Description
I built the continainer from the main repo. Runs find. But alot of packages are missing. I have fixed that. But now I cannot progress because trtexec cannot be found in usr/src/bin. I have tried reformatting PATH in the Dockerfile but nothing works. Please help. Ty
Environment
TensorRT Version: latest
GPU Type: A6000
Nvidia Driver Version: 550
CUDA Version: 12.4
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag): latest container
Relevant Files
Dockerfile
ARG CUDA_VERSION=12.6.0
FROM nvidia/cuda:${CUDA_VERSION}-devel-ubuntu22.04
LABEL maintainer="NVIDIA CORPORATION"
ENV NV_CUDNN_VERSION 8.9.6.50
ENV NV_CUDNN_PACKAGE_NAME "libcudnn8"
ENV CUDA_VERSION_MAJOR_MINOR=12.2
ENV NV_CUDNN_PACKAGE "libcudnn8=$NV_CUDNN_VERSION-1+cuda${CUDA_VERSION_MAJOR_MINOR}"
ENV NV_CUDNN_PACKAGE_DEV "libcudnn8-dev=$NV_CUDNN_VERSION-1+cuda${CUDA_VERSION_MAJOR_MINOR}"
ENV TRT_VERSION 10.6.0.26
SHELL ["/bin/bash", "-c"]
RUN apt-get update && apt-get install -y --no-install-recommends \
${NV_CUDNN_PACKAGE} \
${NV_CUDNN_PACKAGE_DEV} \
&& apt-mark hold ${NV_CUDNN_PACKAGE_NAME} \
&& rm -rf /var/lib/apt/lists/*
# Setup user account
ARG uid=1000
ARG gid=1000
RUN groupadd -r -f -g ${gid} trtuser && useradd -o -r -l -u ${uid} -g ${gid} -ms /bin/bash trtuser
RUN usermod -aG sudo trtuser
RUN echo 'trtuser:nvidia' | chpasswd
RUN mkdir -p /workspace && chown trtuser /workspace
# Required to build Ubuntu 20.04 without user prompts with DLFW container
ENV DEBIAN_FRONTEND=noninteractive
# Update CUDA signing key
RUN apt-key adv --fetch-keys https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/3bf863cc.pub
# Install requried libraries
RUN apt-get update && apt-get install -y software-properties-common
RUN add-apt-repository ppa:ubuntu-toolchain-r/test
libcurl4-openssl-dev \
wget \
git \
pkg-config \
sudo \
ssh \
libssl-dev \
pbzip2 \
pv \
bzip2 \
unzip \
devscripts \
lintian \
fakeroot \
dh-make \
build-essential
# Install python3
RUN apt-get install -y --no-install-recommends \
python3 \
python3-pip \
python3-dev \
python3-wheel &&\
cd /usr/local/bin &&\
ln -s /usr/bin/python3 python &&\
ln -s /usr/bin/pip3 pip;
# Install TensorRT
RUN if [ "${CUDA_VERSION:0:2}" = "11" ]; then \
wget https://developer.nvidia.com/downloads/compute/machine-learning/tensorrt/10.6.0/tars/TensorRT-10.6.0.26.Linux.x86_64-gnu.cuda-11.8.tar.gz \
&& tar -xf TensorRT-10.6.0.26.Linux.x86_64-gnu.cuda-11.8.tar.gz \
&& cp -a TensorRT-10.6.0.26/lib/*.so* /usr/lib/x86_64-linux-gnu \
&& pip install TensorRT-10.6.0.26/python/tensorrt-10.6.0-cp310-none-linux_x86_64.whl ;\
elif [ "${CUDA_VERSION:0:2}" = "12" ]; then \
wget https://developer.nvidia.com/downloads/compute/machine-learning/tensorrt/10.6.0/tars/TensorRT-10.6.0.26.Linux.x86_64-gnu.cuda-12.6.tar.gz \
&& tar -xf TensorRT-10.6.0.26.Linux.x86_64-gnu.cuda-12.6.tar.gz \
else \
echo "Invalid CUDA_VERSION"; \
exit 1; \
fi
# Install PyPI packages
RUN pip3 install --upgrade pip
RUN pip3 install setuptools>=41.0.0
COPY requirements.txt /tmp/requirements.txt
RUN pip3 install -r /tmp/requirements.txt
RUN pip3 install jupyter jupyterlab
# Workaround to remove numpy installed with tensorflow
RUN pip3 install --upgrade numpy
# Install Cmake
RUN cd /tmp && \
wget https://github.com/Kitware/CMake/releases/download/v3.14.4/cmake-3.14.4-Linux-x86_64.sh && \
chmod +x cmake-3.14.4-Linux-x86_64.sh && \
./cmake-3.14.4-Linux-x86_64.sh --prefix=/usr/local --exclude-subdir --skip-license && \
rm ./cmake-3.14.4-Linux-x86_64.sh
# Download NGC client
RUN cd /usr/local/bin && wget https://ngc.nvidia.com/downloads/ngccli_cat_linux.zip && unzip ngccli_cat_linux.zip && chmod u+x ngc-cli/ngc && rm ngccli_cat_linux.zip ngc-cli.md5 && echo "no-apikey\nascii\n" | ngc-cli/ngc config set
# Set environment and working directory
ENV TRT_LIBPATH /usr/lib/x86_64-linux-gnu
ENV TRT_OSSPATH /workspace/TensorRT
ENV PATH="/workspace/TensorRT/build/out:${PATH}:/usr/local/bin/ngc-cli"
ENV PATH="/usr/src/tensorrt/bin:${PATH}"
ENV LD_LIBRARY_PATH="${LD_LIBRARY_PATH}:${TRT_OSSPATH}/build/out:${TRT_LIBPATH}"
WORKDIR /workspace
USER trtuser
RUN ["/bin/bash"]
