TRT LLM for Inference - two Sparks example is VERY slow
I ran this example:
docker exec
-e MODEL=“nvidia/Qwen3-235B-A22B-FP4”
-e HF_TOKEN=$HF_TOKEN
-it $TRTLLM_MN_CONTAINER bash -c ’
mpirun -x HF_TOKEN trtllm-llmapi-launch trtllm-serve $MODEL
–tp_size 2
–backend pytorch
–max_num_tokens 32768
–max_batch_size 4
–extra_llm_api_options /tmp/extra-llm-api-config.yml
–port 8355’
from this page: “Try NVIDIA NIM APIs
and the inference speed was very-very slow.
The example from the single spark page: “Try NVIDIA NIM APIs
export MODEL_HANDLE=“openai/gpt-oss-120b”
docker run
-e MODEL_HANDLE=$MODEL_HANDLE
-v $HOME/.cache/huggingface/:/root/.cache/huggingface/
–rm -it --ulimit memlock=-1 --ulimit stack=67108864
–gpus=all --ipc=host --network host
nvcr.io/nvidia/tensorrt-llm/release:spark-single-gpu-dev
bash -c ’
export TIKTOKEN_ENCODINGS_BASE=“/tmp/harmony-reqs” &&
mkdir -p $TIKTOKEN_ENCODINGS_BASE &&
wget -P $TIKTOKEN_ENCODINGS_BASE https://openaipublic.blob.core.windows.net/encodings/o200k_base.tiktoken &&
wget -P $TIKTOKEN_ENCODINGS_BASE https://openaipublic.blob.core.windows.net/encodings/cl100k_base.tiktoken &&
hf download $MODEL_HANDLE &&
python examples/llm-api/quickstart_advanced.py
–model_dir $MODEL_HANDLE
–prompt “Paris is great because”
–max_tokens 64
was much-much faster, and I suspect that was because it used an optimized branch of tensor-rt:
”nvcr.io/nvidia/tensorrt-llm/release:spark-single-gpu-dev”
Is there an optimized version for two sparks? Please respond with an actual answer and don’t just say “read the documentation”.thanks
You can see all availabe tags in the NGC catalog. There is no explicite dual-node image, but there is one newer image than spark-single-gpu-dev.
You could try that.
rc0.post1 was published on 10/14/2025 10:42 AM - bleeding edge
single-spark was published on 10/06/2025 10:20 PM
Still waiting for a newer build, because there were improvements for RTX5090/sm120 for FP4 a few days ago in the main tree. That’s why I stumbled upon it.
We posted a detailed issue on github:
If we are not able to resolve this, then we will just return the two sparks back to nvidia.
What performance numbers are you seeing for single vs stacked setups?
Edit: Please also use trtllm-bench to collect performance numbers
I’ve had much better luck with the nvcr.io/nvidia/tensorrt-llm/release:1.2.0rc1 image that was released today. Could you please share a docker-command to run the trtllm-bench benchmark for both single and dual sparks. It feels like the single model instance is faster than the sharded model, so I need to properly benchmark them. Thanks!
You are comparing a model with 22B active parameters with a model with 3B active parameters. Of course gpt-oss-120b will be faster…
