Trtexec and dynamic batch size
Description
I am trying to convert a Pytorch model to TensorRT and then do inference in TensorRT using the Python API.
My model takes two inputs: left_input and right_input and outputs a cost_volume. I want the batch size to be dynamic and accept either a batch size of 1 or 2.
Can I use trtexec to generate an optimized engine for dynamic input shapes?
My current call:
	trtexec \
		--verbose \
		--explicitBatch \
		--minShapes=left_input:1x3x512x512,right_input:1x3x512x512,cost_volume:1x20x128x128 \
		--optShapes=left_input:2x3x512x512,right_input:2x3x512x512,cost_volume:2x20x128x128 \
		--maxShapes=left_input:2x3x512x512,right_input:2x3x512x512,cost_volume:2x20x128x128 \
		--onnx='my_onnx_model' \
		--saveEngine='my_trt_model' \
		--workspace=3000
But I cannot get the inference in Python to work with this model. It works for a batch_size of 1, but with a batch size of 2, only the first batch is correct.
When I load the engine in Python I get:
In [1]: engine.get_binding_name(0)
Out[1]: u'left_input'
In [2]: engine.get_binding_name(1)
Out[2]: u'right_input'
In [3]: engine.get_binding_name(2)
Out[3]: u'cost_volume'
In [4]: engine.get_binding_shape(0)
Out[4]: (-1, 3, 512, 512)
In [5]: engine.get_binding_shape(1)
Out[5]: (-1, 3, 512, 512)
In [6]: engine.get_binding_shape(2)
Out[6]: (1, 20, 128, 128)
In [7]: execution_context = engine.create_execution_context()
In [8]: execution_context.get_binding_shape(0)
Out[8]: (-1, 3, 512, 512)
In [9]: execution_context.get_binding_shape(1)
Out[9]: (-1, 3, 512, 512)
In [10]: execution_context.get_binding_shape(2)
[TensorRT] ERROR: Parameter check failed at: engine.cpp::resolveSlots::1092, condition: allInputDimensionsSpecified(routine)
Out[10]: (0)
I am wondering why the output doesn’t get a dynamic batch.
Any guidance here would be appreciated.
Environment
TensorRT Version: 7.0.0-1+cuda10.0 amd64
GPU Type: GeForce GTX 1070
Nvidia Driver Version: 440.82
CUDA Version: 10.0
CUDNN Version: 7.6.5.32-1+cuda10.0 amd64
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6
PyTorch Version (if applicable): 1.4.0
Hi, Can you please share the model and script, so that we can help better.
Also, if possible , please share the verbose error log.
You need to call execution_context.set_binding_shape on your input bindings, to make them have whatever batch you are planning to use.
Only after that can you call get_binding_shape on the output bindings (or use the context at all)
can confirm this works. thanks!
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
