Triton Inference Server Image: nvcr.io/nvidia/tritonserver:20.03.1-py3
GPU: T4
OS: Ubuntu 18.04
Driver: 440.33.01
CUDA version: 10.1, cudnn 7.6.5
Tensorflow: 2.2
Hi, I am using Triton inference server for doing dynamic batching based inference.
Following is my config.pbtxt file -
platform: “tensorflow_savedmodel”
max_batch_size: 64
input {
data_type: TYPE_UINT8
dims: -1
dims: -1
dims: -1
output {
data_type: TYPE_FP32
dims: 100
dims: 7
instance_group [
count: 1
kind: KIND_GPU
dynamic_batching {
preferred_batch_size: [8, 64]
max_queue_delay_microseconds: 100
default_model_filename: “model.savedmodel”
I am successfully able to run the inferrence using a single instance of my effdet model.
However changing number of model instances to anything other than 1, i.e
instance_group [
count: 2 #[or 3,4 etc]
kind: KIND_GPU
leads to an error CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered.
Refering to the screenshot, can someone please assist me with a solution.
Thank you,
Shubham
