Trouble in converting non square grid in YOLO Network to tensorrt via DeepStream
If anyone is still looking for a working solution for asymmetric models, I’ve rolled a patch below:
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/kernels.cu b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/kernels.cu
index 45032f0..43f1906 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/kernels.cu
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/kernels.cu
@@ -17,20 +17,20 @@
 inline __device__ float sigmoidGPU(const float& x) { return 1.0f / (1.0f + __expf(-x)); }
-__global__ void gpuYoloLayerV3(const float* input, float* output, const uint gridSize, const uint numOutputClasses,
+__global__ void gpuYoloLayerV3(const float* input, float* output, const uint gridSizeX,  const uint gridSizeY, const uint numOutputClasses,
                                const uint numBBoxes)
     uint x_id = blockIdx.x * blockDim.x + threadIdx.x;
     uint y_id = blockIdx.y * blockDim.y + threadIdx.y;
     uint z_id = blockIdx.z * blockDim.z + threadIdx.z;
-    if ((x_id >= gridSize) || (y_id >= gridSize) || (z_id >= numBBoxes))
+    if ((x_id >= gridSizeX) || (y_id >= gridSizeY) || (z_id >= numBBoxes))
         return;
-    const int numGridCells = gridSize * gridSize;
-    const int bbindex = y_id * gridSize + x_id;
+    const int numGridCells = gridSizeX * gridSizeY;
+    const int bbindex = y_id * gridSizeX + x_id;
     output[bbindex + numGridCells * (z_id * (5 + numOutputClasses) + 0)]
         = sigmoidGPU(input[bbindex + numGridCells * (z_id * (5 + numOutputClasses) + 0)]);
@@ -54,23 +54,23 @@ __global__ void gpuYoloLayerV3(const float* input, float* output, const uint gri
-cudaError_t cudaYoloLayerV3(const void* input, void* output, const uint& batchSize, const uint& gridSize,
+cudaError_t cudaYoloLayerV3(const void* input, void* output, const uint& batchSize, const uint& gridSizeX, const uint& gridSizeY,
                             const uint& numOutputClasses, const uint& numBBoxes,
                             uint64_t outputSize, cudaStream_t stream);
     dim3 threads_per_block(16, 16, 4);
-    dim3 number_of_blocks((gridSize / threads_per_block.x) + 1,
-                          (gridSize / threads_per_block.y) + 1,
+    dim3 number_of_blocks((gridSizeX / threads_per_block.x) + 1,
+                          (gridSizeY / threads_per_block.y) + 1,
                           (numBBoxes / threads_per_block.z) + 1);
     for (unsigned int batch = 0; batch < batchSize; ++batch)
         gpuYoloLayerV3<<<number_of_blocks, threads_per_block, 0, stream>>>(
             reinterpret_cast<const float*>(input) + (batch * outputSize),
-            reinterpret_cast<float*>(output) + (batch * outputSize), gridSize, numOutputClasses,
+            reinterpret_cast<float*>(output) + (batch * outputSize), gridSizeX, gridSizeY, numOutputClasses,
             numBBoxes);
     return cudaGetLastError();
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp
index 4226027..45399ef 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp
@@ -29,7 +29,7 @@
 #include <iostream>
 #include <unordered_map>
-static const int NUM_CLASSES_YOLO = 80;
+static const int NUM_CLASSES_YOLO = 13;
 extern "C" bool NvDsInferParseCustomYoloV3(
     std::vector<NvDsInferLayerInfo> const& outputLayersInfo,
@@ -167,22 +167,22 @@ nmsAllClasses(const float nmsThresh,
 static std::vector<NvDsInferParseObjectInfo>
 decodeYoloV2Tensor(
     const float* detections, const std::vector<float> &anchors,
-    const uint gridSize, const uint stride, const uint numBBoxes,
+    const uint gridSizeX, const uint gridSizeY, const uint stride, const uint numBBoxes,
     const uint numOutputClasses, const float probThresh, const uint& netW,
     const uint& netH)
     std::vector<NvDsInferParseObjectInfo> binfo;
-    for (uint y = 0; y < gridSize; ++y)
+    for (uint y = 0; y < gridSizeY; ++y)
-        for (uint x = 0; x < gridSize; ++x)
+        for (uint x = 0; x < gridSizeX; ++x)
             for (uint b = 0; b < numBBoxes; ++b)
                 const float pw = anchors[b * 2];
                 const float ph = anchors[b * 2 + 1];
-                const int bbindex = y * gridSize + x;
+                const int bbindex = y * gridSizeX + x;
                 const float bx
                     = x + detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 0)];
                 const float by
@@ -226,22 +226,22 @@ decodeYoloV2Tensor(
 decodeYoloV3Tensor(
     const float* detections, const std::vector<int> &mask, const std::vector<float> &anchors,
     const uint& netH)
                 const float pw = anchors[mask[b] * 2];
                 const float ph = anchors[mask[b] * 2 + 1];
                 const float bx
                 const float by
@@ -304,8 +304,8 @@ static bool NvDsInferParseYoloV3(
     const std::vector<std::vector<int>> &masks)
     const uint kNUM_BBOXES = 3;
-    static const float kNMS_THRESH = 0.3f;
-    static const float kPROB_THRESH = 0.7f;
+    static const float kNMS_THRESH = 0.4f;
+    static const float kPROB_THRESH = 0.3f;
     const std::vector<const NvDsInferLayerInfo*> sortedLayers =
         SortLayers (outputLayersInfo);
@@ -328,11 +328,12 @@ static bool NvDsInferParseYoloV3(
     for (uint idx = 0; idx < masks.size(); ++idx) {
         const NvDsInferLayerInfo &layer = *sortedLayers[idx]; // 255 x Grid x Grid
         assert (layer.dims.numDims == 3);
-        const uint gridSize = layer.dims.d[1];
-        const uint stride = networkInfo.width / gridSize;
+      const uint gridSizeY = layer.dims.d[1];
+      const uint gridSizeX = layer.dims.d[2];
+      const uint stride = networkInfo.height / gridSizeY;
         std::vector<NvDsInferParseObjectInfo> outObjs =
-            decodeYoloV3Tensor((const float*)(layer.buffer), masks[idx], anchors, gridSize, stride, kNUM_BBOXES,
+            decodeYoloV3Tensor((const float*)(layer.buffer), masks[idx], anchors, gridSizeX, gridSizeY, stride, kNUM_BBOXES,
                        NUM_CLASSES_YOLO, kPROB_THRESH, networkInfo.width, networkInfo.height);
         objects.insert(objects.end(), outObjs.begin(), outObjs.end());
@@ -373,8 +374,8 @@ extern "C" bool NvDsInferParseCustomYoloV3Tiny(
         10, 14, 23, 27, 37, 58, 81, 82, 135, 169, 344, 319};
     static const std::vector<std::vector<int>> kMASKS = {
         {3, 4, 5},
-        //{0, 1, 2}}; // as per output result, select {1,2,3}
-        {1, 2, 3}};
+        {0, 1, 2}}; // as per output result, select {1,2,3}
+//        {1, 2, 3}};
     return NvDsInferParseYoloV3 (
         outputLayersInfo, networkInfo, detectionParams, objectList,
@@ -408,10 +409,12 @@ static bool NvDsInferParseYoloV2(
     std::vector<NvDsInferParseObjectInfo> objects =
-        decodeYoloV2Tensor((const float*)(layer.buffer), kANCHORS, gridSize, stride, kNUM_BBOXES,
+        decodeYoloV2Tensor((const float*)(layer.buffer), kANCHORS, gridSizeX, gridSizeY, stride, kNUM_BBOXES,
                    NUM_CLASSES_YOLO, probthreshold, networkInfo.width, networkInfo.height);
     objectList.clear();
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.cpp b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.cpp
index 17049e8..46ee475 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.cpp
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.cpp
@@ -373,19 +373,20 @@ nvinfer1::ILayer* netAddUpsample(int layerIdx, std::map<std::string, std::string
     assert(block.at("type") == "upsample");
     nvinfer1::Dims inpDims = input->getDimensions();
     assert(inpDims.nbDims == 3);
-    assert(inpDims.d[1] == inpDims.d[2]);
+//    assert(inpDims.d[1] == inpDims.d[2]);
     int h = inpDims.d[1];
     int w = inpDims.d[2];
     int stride = std::stoi(block.at("stride"));
     // add pre multiply matrix as a constant
     nvinfer1::Dims preDims{3,
-                           {1, stride * h, w},
-                           {nvinfer1::DimensionType::kCHANNEL, nvinfer1::DimensionType::kSPATIAL,
+                           {1, stride * h, h},
+                           {nvinfer1::DimensionType::kCHANNEL,
+                            nvinfer1::DimensionType::kSPATIAL,
                             nvinfer1::DimensionType::kSPATIAL}};
-    int size = stride * h * w;
+    int size = stride * h * h;
     nvinfer1::Weights preMul{nvinfer1::DataType::kFLOAT, nullptr, size};
     float* preWt = new float;
-    /* (2*h * w)
+    /* (2*h * h)
     [ [1, 0, ..., 0],
       [1, 0, ..., 0],
       [0, 1, ..., 0],
@@ -397,12 +398,9 @@ nvinfer1::ILayer* netAddUpsample(int layerIdx, std::map<std::string, std::string
     for (int i = 0, idx = 0; i < h; ++i)
-        for (int s = 0; s < stride; ++s)
+        for (int j = 0; j < h * stride; ++j, ++idx)
-            for (int j = 0; j < w; ++j, ++idx)
-                preWt[idx] = (i == j) ? 1.0 : 0.0;
+            preWt[idx] = (i == j) ? 1.0 : 0.0;
     preMul.values = preWt;
@@ -413,20 +411,20 @@ nvinfer1::ILayer* netAddUpsample(int layerIdx, std::map<std::string, std::string
     preM->setName(preLayerName.c_str());
     // add post multiply matrix as a constant
     nvinfer1::Dims postDims{3,
-                            {1, h, stride * w},
+                            {1, w, stride * w},
-    size = stride * h * w;
+    size = stride * w * w;
     nvinfer1::Weights postMul{nvinfer1::DataType::kFLOAT, nullptr, size};
     float* postWt = new float;
-    /* (h * 2*w)
+    /* (w * 2*w)
     [ [1, 1, 0, 0, ..., 0, 0],
       [0, 0, 1, 1, ..., 0, 0],
       [0, 0, 0, 0, ..., 1, 1] ]
-    for (int i = 0, idx = 0; i < h; ++i)
+    for (int i = 0, idx = 0; i < w; ++i)
         for (int j = 0; j < stride * w; ++j, ++idx)
@@ -441,8 +439,8 @@ nvinfer1::ILayer* netAddUpsample(int layerIdx, std::map<std::string, std::string
     post_m->setName(postLayerName.c_str());
     // add matrix multiply layers for upsampling
     nvinfer1::IMatrixMultiplyLayer* mm1
-        = network->addMatrixMultiply(*preM->getOutput(0), nvinfer1::MatrixOperation::kNONE, *input,
-                                     nvinfer1::MatrixOperation::kNONE);
+        = network->addMatrixMultiply(*preM->getOutput(0), nvinfer1::MatrixOperation::kNONE,
+                                     *input,nvinfer1::MatrixOperation::kNONE);
     assert(mm1 != nullptr);
     std::string mm1LayerName = "mm1_" + std::to_string(layerIdx);
     mm1->setName(mm1LayerName.c_str());
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.h b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.h
index 97dcc5f..26e901b 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.h
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/trt_utils.h
@@ -46,23 +46,26 @@ private:
                              nvinfer1::DimsHW stride, nvinfer1::DimsHW padding,
                              nvinfer1::DimsHW dilation, const char* layerName) const override
-        assert(inputDims.d[0] == inputDims.d[1]);
+//        assert(inputDims.d[0] == inputDims.d[1]);
         assert(kernelSize.d[0] == kernelSize.d[1]);
         assert(stride.d[0] == stride.d[1]);
         assert(padding.d[0] == padding.d[1]);
-        int outputDim;
+        int outputDimH;
+        int outputDimW;
         // Only layer maxpool_12 makes use of same padding
         if (m_SamePaddingLayers.find(layerName) != m_SamePaddingLayers.end())
-            outputDim = (inputDims.d[0] + 2 * padding.d[0]) / stride.d[0];
+            outputDimH = (inputDims.d[0] + 2 * padding.d[0]) / stride.d[0];
+            outputDimW = (inputDims.d[1] + 2 * padding.d[1]) / stride.d[1];
         // Valid Padding
         else
-            outputDim = (inputDims.d[0] - kernelSize.d[0]) / stride.d[0] + 1;
+            outputDimH = (inputDims.d[0] - kernelSize.d[0]) / stride.d[0] + 1;
+            outputDimW = (inputDims.d[1] - kernelSize.d[1]) / stride.d[1] + 1;
-        return nvinfer1::DimsHW{outputDim, outputDim};
+        return nvinfer1::DimsHW{outputDimH, outputDimW};
 public:
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.cpp b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.cpp
index 379694a..bbc34eb 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.cpp
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.cpp
@@ -173,19 +173,21 @@ nvinfer1::INetworkDefinition *Yolo::createYoloNetwork (
         else if (m_configBlocks.at(i).at("type") == "yolo")
             nvinfer1::Dims prevTensorDims = previous->getDimensions();
-            assert(prevTensorDims.d[1] == prevTensorDims.d[2]);
+//            assert(prevTensorDims.d[1] == prevTensorDims.d[2]);
             TensorInfo& curYoloTensor = m_OutputTensors.at(outputTensorCount);
-            curYoloTensor.gridSize = prevTensorDims.d[1];
-            curYoloTensor.stride = m_InputW / curYoloTensor.gridSize;
-            m_OutputTensors.at(outputTensorCount).volume = curYoloTensor.gridSize
-                * curYoloTensor.gridSize
+            curYoloTensor.gridSizeY = prevTensorDims.d[1];
+            curYoloTensor.gridSizeX = prevTensorDims.d[2];
+            curYoloTensor.stride = m_InputH / curYoloTensor.gridSizeY;
+            m_OutputTensors.at(outputTensorCount).volume = curYoloTensor.gridSizeY
+                * curYoloTensor.gridSizeX
                 * (curYoloTensor.numBBoxes * (5 + curYoloTensor.numClasses));
             std::string layerName = "yolo_" + std::to_string(i);
             curYoloTensor.blobName = layerName;
             nvinfer1::IPluginV2* yoloPlugin
                 = new YoloLayerV3(m_OutputTensors.at(outputTensorCount).numBBoxes,
                                   m_OutputTensors.at(outputTensorCount).numClasses,
-                                  m_OutputTensors.at(outputTensorCount).gridSize);
+                                  m_OutputTensors.at(outputTensorCount).gridSizeX,
+                                  m_OutputTensors.at(outputTensorCount).gridSizeY);
             assert(yoloPlugin != nullptr);
             nvinfer1::IPluginV2Layer* yolo = network->addPluginV2(&previous, 1, *yoloPlugin);
             assert(yolo != nullptr);
@@ -206,10 +208,11 @@ nvinfer1::INetworkDefinition *Yolo::createYoloNetwork (
             TensorInfo& curRegionTensor = m_OutputTensors.at(outputTensorCount);
-            curRegionTensor.gridSize = prevTensorDims.d[1];
-            curRegionTensor.stride = m_InputW / curRegionTensor.gridSize;
-            m_OutputTensors.at(outputTensorCount).volume = curRegionTensor.gridSize
-                * curRegionTensor.gridSize
+            curRegionTensor.gridSizeY = prevTensorDims.d[1];
+            curRegionTensor.gridSizeX = prevTensorDims.d[2];
+            curRegionTensor.stride = m_InputW / curRegionTensor.gridSizeX;
+            m_OutputTensors.at(outputTensorCount).volume = curRegionTensor.gridSizeX
+                * curRegionTensor.gridSizeY
                 * (curRegionTensor.numBBoxes * (5 + curRegionTensor.numClasses));
             std::string layerName = "region_" + std::to_string(i);
             curRegionTensor.blobName = layerName;
@@ -423,7 +426,7 @@ void Yolo::parseConfigBlocks()
             m_InputH = std::stoul(block.at("height"));
             m_InputW = std::stoul(block.at("width"));
             m_InputC = std::stoul(block.at("channels"));
-            assert(m_InputW == m_InputH);
+//            assert(m_InputW == m_InputH);
             m_InputSize = m_InputC * m_InputH * m_InputW;
         else if ((block.at("type") == "region") || (block.at("type") == "yolo"))
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.h b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.h
index 968ba2b..f002588 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.h
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yolo.h
@@ -50,7 +50,8 @@ struct TensorInfo
     std::string blobName;
     uint stride{0};
-    uint gridSize{0};
+    uint gridSizeY{0};
+    uint gridSizeX{0};
     uint numClasses{0};
     uint numBBoxes{0};
     uint64_t volume{0};
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.cpp b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.cpp
index e8a90b3..1da010c 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.cpp
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.cpp
@@ -45,7 +45,7 @@ void read(const char*& buffer, T& val)
 // Forward declaration of cuda kernels
 cudaError_t cudaYoloLayerV3 (
-    const uint& gridSize, const uint& numOutputClasses,
+    const uint& gridSizeX, const uint& gridSizeY,  const uint& numOutputClasses,
     const uint& numBBoxes, uint64_t outputSize, cudaStream_t stream);
 YoloLayerV3::YoloLayerV3 (const void* data, size_t length)
@@ -53,20 +53,23 @@ YoloLayerV3::YoloLayerV3 (const void* data, size_t length)
     const char *d = static_cast<const char*>(data);
     read(d, m_NumBoxes);
     read(d, m_NumClasses);
-    read(d, m_GridSize);
+    read(d, m_GridSizeX);
+    read(d, m_GridSizeY);
     read(d, m_OutputSize);
-    const uint& numBoxes, const uint& numClasses, const uint& gridSize) :
+    const uint& numBoxes, const uint& numClasses, const uint& gridSizeX, const uint& gridSizeY) :
     m_NumBoxes(numBoxes),
     m_NumClasses(numClasses),
-    m_GridSize(gridSize)
+    m_GridSizeX(gridSizeX),
+    m_GridSizeY(gridSizeY)
     assert(m_NumBoxes > 0);
     assert(m_NumClasses > 0);
-    assert(m_GridSize > 0);
-    m_OutputSize = m_GridSize * m_GridSize * (m_NumBoxes * (4 + 1 + m_NumClasses));
+    assert(m_GridSizeX > 0);
+    assert(m_GridSizeY > 0);
+    m_OutputSize = m_GridSizeX * m_GridSizeY * (m_NumBoxes * (4 + 1 + m_NumClasses));
 nvinfer1::Dims
@@ -100,14 +103,14 @@ int YoloLayerV3::enqueue(
     CHECK(cudaYoloLayerV3(
-              inputs[0], outputs[0], batchSize, m_GridSize, m_NumClasses, m_NumBoxes,
+              inputs[0], outputs[0], batchSize, m_GridSizeX, m_GridSizeY, m_NumClasses, m_NumBoxes,
               m_OutputSize, stream));
     return 0;
 size_t YoloLayerV3::getSerializationSize() const
-    return sizeof(m_NumBoxes) + sizeof(m_NumClasses) + sizeof(m_GridSize) + sizeof(m_OutputSize);
+    return sizeof(m_NumBoxes) + sizeof(m_NumClasses) + sizeof(m_GridSizeX) + sizeof(m_GridSizeY) + sizeof(m_OutputSize);
 void YoloLayerV3::serialize(void* buffer) const
@@ -115,13 +118,14 @@ void YoloLayerV3::serialize(void* buffer) const
     char *d = static_cast<char*>(buffer);
     write(d, m_NumBoxes);
     write(d, m_NumClasses);
-    write(d, m_GridSize);
+    write(d, m_GridSizeX);
+    write(d, m_GridSizeY);
     write(d, m_OutputSize);
 nvinfer1::IPluginV2* YoloLayerV3::clone() const
-    return new YoloLayerV3 (m_NumBoxes, m_NumClasses, m_GridSize);
+    return new YoloLayerV3 (m_NumBoxes, m_NumClasses, m_GridSizeX, m_GridSizeY);
 REGISTER_TENSORRT_PLUGIN(YoloLayerV3PluginCreator);
diff --git a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.h b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.h
index f10047e..21487b2 100755
--- a/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.h
+++ b/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/yoloPlugins.h
@@ -51,7 +51,7 @@ class YoloLayerV3 : public nvinfer1::IPluginV2
 public:
     YoloLayerV3 (const void* data, size_t length);
-    YoloLayerV3 (const uint& numBoxes, const uint& numClasses, const uint& gridSize);
+    YoloLayerV3 (const uint& numBoxes, const uint& numClasses, const uint& gridSizeX, const uint& gridSizeY);
     const char* getPluginType () const override { return YOLOV3LAYER_PLUGIN_NAME; }
     const char* getPluginVersion () const override { return YOLOV3LAYER_PLUGIN_VERSION; }
     int getNbOutputs () const override { return 1; }
@@ -89,7 +89,8 @@ public:
 private:
     uint m_NumBoxes {0};
     uint m_NumClasses {0};
-    uint m_GridSize {0};
+    uint m_GridSizeX {0};
+    uint m_GridSizeY {0};
     uint64_t m_OutputSize {0};
     std::string m_Namespace {""};
