I’m trying to develop a 2D FFT for an Imaging App using CUFFT, but it doesn’t seem to be working. The CUDA (*.cu) code I’m working with is below.
My FFT output does not have any specturm. It looks like grainy image. No real or imaginary axis. (My FFT expertise is minimum).
Note that the image is 400 x 400(lena.pgm), and stored in an array of unsigned chars.
void runTest(unsigned char *pixels, int w, int h, unsigned char *outArray)
// Allocate host memory for the image
cufftReal *host_real_image = (cufftReal*)malloc(sizeof(cufftReal)* w*h);
cufftComplex* h_result = (cufftComplex*)malloc(sizeof(cufftComplex) * w*h);
// Initalize the memory for the image
for (unsigned int i = 0; i < (w*h); ++i)
host_real_image[i] = pixels[i];
host_real_image[i+1] = 0;
int mem_size = sizeof(cufftReal)* w*h;
int out_size = sizeof(cufftComplex)*w*h;
// Allocate device memory image
cufftReal* device_real_image;
CUDA_SAFE_CALL(cudaMalloc((void**)&device_real_image, mem_size));
// Copy host memory to device
CUDA_SAFE_CALL(cudaMemcpy(device_real_image host_real_image, mem_size, cudaMemcpyHostToDevice));
// Allocate device memory for output
cufftComplex *d_result;
CUDA_SAFE_CALL(cudaMalloc((void**)&d_result, out_size));
// CUFFT plan
cufftHandle plan;
CUFFT_SAFE_CALL(cufftPlan2d(&plan, w, h, CUFFT_R2C));
// Transform image and kernel
CUFFT_SAFE_CALL(cufftExecR2C(plan, (cufftReal *)device_real_image, (cufftComplex *)d_result));
CUFFT_SAFE_CALL(cufftDestroy(plan));
// CUFFT plan
cufftHandle plan1;
CUFFT_SAFE_CALL(cufftPlan2d(&plan1, w, h, CUFFT_C2R));
cufftExecC2R( plan1, (cufftComplex *)d_result, (cufftReal *)device_real_image);
CUFFT_SAFE_CALL(cufftDestroy(plan1));
// Copy device memory to host
CUDA_SAFE_CALL(cudaMemcpy(h_result, d_result, out_size,
cudaMemcpyDeviceToHost));
// Initalize the memory for the output image
for (unsigned int i = 0; i < (w*h); i+=2)
outArray[(2*i)] = h_result[i].x;
outArray[(2*i)+1] = h_result[i].y;
// cleanup memory
free( host_real_image);
CUDA_SAFE_CALL(cudaFree(d_signal));
Can anyone tell me what I’m doing wrong here?
Thanks in advance
