
My first thought was an issue with my bounding box functions, but there is no difference in how the bounding box funstions are called and what they return between the different scenarios (transform or no transform, and Trbvh or NoAccel).
Since the issue is that my intersection functions are never called, I assume there must be something wrong with the way I’m building the scene, as the intersect functions and hit programs never come into it and context->validate() also doesn’t throw up any errors.
I’ve pasted some relevant code snippets below, as well as an OAC trace. Any help would be much appreciated, and please let me know if there’s something else I need to show for you to know what my problem is.
// receiver (aka child 0)
GeometryGroup receiver = context->createGeometryGroup();
receiver->setChildCount(2);
receiver->setChild(0u, rec_square);
receiver->setChild(1u, rec_sphere);
receiver->setAcceleration(context->createAcceleration("Trbvh", "Bvh"));
// object (aka child 1)
GeometryGroup obj_gr = context->createGeometryGroup();
obj_gr->setChildCount(1);
obj_gr->setChild(0u, object);
obj_gr->setAcceleration(context->createAcceleration("Trbvh", "Bvh"));
// transform
float matrix[16] = {1.f, 0.f, 0.f, 0.f,
0.f, 1.f, 0.f, 0.f,
0.f, 0.f, 1.f, 0.f,
0.f, 0.f, 0.f, 1.f };
Transform obj_tr = context->createTransform();
obj_tr->setChild(obj_gr);
obj_tr->setMatrix(0, matrix, NULL);
// top node
Group scene = context->createGroup();
scene->setChildCount(2u);
scene->setChild(0u, receiver);
scene->setChild(1u, obj_tr);
scene->setAcceleration(context->createAcceleration("Trbvh", "Bvh"));
context["top_object"]->set(scene);
OAC trace (with all paths removed because I’ve been using absolute paths in my code and am paranoid):
6
64
Platform: Windows
CUDA driver version: 7050
OptiX Version:[3.9.0] Build Number:[20240475Branch%] CUDA Version:[7.5] 64-bit 2015-12-09
Command line:
Capture time: 2016-02-17 13:06:24
rtContextCreate( 000000000016F9B0 )
res = 0
hdl = 00000000003F1750
rtContextSetRayTypeCount( 00000000003F1750, 2 )
res = 0
rtContextSetEntryPointCount( 00000000003F1750, 1 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, raygen, 000000000016F9D8 )
file = oac.ptx.000000.potx
res = 0
hdl = 00000000064F6080
rtContextSetRayGenerationProgram( 00000000003F1750, 0, 00000000064F6080 )
res = 0
rtContextQueryVariable( 00000000003F1750, ray_openangle, 000000000016F938 )
res = 0
rtContextDeclareVariable( 00000000003F1750, ray_openangle, 000000000016F938 )
res = 0
hdl = 000000000668A150
rtVariableSet1f( 000000000668A150, 0.0174533 )
res = 0
rtContextQueryVariable( 00000000003F1750, tx_pos, 000000000016F938 )
res = 0
rtContextDeclareVariable( 00000000003F1750, tx_pos, 000000000016F938 )
res = 0
hdl = 000000000668A280
rtVariableSet3fv( 000000000668A280, 000000000016FAD0 )
val = 10 0 0
res = 0
rtContextQueryVariable( 00000000003F1750, tx_normal, 000000000016F938 )
res = 0
rtContextDeclareVariable( 00000000003F1750, tx_normal, 000000000016F938 )
res = 0
hdl = 0000000006678960
rtVariableSet3fv( 0000000006678960, 000000000016FA60 )
val = -1 0 0
res = 0
rtBufferCreate( 00000000003F1750, 2, 000000000016F9E8 )
// BUFFER_OUTPUT
res = 0
hdl = 0000000006678B10
rtBufferSetFormat( 0000000006678B10, 285 )
// RT_FORMAT_USER
res = 0
rtBufferSetSize3D( 0000000006678B10, 1, 1, 4 )
res = 0
rtBufferSetElementSize( 0000000006678B10, 28 )
res = 0
rtContextQueryVariable( 00000000003F1750, output_buffer1, 000000000016F938 )
res = 0
rtContextDeclareVariable( 00000000003F1750, output_buffer1, 000000000016F938 )
res = 0
hdl = 00000000066785E0
rtVariableSetObject( 00000000066785E0, 0000000006678B10 )
res = 0
rtGeometryCreate( 00000000003F1750, 000000000016F778 )
res = 0
hdl = 000000000668ADD0
rtGeometrySetPrimitiveCount( 000000000668ADD0, 2 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, bounds, 000000000016F768 )
file = oac.ptx.000001.potx
res = 0
hdl = 000000000668AF90
rtGeometrySetBoundingBoxProgram( 000000000668ADD0, 000000000668AF90 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, intersect, 000000000016F768 )
res = 0
hdl = 00000000067A5C60
rtGeometrySetIntersectionProgram( 000000000668ADD0, 00000000067A5C60 )
res = 0
rtBufferCreate( 00000000003F1750, 1, 000000000016F778 )
// BUFFER_INPUT
res = 0
hdl = 000000000680A8C0
rtBufferSetFormat( 000000000680A8C0, 285 )
// RT_FORMAT_USER
res = 0
rtBufferSetSize1D( 000000000680A8C0, 2 )
res = 0
rtBufferSetElementSize( 000000000680A8C0, 112 )
res = 0
rtGeometryQueryVariable( 000000000668ADD0, tri, 000000000016F6C8 )
res = 0
rtGeometryDeclareVariable( 000000000668ADD0, tri, 000000000016F6C8 )
res = 0
hdl = 0000000006816710
rtVariableSetObject( 0000000006816710, 000000000680A8C0 )
res = 0
rtBufferMap( 000000000680A8C0, 000000000016F8E0 )
res = 0
rtBufferUnmap( 000000000680A8C0 )
file = oac.buf.000001.potx
res = 0
rtMaterialCreate( 00000000003F1750, 000000000016F778 )
res = 0
hdl = 0000000006840ED0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, receiver_hit, 000000000016F768 )
file = oac.ptx.000002.potx
res = 0
hdl = 00000000067ACDC0
rtMaterialSetClosestHitProgram( 0000000006840ED0, 1, 00000000067ACDC0 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, ignore_hit, 000000000016F768 )
res = 0
hdl = 0000000006A8E490
rtMaterialSetAnyHitProgram( 0000000006840ED0, 0, 0000000006A8E490 )
res = 0
rtGeometryInstanceCreate( 00000000003F1750, 000000000016F778 )
res = 0
hdl = 0000000006A8E8F0
rtGeometryInstanceSetGeometry( 0000000006A8E8F0, 000000000668ADD0 )
res = 0
rtGeometryInstanceSetMaterialCount( 0000000006A8E8F0, 1 )
res = 0
rtGeometryInstanceSetMaterial( 0000000006A8E8F0, 0, 0000000006840ED0 )
res = 0
res = 0
hdl = 0000000006AA8780
rtGeometrySetPrimitiveCount( 0000000006AA8780, 1 )
res = 0
file = oac.ptx.000003.potx
res = 0
hdl = 0000000006AA8950
rtGeometrySetBoundingBoxProgram( 0000000006AA8780, 0000000006AA8950 )
res = 0
res = 0
hdl = 0000000006B8DDC0
rtGeometrySetIntersectionProgram( 0000000006AA8780, 0000000006B8DDC0 )
res = 0
res = 0
hdl = 000000000687A1C0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, boundsphere_hit, 000000000016F768 )
res = 0
hdl = 000000000687A280
rtMaterialSetClosestHitProgram( 000000000687A1C0, 0, 000000000687A280 )
res = 0
res = 0
hdl = 0000000006B4CAD0
rtMaterialSetAnyHitProgram( 000000000687A1C0, 1, 0000000006B4CAD0 )
res = 0
res = 0
hdl = 0000000006B79820
rtGeometryInstanceSetGeometry( 0000000006B79820, 0000000006AA8780 )
res = 0
rtGeometryInstanceSetMaterialCount( 0000000006B79820, 1 )
res = 0
rtGeometryInstanceSetMaterial( 0000000006B79820, 0, 000000000687A1C0 )
res = 0
rtGeometryInstanceQueryVariable( 0000000006B79820, spherepars, 000000000016F6C8 )
res = 0
rtGeometryInstanceDeclareVariable( 0000000006B79820, spherepars, 000000000016F6C8 )
res = 0
hdl = 0000000006B799A0
rtVariableSet4fv( 0000000006B799A0, 000000000016F7F0 )
val = 10 0 0 3
res = 0
rtGeometryInstanceQueryVariable( 0000000006B79820, receivepars, 000000000016F6C8 )
res = 0
rtGeometryInstanceDeclareVariable( 0000000006B79820, receivepars, 000000000016F6C8 )
res = 0
hdl = 0000000006879A70
rtVariableSet4fv( 0000000006879A70, 000000000016F7F0 )
val = -1 0 0 0.005
res = 0
rtGeometryGroupCreate( 00000000003F1750, 000000000016F778 )
res = 0
hdl = 0000000006879C20
rtGeometryGroupSetChildCount( 0000000006879C20, 2 )
res = 0
rtGeometryGroupSetChild( 0000000006879C20, 0, 0000000006A8E8F0 )
res = 0
rtGeometryGroupSetChild( 0000000006879C20, 1, 0000000006B79820 )
res = 0
rtAccelerationCreate( 00000000003F1750, 000000000016F778 )
res = 0
hdl = 000000000687B590
rtAccelerationSetBuilder( 000000000687B590, Trbvh )
res = 0
rtAccelerationSetTraverser( 000000000687B590, Bvh )
res = 0
rtGeometryGroupSetAcceleration( 0000000006879C20, 000000000687B590 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, ray_done, 000000000016F9D8 )
res = 0
hdl = 00000000075D4440
rtContextSetMissProgram( 00000000003F1750, 0, 00000000075D4440 )
res = 0
rtGeometryCreate( 00000000003F1750, 000000000016F288 )
res = 0
hdl = 00000000075998D0
rtGeometrySetPrimitiveCount( 00000000075998D0, 8 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, bounds, 000000000016F278 )
res = 0
hdl = 00000000075A21B0
rtGeometrySetBoundingBoxProgram( 00000000075998D0, 00000000075A21B0 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, intersect, 000000000016F278 )
res = 0
hdl = 0000000007632960
rtGeometrySetIntersectionProgram( 00000000075998D0, 0000000007632960 )
res = 0
rtBufferCreate( 00000000003F1750, 1, 000000000016F288 )
// BUFFER_INPUT
res = 0
hdl = 000000000739B830
rtBufferSetFormat( 000000000739B830, 285 )
// RT_FORMAT_USER
res = 0
rtBufferSetSize1D( 000000000739B830, 8 )
res = 0
rtBufferSetElementSize( 000000000739B830, 112 )
res = 0
rtGeometryQueryVariable( 00000000075998D0, tri, 000000000016F1D8 )
res = 0
rtGeometryDeclareVariable( 00000000075998D0, tri, 000000000016F1D8 )
res = 0
hdl = 00000000075F6A60
rtVariableSetObject( 00000000075F6A60, 000000000739B830 )
res = 0
rtBufferMap( 000000000739B830, 000000000016F350 )
res = 0
rtBufferUnmap( 000000000739B830 )
file = oac.buf.000003.potx
res = 0
rtMaterialCreate( 00000000003F1750, 000000000016F288 )
res = 0
hdl = 0000000007576460
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, material_hit, 000000000016F278 )
res = 0
hdl = 00000000075765A0
rtMaterialSetClosestHitProgram( 0000000007576460, 0, 00000000075765A0 )
res = 0
rtProgramCreateFromPTXFile( 00000000003F1750, <path>, terminate_on_hit, 000000000016F278 )
res = 0
hdl = 0000000007664180
rtMaterialSetAnyHitProgram( 0000000007576460, 1, 0000000007664180 )
res = 0
rtGeometryInstanceCreate( 00000000003F1750, 000000000016F288 )
res = 0
hdl = 00000000076A1AD0
rtGeometryInstanceSetGeometry( 00000000076A1AD0, 00000000075998D0 )
res = 0
rtGeometryInstanceSetMaterialCount( 00000000076A1AD0, 1 )
res = 0
rtGeometryInstanceSetMaterial( 00000000076A1AD0, 0, 0000000007576460 )
res = 0
rtGeometryGroupCreate( 00000000003F1750, 000000000016F958 )
res = 0
hdl = 00000000076A1C50
rtGeometryGroupSetChildCount( 00000000076A1C50, 1 )
res = 0
rtGeometryGroupSetChild( 00000000076A1C50, 0, 00000000076A1AD0 )
res = 0
rtAccelerationCreate( 00000000003F1750, 000000000016F958 )
res = 0
hdl = 00000000076A3340
rtAccelerationSetBuilder( 00000000076A3340, Trbvh )
res = 0
rtAccelerationSetTraverser( 00000000076A3340, Bvh )
res = 0
rtGeometryGroupSetAcceleration( 00000000076A1C50, 00000000076A3340 )
res = 0
rtTransformCreate( 00000000003F1750, 000000000016F958 )
res = 0
hdl = 00000000076672B0
rtTransformSetChild( 00000000076672B0, 00000000076A1C50 )
res = 0
rtTransformSetMatrix( 00000000076672B0, 0, 000000000016FB40, 0000000000000000 )
val = 1 -0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
res = 0
rtGeometryGroupCreate( 00000000003F1750, 000000000016F9E8 )
res = 0
hdl = 0000000007776110
rtGeometryGroupSetChildCount( 0000000007776110, 1 )
res = 0
rtGeometryGroupSetChild( 0000000007776110, 0, 00000000076A1AD0 )
res = 0
rtAccelerationCreate( 00000000003F1750, 000000000016F9E8 )
res = 0
hdl = 000000000779B3A0
rtAccelerationSetBuilder( 000000000779B3A0, Trbvh )
res = 0
rtAccelerationSetTraverser( 000000000779B3A0, Bvh )
res = 0
rtGeometryGroupSetAcceleration( 0000000007776110, 000000000779B3A0 )
res = 0
rtGroupCreate( 00000000003F1750, 000000000016F9E8 )
res = 0
hdl = 00000000076F0380
rtGroupSetChildCount( 00000000076F0380, 2 )
res = 0
rtGroupSetChild( 00000000076F0380, 0, 0000000006879C20 )
res = 0
rtGroupSetChild( 00000000076F0380, 1, 00000000076672B0 )
res = 0
res = 0
hdl = 00000000076F12C0
rtAccelerationSetBuilder( 00000000076F12C0, Trbvh )
res = 0
rtAccelerationSetTraverser( 00000000076F12C0, Bvh )
res = 0
rtGroupSetAcceleration( 00000000076F0380, 00000000076F12C0 )
res = 0
rtContextQueryVariable( 00000000003F1750, top_object, 000000000016F938 )
res = 0
rtContextDeclareVariable( 00000000003F1750, top_object, 000000000016F938 )
res = 0
hdl = 00000000077C5DE0
rtVariableSetObject( 00000000077C5DE0, 00000000076F0380 )
res = 0
rtContextValidate( 00000000003F1750 )
res = 0
rtContextCompile( 00000000003F1750 )
res = 0
rtContextLaunch2D( 00000000003F1750, 0, 1, 1 )
file::CUDAbuf::0000000000000000 = oac.CUDAbuf.000003.potx
file::CUDAbuf::0000000000000000 = oac.CUDAbuf.000004.potx
file::CUDAbuf::0000000000000000 = oac.CUDAbuf.000005.potx
file::CUDAbuf::0000000000000000 = oac.CUDAbuf.000006.potx
res = 0
rtBufferMap( 0000000006678B10, 000000000016FAD0 )
res = 0
