Hello! I apologize in advance for the novice question but I’m trying to learn how to get cublas_v2 function calls working in a Fortran code. The codes are a 1d heat equation solver using implicit methods as part of a school research project and when I compile I cannot seem to get cublas to link correctly. The section of code that the compiler complains about is
function impmid_driver(nt, ts, xs, dx, init_dt, ti, tf, beta) result(u)
!https://docs.nvidia.com/hpc-sdk/compilers/fortran-cuda-interfaces/index.html#iface-introduction
use cudafor
use cublas_v2
use cusolverDn
implicit none
integer, value, intent(in) :: nt
real(8), intent(in) :: ts(:), xs(NX), dx, init_dt, ti, tf, beta
real(8) :: t_f, dt, t, gamma
real(8) :: a(NX, NX), b(NX, NX), u(NX)
integer :: i, stat
real(8), device :: a_d(NX, NX), u_d(NX)
real(8), device :: b_d(NX, NX), y1_d(NX), workspace_d(NX)
integer, device :: pivots_d(NX), info_d
type (cublasHandle) ::cb_h
type (cusolverDnHandle) :: cs_h
stat = cublasCreate(cb_h)
stat = cusolverDnCreate(cs_h)
!initializations
dt = init_dt
gamma = beta * dt / (dx * dx)
call init_u(u, xs)
u_d = u
!initialize the matricies for LU. Only perform one LU decompose on b
!then use the getrs solvers on decomposed b each iteration.
call init_a(a, gamma)
a_d = a
call init_b(a, b)
b_d = b
!https://docs.nvidia.com/cuda/cusolver/index.html#cuSolverDN-lt-t-gt-getrf
stat = cusolverDnDgetrf(cs_h, NX, NX, b_d, NX, workspace_d, pivots_d, info_d)
t_f = ti
!run time stepping loop
do i=1,size(ts)
!implicit step
!https://docs.nvidia.com/cuda/cusolver/index.html#cuSolverDN-lt-t-gt-getrs
y1_d = u_d
!Note I have no idea what nrhs is supposed to be so I just set it to 1
stat = cusolverDnDgetrs(cs_h, CUBLAS_OP_N, NX, 1, b_d, NX, pivots_d, y1_d, NX, info_d)
!update step
!https://docs.nvidia.com/cuda/cublas/index.html#cublas-lt-t-gt-gemv
!note I have no idea what the inc[x,y] are supposed to be so I just used 1
stat = cublasDgemv_v2(cb_h, CUBLAS_OP_N, NX, NX, 1.0, a_d, NX, y1_d, 1, 1.0, u_d, 1.0)
stat = cudaDeviceSynchronize()
!update total time
t_f = t_f + dt
end do
u = u_d
end function impmid_driver
I am compiling the full program (omitted here to cut back on clutter, I can provide it if it helps) using nvfortran -o impmid.x impmid.cuf -cpp -DNX=20 and am greeted with the error
NVFORTRAN-S-0155-Could not resolve generic procedure cublasdgemv_v2 (impmid.cuf: 173)
0 inform, 0 warnings, 1 severes, 0 fatal for impmid_driver
I’ve tried adding the -cudalib=cublas and -lblas flags but nothing changed. This is confusing to me because I don’t seem to be getting any errors regarding the use of cusolver calls, only cublas calls. My user environment is making use of the nvhpc/21.9 modulefile.
Thanks in advance for any tips/help you can provide!
