How to get/compile trtexec for TensorRT installed using pip
Hey,
I’m trying to follow the TensorRT quick start guide: Quick Start Guide :: NVIDIA Deep Learning TensorRT Documentation
I installed everything using pip, and the small python test code runs fine.
Then they say to use a tool called trtexec to create a .trt file from an onnx file, and this tool is supposed to come with the TensorRT installation. I didn’t install it myself though, pip installed everything for me. Where then do I get this tool? I tried looking around in the python install directory (.local/lib/python3.8/site-packages/tensorrt) but it’s not there.
I then tried compiling it myself from a new download of TensorRT, version 8.0.0.3 from https://developer.nvidia.com/nvidia-tensorrt-download, by running make inside the samples/trtexec folder. This results in the following errors:
../Makefile.config:11: CUDA_INSTALL_DIR variable is not specified, using /usr/local/cuda by default, use CUDA_INSTALL_DIR=<cuda_directory> to change.
../Makefile.config:16: CUDNN_INSTALL_DIR variable is not specified, using /usr/local/cuda by default, use CUDNN_INSTALL_DIR=<cudnn_directory> to change.
../Makefile.config:29: TRT_LIB_DIR is not specified, searching ../../lib, ../../lib, ../lib by default, use TRT_LIB_DIR=<trt_lib_directory> to change.
if [ ! -d ../../bin/chobj/../common ]; then mkdir -p ../../bin/dchobj/../common; fi; :
Compiling: trtexec.cpp
In file included from ../common/buffers.h:20,
                 from trtexec.cpp:35:
../common/common.h:38:10: fatal error: cuda_runtime_api.h: No such file or directory
   38 | #include <cuda_runtime_api.h>
compilation terminated.
make: *** [../Makefile.config:355: ../../bin/dchobj/trtexec.o] Error 1
This makes sense, I didn’t set those environment variables. What should I set them to? Or it it really necessary for me to install Cuda separately as well?
I have exactly the same issue.
Have you found a solution yet?
I just tried compiling it again, and everything just worked.
I think the issue I originally had is that I didn’t have CUDA installed correctly. For example, cuda_runtime_api.h is supposed to be located at $CUDA_INSTALL_DIR/include/cuda_runtime_api.h, or /usr/local/cuda/include/cuda_runtime_api.h if CUDA is installed in the default location. If this is not the case maybe try reinstalling CUDA and cuDNN?
Note:
To actually run trtexec afterwards I had to set the environment variable LD_LIBRARY_PATH to include the TensorTR lib folder included in the download, otherwise it would give the following error:
../../bin/trtexec: error while loading shared libraries: libnvinfer.so.8: cannot open shared object file: No such file or directory
Thanks for the update!
