I’m new starting to wok with Optix.
I’m trying to reproduce the same output of as
mesh_rot = trimesh.Trimesh(vertices=origins_rot, faces=mesh_for_shadow.faces,process=False)
-- >shadowed = mesh_rot.ray.intersects_any( ray_origins=origins, ray_directions=dirs)
this is my code:
#include "optix_shadow.h"
#include <cuda_runtime.h>
#include <cuda.h>
#include <optix.h>
#include <optix_stubs.h>
#include <optix_function_table_definition.h>
#include <vector>
#include <iostream>
#include <fstream>
#include <cstring>
// ERROR CHECKING
#define OPTIX_CHECK(call) \
do { \
OptixResult res = call; \
if (res != OPTIX_SUCCESS) { \
std::cerr << "OptiX Error: " << res << std::endl; \
exit(1); \
} while(0)
#define CUDA_CHECK(call) \
do { \
cudaError_t err = call; \
if (err != cudaSuccess) { \
std::cerr << "CUDA error: " \
<< cudaGetErrorString(err) \
<< " at " << __FILE__ << ":" << __LINE__\
<< std::endl; \
exit(1); \
} while(0)
// GLOBAL STATE
static OptixDeviceContext context = nullptr;
static OptixTraversableHandle gas_handle = 0;
static CUdeviceptr d_gas_output = 0;
static OptixPipeline pipeline = nullptr;
static OptixModule module = nullptr;
static OptixProgramGroup raygen_prog_group = nullptr;
static OptixProgramGroup miss_prog_group = nullptr;
static OptixProgramGroup hitgroup_prog_group = nullptr;
static OptixShaderBindingTable sbt = {};
static CUstream stream = 0;
static Params params;
static CUdeviceptr d_params;
// MODULE
void create_module(const char* ptx_code)
OptixModuleCompileOptions mopt = {};
mopt.maxRegisterCount = OPTIX_COMPILE_DEFAULT_MAX_REGISTER_COUNT;
mopt.optLevel = OPTIX_COMPILE_OPTIMIZATION_DEFAULT;
mopt.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_MODERATE;
OptixPipelineCompileOptions popt = {};
popt.traversableGraphFlags = OPTIX_TRAVERSABLE_GRAPH_FLAG_ALLOW_SINGLE_GAS;
popt.numPayloadValues = 1;
popt.numAttributeValues = 2; // ⚠️ REQUIRED for triangles
popt.pipelineLaunchParamsVariableName = "params";
char log[2048];
size_t log_size = sizeof(log);
OPTIX_CHECK(
optixModuleCreate(
context,
&mopt,
&popt,
ptx_code,
strlen(ptx_code),
log,
&log_size,
&module
if (log_size > 1)
std::cout << "MODULE LOG:\n" << log << std::endl;
// PROGRAM GROUPS
void create_program_groups()
OptixProgramGroupOptions opts = {};
// ── Raygen ─────────────────────────────
OptixProgramGroupDesc raygen_desc = {};
raygen_desc.kind = OPTIX_PROGRAM_GROUP_KIND_RAYGEN;
raygen_desc.raygen.module = module;
raygen_desc.raygen.entryFunctionName = "__raygen__rg";
OPTIX_CHECK(optixProgramGroupCreate(
context, &raygen_desc, 1, &opts, nullptr, nullptr, &raygen_prog_group));
// ── Miss ───────────────────────────────
OptixProgramGroupDesc miss_desc = {};
miss_desc.kind = OPTIX_PROGRAM_GROUP_KIND_MISS;
miss_desc.miss.module = module;
miss_desc.miss.entryFunctionName = "__miss__ms";
context, &miss_desc, 1, &opts, nullptr, nullptr, &miss_prog_group));
// ── Hitgroup ───────────────────────────
OptixProgramGroupDesc hit_desc = {};
hit_desc.kind = OPTIX_PROGRAM_GROUP_KIND_HITGROUP;
//closest hit
hit_desc.hitgroup.moduleCH = nullptr;
hit_desc.hitgroup.entryFunctionNameCH = nullptr;
//any hit
hit_desc.hitgroup.moduleAH = module;
hit_desc.hitgroup.entryFunctionNameAH = "__anyhit__ah"; // must be non-null to enable any-hit shader
//intersection
hit_desc.hitgroup.moduleIS = nullptr;
hit_desc.hitgroup.entryFunctionNameIS = nullptr;
std::cerr << "Creating hitgroup program group with: ";
if (hit_desc.hitgroup.entryFunctionNameCH)
std::cerr << hit_desc.hitgroup.entryFunctionNameCH;
else
std::cerr << "NULL";
std::cerr << " (CH) and ";
if (hit_desc.hitgroup.entryFunctionNameAH)
std::cerr << hit_desc.hitgroup.entryFunctionNameAH;
else
std::cerr << " (AH)" << std::endl;
context, &hit_desc, 1, &opts, nullptr, nullptr, &hitgroup_prog_group));
// PIPELINE
void create_pipeline()
OptixPipelineLinkOptions link = {};
link.maxTraceDepth = 1;
OptixProgramGroup groups[] = {
raygen_prog_group,
miss_prog_group,
hitgroup_prog_group
OPTIX_CHECK(optixPipelineCreate(
context,
&popt,
&link,
groups,
3,
nullptr,
nullptr,
&pipeline));
// CRITICAL
OPTIX_CHECK(optixPipelineSetStackSize(
pipeline,
2048,
2048,
2048,
1
// SBT
struct RayGenRecord { char header[OPTIX_SBT_RECORD_HEADER_SIZE]; };
struct MissRecord { char header[OPTIX_SBT_RECORD_HEADER_SIZE]; };
struct HitRecord { char header[OPTIX_SBT_RECORD_HEADER_SIZE]; };
void create_sbt()
// Raygen
RayGenRecord rg;
optixSbtRecordPackHeader(raygen_prog_group, &rg);
cudaMalloc((void**)&sbt.raygenRecord, sizeof(rg));
cudaMemcpy((void*)sbt.raygenRecord, &rg, sizeof(rg), cudaMemcpyHostToDevice);
// Miss
MissRecord ms;
optixSbtRecordPackHeader(miss_prog_group, &ms);
cudaMalloc((void**)&sbt.missRecordBase, sizeof(ms));
cudaMemcpy((void*)sbt.missRecordBase, &ms, sizeof(ms), cudaMemcpyHostToDevice);
sbt.missRecordStrideInBytes = sizeof(MissRecord);
sbt.missRecordCount = 1;
// Hit
HitRecord hg;
optixSbtRecordPackHeader(hitgroup_prog_group, &hg);
cudaMalloc((void**)&sbt.hitgroupRecordBase, sizeof(hg));
cudaMemcpy((void*)sbt.hitgroupRecordBase, &hg, sizeof(hg), cudaMemcpyHostToDevice);
sbt.hitgroupRecordStrideInBytes = sizeof(HitRecord);
sbt.hitgroupRecordCount = 1;
// INIT
void init_optix(const float* vertices, int num_vertices,
const int32_t* faces, int num_faces)
std::cerr << "Initializing OptiX...\n";
CUDA_CHECK(cudaFree(0)); // init CUDA
OPTIX_CHECK(optixInit());
OptixDeviceContextOptions options = {};
options.logCallbackLevel = 4;
OPTIX_CHECK(optixDeviceContextCreate(0, &options, &context));
std::cerr << "Context created.\n";
// Upload geometry
CUdeviceptr d_vertices = 0;
CUdeviceptr d_indices = 0;
size_t v_bytes = num_vertices * 3 * sizeof(float);
size_t i_bytes = num_faces * 3 * sizeof(uint32_t);
std::cerr << "Allocating vertices: " << v_bytes << " bytes\n";
CUDA_CHECK(cudaMalloc((void**)&d_vertices, v_bytes));
std::cerr << "Copying vertices\n";
CUDA_CHECK(cudaMemcpy((void*)d_vertices, vertices,
v_bytes, cudaMemcpyHostToDevice));
std::cerr << "Allocating indices: " << i_bytes << " bytes\n";
CUDA_CHECK(cudaMalloc((void**)&d_indices, i_bytes));
std::cerr << "Copying indices\n";
CUDA_CHECK(cudaMemcpy((void*)d_indices, faces,
i_bytes, cudaMemcpyHostToDevice));
CUDA_CHECK(cudaDeviceSynchronize());
std::cerr << "Geometry uploaded.\n";
// Build GAS
uint32_t triangle_input_flags[1] = { OPTIX_GEOMETRY_FLAG_NONE };
OptixBuildInput build_input = {};
build_input.type = OPTIX_BUILD_INPUT_TYPE_TRIANGLES;
CUdeviceptr vb[] = { d_vertices };
build_input.triangleArray.vertexBuffers = vb;
build_input.triangleArray.numVertices = num_vertices;
build_input.triangleArray.vertexFormat = OPTIX_VERTEX_FORMAT_FLOAT3;
build_input.triangleArray.vertexStrideInBytes = sizeof(float) * 3;
build_input.triangleArray.indexBuffer = d_indices;
build_input.triangleArray.numIndexTriplets = num_faces;
build_input.triangleArray.indexFormat = OPTIX_INDICES_FORMAT_UNSIGNED_INT3;
build_input.triangleArray.indexStrideInBytes = sizeof(uint32_t) * 3;
build_input.triangleArray.flags = triangle_input_flags;
build_input.triangleArray.numSbtRecords = 1;
OptixAccelBuildOptions opts = {};
opts.operation = OPTIX_BUILD_OPERATION_BUILD;
OptixAccelBufferSizes sizes;
OPTIX_CHECK(optixAccelComputeMemoryUsage(
context, &opts, &build_input, 1, &sizes));
std::cerr << "Temp size: " << sizes.tempSizeInBytes << "\n";
std::cerr << "Output size: " << sizes.outputSizeInBytes << "\n";
CUdeviceptr d_temp = 0;
CUDA_CHECK(cudaMalloc((void**)&d_temp, sizes.tempSizeInBytes));
CUDA_CHECK(cudaMalloc((void**)&d_gas_output, sizes.outputSizeInBytes));
OPTIX_CHECK(optixAccelBuild(
context, 0,
&opts,
&build_input, 1,
d_temp, sizes.tempSizeInBytes,
d_gas_output, sizes.outputSizeInBytes,
&gas_handle,
nullptr, 0
CUDA_CHECK(cudaFree((void*)d_temp));
std::cerr << "GAS built successfully.\n";
// Stream + params
CUDA_CHECK(cudaStreamCreate(&stream));
CUDA_CHECK(cudaMalloc((void**)&d_params, sizeof(Params)));
// Load PTX
std::ifstream file("build/optix_shadow.ptx");
if (!file) {
std::cerr << "Failed to open PTX file\n";
exit(1);
std::string ptx((std::istreambuf_iterator<char>(file)),
std::istreambuf_iterator<char>());
std::cerr << "Creating module...\n";
create_module(ptx.c_str());
std::cerr << "Creating program groups...\n";
create_program_groups();
std::cerr << "Creating pipeline...\n";
create_pipeline();
std::cerr << "Creating SBT...\n";
create_sbt();
std::cerr << "OptiX fully initialized.\n";
// QUERY
std::vector<bool> shadow_rays(const float* origins,
const float* dirs,
int N)
CUdeviceptr d_origins, d_dirs, d_results;
cudaMalloc((void**)&d_origins, N*sizeof(float3));
cudaMalloc((void**)&d_dirs, N*sizeof(float3));
cudaMalloc((void**)&d_results, N*sizeof(int));
cudaMemcpy((void*)d_origins, origins, N*sizeof(float3), cudaMemcpyHostToDevice);
cudaMemcpy((void*)d_dirs, dirs, N*sizeof(float3), cudaMemcpyHostToDevice);
params.origins = (float3*)d_origins;
params.dirs = (float3*)d_dirs;
params.results = (int*)d_results;
params.N = N;
params.handle = gas_handle;
cudaMemcpy((void*)d_params, ¶ms, sizeof(Params), cudaMemcpyHostToDevice);
OPTIX_CHECK(optixLaunch(
pipeline,
stream,
d_params,
sizeof(Params),
&sbt,
N, 1, 1
cudaDeviceSynchronize();
std::vector<int> tmp(N);
cudaMemcpy(tmp.data(), (void*)d_results, N*sizeof(int), cudaMemcpyDeviceToHost);
std::vector<bool> out(N);
for (int i = 0; i < N; ++i)
out[i] = tmp[i] != 0;
cudaFree((void*)d_origins);
cudaFree((void*)d_dirs);
cudaFree((void*)d_results);
return out;
#include <optix.h>
#include <optix_device.h>
#include <cuda.h>
struct Params {
float3* origins;
float3* dirs;
int* results;
int N;
OptixTraversableHandle handle;
extern "C" {
__constant__ Params params;
// RAYGEN
extern "C" __global__ void __raygen__rg()
const int idx = optixGetLaunchIndex().x;
if (idx >= params.N) return;
float3 origin = params.origins[idx];
float3 dir = params.dirs[idx];
unsigned int payload = 0; // default = no hit
optixTrace(
params.handle,
origin,
dir,
1e-3f,
1e16f,
0.0f,
OptixVisibilityMask(255),
OPTIX_RAY_FLAG_DISABLE_CLOSESTHIT,
0, 1, 0,
payload
params.results[idx] = (payload != 0);
extern "C" __global__ void __anyhit__ah()
optixSetPayload_0(1); // mark hit
optixTerminateRay(); // stop immediately
// MISS
extern "C" __global__ void __miss__ms()
// payload stays 0 → no hit
// HIT
extern "C" __global__ void __closesthit__ch()
